[Swift-devel] Feature proposal: struct constructors
Justin M Wozniak
wozniak at mcs.anl.gov
Wed Feb 4 10:50:23 CST 2015
There's also this compact style:
foo bar(1,2);
Is it ambiguous? C++ has issues with this.
On 02/03/2015 04:54 PM, Tim Armstrong wrote:
> Hi All,
> While designing a location-aware feature for Swift/T Justin and I
> came across a scenario where we wanted to use Swift structs, but where
> it was very painful to assign each element individually. To give you
> an idea:
> type foo {
> int x;
> int y;
> foo bar;
> bar.x = 1;
> bar.y = 2;
> I'm looking at adding a feature where we can fill in a structs fields
> with a single expression.
> We could do them the C-style way, but that doesn't allow us to use
> them without defining a new variable (the issue is that {} doesn't
> specify the intended type, meaning it needs to come from context):
> foo bar = { 1, 2 };
> I was thinking that we should just have types function as named
> constructor functions. There's precedent both in object-oriented
> languages and with Haskell's algebraic data types. Now you can just
> use this expression wherever needed:
> foo(1, 2)
> Thoughts? I'm reluctant to add new incompatibilities with Swift/K,
> but this seems like it would be really clunky otherwise.
> - Tim
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150204/7e5abf54/attachment.html>
