[Swift-user] Block task failed on Tukey/Cobalt
David Kelly
davidkelly at uchicago.edu
Tue Feb 11 10:51:21 CST 2014
The Cobalt provider submits jobs via the command line rather than a submit
script, so I believe empty submit scripts are normal. From the log it looks
like jobs are getting submitted and getting a job number. Are you running
from a filesystem that is shared on worker nodes?
On Tue, Feb 11, 2014 at 10:12 AM, Ketan Maheshwari <ketan at mcs.anl.gov>wrote:
> Swift Tutorial scripts worked on Tukey as of last August during the ATPESC
> tutorials.
> I find that empty Cobalt submit script files are created.
> On Tue, Feb 11, 2014 at 9:27 AM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
>> Has anyone else run successfully on Tukey?
>> Can you inspect/post the Swift-generated Cobalt submit script? You may
>> also want to inspect/post the Cobalt-generated
>> *.submit.stdout/*.submit.stderr logs.
>> On 02/10/2014 08:23 PM, Ketan Maheshwari wrote:
>> Hi,
>> Trying some Swift test for Swift-Galaxy demo on Tukey. Using
>> local:cobalt coaster provider. I am getting the following error:
>> $ swift -sites.file sites.xml -tc.file tc -config cf script.swift
>> Swift 0.94 swift-r6637 cog-r3742
>> RunID: 20140211-0216-ryo7slj7
>> Progress: time: Tue, 11 Feb 2014 02:16:53 +0000
>> Progress: time: Tue, 11 Feb 2014 02:17:23 +0000 Submitted:3
>> Progress: time: Tue, 11 Feb 2014 02:17:53 +0000 Submitted:3
>> Progress: time: Tue, 11 Feb 2014 02:17:58 +0000 Submitted:2 Active:1
>> Execution failed:
>> Exception in sh:
>> Arguments:
>> [gpfs/mira-home/ketan/galaxy-dist/database/files/000/dataset_1.dat, 0]
>> Host: tukey
>> Directory: script-20140211-0216-ryo7slj7/jobs/u/sh-uv25u9ml
>> Caused by:
>> Block task failed:
>> anapp, script.swift, line 13
>> Tried many different options in swift.properties to no avail.
>> Also tried the ATPESC 2013 tutorial setup but scripts fail with same
>> pattern/error messages.
>> Attaching the tarball with config, sites file.
>> Thanks for any suggestions.
>> Ketan
>> Swift-user mailing listSwift-user at ci.uchicago.eduhttps://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-user
>> Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20140211/74e4b11f/attachment.html>
More information about the Swift-user
