[petsc-users] VecView output to HDF5 in 3.12.0 broken ?
Stefano Zampini stefano.zampini at gmail.com
Fri Oct 11 15:54:27 CDT 2019
The size you want to use 268435456, multiplied by 8 (size of double) gives 2147483648, 1 more than the largest 32bit int.
Not sure if this is a limitation in how PETSc creates the HDF5 metadata or not, I did not write that code
> On Oct 11, 2019, at 11:35 PM, Sajid Ali via petsc-users <petsc-users at mcs.anl.gov> wrote:
> 268435456
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191011/e0d1a19a/attachment.html>
