[Swift-devel] Feature proposal: struct constructors
Tim Armstrong
tim.g.armstrong at gmail.com
Tue Feb 3 16:54:31 CST 2015
Hi All,
While designing a location-aware feature for Swift/T Justin and I came
across a scenario where we wanted to use Swift structs, but where it was
very painful to assign each element individually. To give you an idea:
type foo {
int x;
int y;
foo bar;
bar.x = 1;
bar.y = 2;
I'm looking at adding a feature where we can fill in a structs fields with
a single expression.
We could do them the C-style way, but that doesn't allow us to use them
without defining a new variable (the issue is that {} doesn't specify the
intended type, meaning it needs to come from context):
foo bar = { 1, 2 };
I was thinking that we should just have types function as named
constructor functions. There's precedent both in object-oriented languages
and with Haskell's algebraic data types. Now you can just use this
expression wherever needed:
foo(1, 2)
Thoughts? I'm reluctant to add new incompatibilities with Swift/K, but
this seems like it would be really clunky otherwise.
- Tim
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150203/db933869/attachment.html>
