[petsc-users] VecView output to HDF5 in 3.12.0 broken ?
Sajid Ali
sajidsyed2021 at u.northwestern.edu
Fri Oct 11 15:35:15 CDT 2019
I've run this with a minimal code snippet that just saves a vector (unlike
one created from MatCreateVecsFFTW) to hdf5 (with size 268435456) on a
workstation and cluster and it failed on both systems.
I'm attaching the code and log files from both workstation and cluster.
Thank You,
Sajid Ali
Applied Physics
Northwestern University
s-sajid-ali.github.io
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191011/7cae490f/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191011/7cae490f/attachment-0003.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191011/7cae490f/attachment-0004.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191011/7cae490f/attachment-0005.obj>
