[Swift-user] Swift-Plot-Log
Melinda Chin me.melly at gmail.com
Mon Jun 22 15:28:36 CDT 2009
I was testing out the swift-plot-log command however I was running into some
troubles.  I was using
http://www.ci.uchicago.edu/swift/guides/log-processing.php as my guide to
run swift-plot-log on a random log I picked from the
/disk/ci-gpfs/swift/swift-logs directory.
My swift-plot log is in /home/mchin/swift/bin
Inside the swift dir, I created a log-processing dir and a bin dir in side
it and typed the commands as shown on the above url, Step 3.
*[mchin at tp-login2 bin]$* cd ../log-processing/bin/
*[mchin at tp-login2 bin]$ *export PATH=$(pwd):$PATH
*[mchin at tp-login2 bin]$* swift-plot-log
/path/to/mchin-20090609-1307-020920gc.log
Log file path is /path/to/mchin-20090609-1307-020920gc.log
Log is in directory /path/to
Log basename is mchin-20090609-1307-020920gc
Now in directory /tmp/swift-plot-log-pnKiMSBLiTdy9503
rm -f start-times.data kickstart-times.data start-time.tmp end-time.tmp
threads.list tasks.list log *.data *.shifted *.png *.event *.coloured-event
*.total *.tmp *.transitions *.last karatasks-type-counts.txt index.html
*.lastsummary execstages.plot total.plot colour.plot jobs-sites.html
jobs.retrycount.summary kickstart.stats execution-counts.txt
site-duration.txt jobs.retrycount sp.plot karatasks.coloured-sorted-event
*.cedps *.stats t.inf *.seenstates tmp-* clusterstats  trname-summary
sites-list.data.nm info-md5sums pse2d-tmp.eip karajan.html falkon.html
execute2.html info.html execute.html kickstart.html scheduler.html
assorted.html
make: *** No rule to make target
`/path/to/mchin-20090609-1307-020920gc.log', needed by
`karatasks.transitions'.  Stop.
pwd: /home/mchin/swift/log-processing/bin
The directory I am in is empty at the moment, but I have tried it with the
swift-plot-log as well as the log file (in the current directory at the same
time) and the output is the same regardless.  I tried reading what the
swift-plot-log does using emacs, but got a little lost.  What I gathered is
something is wrong with karatasks, but I don't know what I'm doing wrong and
how to fix this problem.  Thank you ahead of time.
Sincerely,
Melinda Chin
URL: <http://lists.mcs.anl.gov/pipermail/swift-user/attachments/20090622/da5425c1/attachment.html>
More information about the Swift-user mailing list
