[Swift-user] Block task failed on Tukey/Cobalt
Ketan Maheshwari
ketan at mcs.anl.gov
Tue Feb 11 11:12:28 CST 2014
This was fixed after changing the default project from the expired atpesc
to ExM.
Thanks!
On Tue, Feb 11, 2014 at 10:51 AM, David Kelly <davidkelly at uchicago.edu>wrote:
> The Cobalt provider submits jobs via the command line rather than a submit
> script, so I believe empty submit scripts are normal. From the log it looks
> like jobs are getting submitted and getting a job number. Are you running
> from a filesystem that is shared on worker nodes?
> On Tue, Feb 11, 2014 at 10:12 AM, Ketan Maheshwari <ketan at mcs.anl.gov>wrote:
>> Swift Tutorial scripts worked on Tukey as of last August during the
>> ATPESC tutorials.
>> I find that empty Cobalt submit script files are created.
>> On Tue, Feb 11, 2014 at 9:27 AM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
>>> Has anyone else run successfully on Tukey?
>>> Can you inspect/post the Swift-generated Cobalt submit script? You may
>>> also want to inspect/post the Cobalt-generated
>>> *.submit.stdout/*.submit.stderr logs.
>>> On 02/10/2014 08:23 PM, Ketan Maheshwari wrote:
>>> Hi,
>>> Trying some Swift test for Swift-Galaxy demo on Tukey. Using
>>> local:cobalt coaster provider. I am getting the following error:
>>> $ swift -sites.file sites.xml -tc.file tc -config cf script.swift
>>> Swift 0.94 swift-r6637 cog-r3742
>>> RunID: 20140211-0216-ryo7slj7
>>> Progress: time: Tue, 11 Feb 2014 02:16:53 +0000
>>> Progress: time: Tue, 11 Feb 2014 02:17:23 +0000 Submitted:3
>>> Progress: time: Tue, 11 Feb 2014 02:17:53 +0000 Submitted:3
>>> Progress: time: Tue, 11 Feb 2014 02:17:58 +0000 Submitted:2 Active:1
>>> Execution failed:
>>> Exception in sh:
>>> Arguments:
>>> [gpfs/mira-home/ketan/galaxy-dist/database/files/000/dataset_1.dat, 0]
>>> Host: tukey
>>> Directory: script-20140211-0216-ryo7slj7/jobs/u/sh-uv25u9ml
>>> Caused by:
>>> Block task failed:
>>> anapp, script.swift, line 13
>>> Tried many different options in swift.properties to no avail.
>>> Also tried the ATPESC 2013 tutorial setup but scripts fail with same
>>> pattern/error messages.
>>> Attaching the tarball with config, sites file.
>>> Thanks for any suggestions.
>>> Ketan
>>> _______________________________________________
>>> Swift-user mailing listSwift-user at ci.uchicago.eduhttps://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
>>> Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140211/233b9c19/attachment.html>
More information about the Swift-user
