[Swift-user] Swift-Plot-Log
Ben Clifford
benc at hawaga.org.uk
Mon Jun 22 16:24:51 CDT 2009
On Mon, 22 Jun 2009, Melinda Chin wrote:
> I was testing out the swift-plot-log command however I was running into some
> troubles. I was using
> http://www.ci.uchicago.edu/swift/guides/log-processing.php as my guide to
thats out of date.
Do this:
put the log file you want to process in a directory that you have write
access to - if you did the run yourself then it will already be in such a
directory. if you are getting the log from the repository, copy it to a
directory of your choice.
inside that direcotry, type:
swift-plog-log whatever.log
where <whatever> is the name of the log file.
More information about the Swift-user
