[Swift-devel] Standard Library, take II
Tim Armstrong tim.g.armstrong at gmail.com
Mon Feb 2 17:30:24 CST 2015
Ah thanks, I didn't do a good job of ctrl-Fing the docs.
- Tim
On Mon, Feb 2, 2015 at 5:26 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> On Mon, 2015-02-02 at 16:56 -0600, Tim Armstrong wrote:
> > Oh I didn't realise there were keyword args in K.  So K supports optional
> > arguments but the caller has to specify them by name, not position?
> Yep. See
> http://swift-lang.org/guides/trunk/userguide/userguide.html#_procedures
> It's even funny at times:
> "...both positional parameter and named parameter passings can be
> passed..."
> Mihael
> > - Tim
> > On Mon, Feb 2, 2015 at 4:18 PM, Mihael Hategan <hategan at mcs.anl.gov>
> wrote:
> > > On Mon, 2015-02-02 at 15:46 -0600, Tim Armstrong wrote:
> > > > I think that sounds good to me.
> > > > I think with overloading, I might attempt to implement overloading
> in the
> > > > generic way (such that it would support user-defined functions), but
> only
> > > > enable it for library functions by default.  This would let us
> experiment
> > > > with it to see how it works, but reduces the possibility of bugs for
> the
> > > > time being.
> > > > I think the keyword arguments needs some discussion.   I was thinking
> > > that
> > > > we'd have optional positional arguments only (like C++).  I think in
> any
> > > > case I'd like to put keyword arguments into the "future" category.
> I'm
> > > > open to discussion but I think we can put that off too.
> > > They are already in K, but noted.
> > > I'm inclined to change most library functions with keyword args (such
> as
> > > substring(str, start, [end =...]) to overloaded ones, since there is no
> > > good reason to write:
> > > s1 = substring(s, 0);
> > > s2 = substring(s, 1, end = 5);
> > > rather than
> > > s2 = substring(s, 1, 5);
> > > I think that, from this perspective, overloading is roughly equivalent
> > > to optional positional arguments.
> > > Mihael
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20150202/749e6246/attachment.html>
