[Swift-user] CFP: Special Issue on Many-Task Computing in the IEEE Transactions on Parallel and Distributed Systems (TPDS) Journal
Ioan Raicu iraicu at cs.uchicago.edu
Mon Jun 22 14:42:42 CDT 2009
Call for Papers
Special Issue on Many-Task Computing on Grids and Supercomputers
http://dsl.cs.uchicago.edu/TPDS_MTC/
The Special Issue on Many-Task Computing (MTC) will provide the scientific community a
dedicated forum, within the prestigious IEEE Transactions on Parallel and Distributed
Systems Journal, for presenting new research, development, and deployment efforts of
loosely coupled large scale applications on large scale clusters, Grids, Supercomputers,
and Cloud Computing infrastructure. MTC, the focus of the special issue, encompasses
loosely coupled applications, which are generally composed of many tasks (both
independent and dependent tasks) to achieve some larger application goal.  This special
issue will cover challenges that can hamper efficiency and utilization in running
applications on large-scale systems, such as local resource manager scalability and
granularity, efficient utilization of the raw hardware, parallel file system contention
and scalability, data management, I/O management, reliability at scale, and application
scalability. We welcome paper submissions on all topics related to MTC on large scale
systems.  For more information on this special issue, please see
http://dsl.cs.uchicago.edu/TPDS_MTC/.
Scope
This special issue will focus on the ability to manage and execute large scale
applications on today's largest clusters, Grids, and Supercomputers. Clusters with tens
of thousands of processor cores are readily available, Grids (i.e. TeraGrid) with a
dozen sites and 100K+ processors, and supercomputers with up to 200K processors (i.e.
IBM BlueGene/L and BlueGene/P, Cray XT5, Sun Constellation), are all now available to
the broader scientific community for open science research. Large clusters and
supercomputers have traditionally been high performance computing (HPC) systems, as
they are efficient at executing tightly coupled parallel jobs within a particular
machine with low-latency interconnects; the applications typically use message passing
interface (MPI) to achieve the needed inter-process communication. On the other hand,
Grids have been the preferred platform for more loosely coupled applications that tend
to be managed and executed through workflow systems, commonly known to fit in the
high-throughput computing (HTC) paradigm.
Many-task computing (MTC) aims to bridge the gap between two computing paradigms, HTC
and HPC. MTC is reminiscent to HTC, but it differs in the emphasis of using many
computing resources over short periods of time to accomplish many computational tasks
(i.e. including both dependent and independent tasks), where the primary metrics are
measured in seconds (e.g. FLOPS, tasks/s, MB/s I/O rates), as opposed to operations
(e.g. jobs) per month. MTC denotes high-performance computations comprising multiple
distinct activities, coupled via file system operations. Tasks may be small or large,
uniprocessor or multiprocessor, compute-intensive or data-intensive. The set of tasks
may be static or dynamic, homogeneous or heterogeneous, loosely coupled or tightly
coupled. The aggregate number of tasks, quantity of computing, and volumes of data may
be extremely large. MTC includes loosely coupled applications that are generally
communication-intensive but not naturally expressed using standard message passing
interface commonly found in HPC, drawing attention to the many computations that are
heterogeneous but not "happily" parallel.
There is more to HPC than tightly coupled MPI, and more to HTC than embarrassingly
parallel long running jobs. Like HPC applications, and science itself, applications
are becoming increasingly complex opening new doors for many opportunities to apply
HPC in new ways if we broaden our perspective. Some applications have just so many
simple tasks that managing them is hard. Applications that operate on or produce
large amounts of data need sophisticated data management in order to scale. There
exist applications that involve many tasks, each composed of tightly coupled MPI
tasks. Loosely coupled applications often have dependencies among tasks, and typically
use files for inter-process communication. Efficient support for these sorts of
applications on existing large scale systems will involve substantial technical
challenges and will have big impact on science.
Today's existing HPC systems are a viable platform to host MTC applications. However,
some challenges arise in large scale applications when run on large scale systems,
which can hamper the efficiency and utilization of these large scale systems.  These
challenges vary from local resource manager scalability and granularity, efficient
utilization of the raw hardware, parallel file system contention and scalability, data
management, I/O management, reliability at scale, application scalability, and
understanding the limitations of the HPC systems in order to identify good candidate
MTC applications. Furthermore, the MTC paradigm can be naturally applied to the emerging
Cloud Computing paradigm due to its loosely coupled nature, which is being adopted by
industry as the next wave of technological advancement to reduce operational costs while
improving efficiencies in large scale infrastructures.
For an interesting discussion in a blog by Ian Foster on the difference between MTC and
HTC, please see his blog athttp://ianfoster.typepad.com/blog/2008/07/many-tasks-comp.html.
The proposed editors also published several papers highly relevant to this special issue.
One paper is titled "Toward Loosely Coupled Programming on Petascale Systems", and was
published in IEEE/ACM Supercomputing 2008 (SC08) Conference; the second paper is titled
"Many-Task Computing for Grids and Supercomputers", which was published in the IEEE
Workshop on Many-Task Computing on Grids and Supercomputers 2008 (MTAGS08). To see last
year's workshop program agenda, and accepted papers and presentations, please see
http://dsl.cs.uchicago.edu/MTAGS08/. To see this year's workshop web site, see
http://dsl.cs.uchicago.edu/MTAGS09/.
Topics
Topics of interest include, but are not limited to:
*	Compute Resource Management in large scale clusters, large Grids, Supercomputers,
         or Cloud Computing infrastructure
	o	Scheduling
	o	Job execution frameworks
	o	Local resource manager extensions
	o	Performance evaluation of resource managers in use on large scale systems
	o	Challenges and opportunities in running many-task workloads on HPC systems
	o	Challenges and opportunities in running many-task workloads on Cloud
*	Data Management in large scale Grid and Supercomputer environments:
	o	Data-Aware Scheduling
	o	Parallel File System performance and scalability in large deployments
	o	Distributed file systems
	o	Data caching frameworks and techniques
*	Large-Scale Workflow Systems
	o	Workflow system performance and scalability analysis
	o	Scalability of workflow systems
	o	Workflow infrastructure and e-Science middleware
	o	Programming Paradigms and Models
*	Large-Scale Many-Task Applications
	o	Large-scale many-task applications
	o	Large-scale many-task data-intensive applications
	o	Large-scale high throughput computing (HTC) applications
	o	Quasi-supercomputing applications, deployments, and experiences
Paper Submission and Publication
Authors are invited to submit papers with unpublished, original work of not more
than 14 pages of double column text using single spaced 9.5 point size on 8.5 x 11 inch
pages and 0.5 inch margins
(http://www2.computer.org/portal/c/document_library/get_file?uuid=02e1509b-5526-4658-afb2-fe8b35044552&groupId=525767).
Papers will be peer-reviewed, and accepted papers will be published in the IEEE digital
library. For more information, please visithttp://dsl.cs.uchicago.edu/TPDS_MTC/.
Important Dates
*	Abstract Due:			December 1st, 2009
*	Papers Due:			December 21st, 2009
*	First Round Decisions:		February 22nd, 2010
*	Major Revisions if needed:	April 19th, 2010
*	Second Round Decisions:		May 24th, 2010
*	Minor Revisions if needed:	June 7th, 2010
*	Final Decision:			June 21st, 2010
*	Publication Date:		November, 2010
Guest Editors and Potential Reviewers
Special Issue Guest Editors
*	Ian Foster, University of Chicago&  Argonne National Laboratory
*	Ioan Raicu, University of Chicago
*	Yong Zhao, Microsoft
More information about the Swift-user mailing list
