[petsc-users] VecView output to HDF5 in 3.12.0 broken ?
Sajid Ali sajidsyed2021 at u.northwestern.edu
Thu Oct 10 12:12:34 CDT 2019
Hi PETSc-developers,
I'm seeing an error while trying to write a vector to hdf5 file. The size
of the (complex valued) vector is 16384x16384.  I'm attaching the output
log file and the code that was run.
This was a known bug before the 3.12.0 release but as per an old thread, it
was fixed. Which makes me even more confused as to why it still occurs with
the new version.
Thank You,
Sajid Ali
Applied Physics
Northwestern University
s-sajid-ali.github.io
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191010/d2f4abac/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191010/d2f4abac/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191010/d2f4abac/attachment-0003.obj>
