[Darshan-users] Data written to /dev/shm not captured by Darshan
Phil Carns
carns at mcs.anl.gov
Tue Jun 19 07:24:57 CDT 2012
Hi Håkon,
Darshan is configured to automatically filter out access to certain
types of file systems, one of which is tmpfs. If you look in the
darsan-runtime/lib/darshan-mpi-io.c file, there is a statement that
looks like this:
static char* fs_exclusions[] = {
"tmpfs",
"proc",
"sysfs",
"devpts",
"binfmt_misc",
If you delete the "tmpfs" line and recompile Darshan then it should pick
up the access to /dev/shm just like any other file system.
Unfortunately this is hard coded right now, but we can make this
configurable in the future.
thanks,
-Phil
On 06/19/2012 02:50 AM, Håkon Strandenes wrote:
> Hello,
> I am trying to profile OpenFOAM (http://www.openfoam.com/) with
> Darshan. This seems to work pretty good, although I have encountered a
> little problem that I hope you could help me with:
> I am trying to write the data from each process to /dev/shm to reduce
> the total filesystem IO (witch seems to be a bottleneck in some
> cases). The problem is that Darshan does not capture this data, and
> report 0 MB written to an unknown filesystem. See attached PDFs. The
> case is identical except that in the first case (Normal.pdf) all
> processes writes data to /home, and in the last case (DEV-SHM.pdf)
> only a few files are read from /home, and the rest is read and written
> from /dev/shm.
> Does any of you have some ideas why Darshan does not capture the data
> written to/from /dev/shm?
> I have tried doing this on my workstation, with another version of
> OpenFOAM (newer), and the same thing happens. OpenFOAM and Darshan is
> in both cases compiled with the same compiler, Intel and GNU respectivly.
> Best regards,
> Håkon Strandenes
> Norwegian University of Science and Technology
> Darshan-users mailing list
> Darshan-users at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/darshan-users
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20120619/34b196c3/attachment.html>
More information about the Darshan-users
