[Darshan-users] Data written to /dev/shm not captured by Darshan
Håkon Strandenes hakostra at stud.ntnu.no
Tue Jun 19 01:50:25 CDT 2012
Hello,
I am trying to profile OpenFOAM (http://www.openfoam.com/) with Darshan.
This seems to work pretty good, although I have encountered a little
problem that I hope you could help me with:
I am trying to write the data from each process to /dev/shm to reduce
the total filesystem IO (witch seems to be a bottleneck in some cases).
The problem is that Darshan does not capture this data, and report 0 MB
written to an unknown filesystem. See attached PDFs. The case is
identical except that in the first case (Normal.pdf) all processes
writes data to /home, and in the last case (DEV-SHM.pdf) only a few
files are read from /home, and the rest is read and written from /dev/shm.
Does any of you have some ideas why Darshan does not capture the data
written to/from /dev/shm?
I have tried doing this on my workstation, with another version of
OpenFOAM (newer), and the same thing happens. OpenFOAM and Darshan is in
both cases compiled with the same compiler, Intel and GNU respectivly.
Best regards,
Håkon Strandenes
Norwegian University of Science and Technology
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20120619/1be05ba5/attachment-0002.pdf>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20120619/1be05ba5/attachment-0003.pdf>
More information about the Darshan-users mailing list
