[Swift-devel] ui http error on browser
    Ketan Maheshwari
    ketancmaheshwari at gmail.com
    Tue Sep  3 17:57:08 CDT 2013
Works now, Thanks!
I see summary tab showing graphical output. The other tabs are showing
numbers.
Also, the Graph tab shows tabs garbled on my browser. See attached
screenshot.
Ketan
On Tue, Sep 3, 2013 at 5:27 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> There is a fix in SVN for this.
> The issue was that there was an extra "/" between the path elements.
> I.e.: httpmonitor//index.html.
> I was running this from eclipse and 'resources' was a filesystem
> directory. The lookup went fine. However, when the same path points to
> something in a jar file (as happens in normal swift invocations), the
> lookup fails.
> Mihael
> On Tue, 2013-09-03 at 14:27 -0700, Mihael Hategan wrote:
> > It's in the jar file: httpmonitor/
> > In the source tree it would be in resources/httpmonitor/
> > Mihael
> > On Tue, 2013-09-03 at 15:08 -0500, Ketan Maheshwari wrote:
> > > Mihael,
> > > Which directory does the http serve index.html from?
> > > On Wed, Aug 28, 2013 at 9:41 PM, Ketan Maheshwari <
> > > ketancmaheshwari at gmail.com> wrote:
> > > > Please find attached.
> > > > On Wed, Aug 28, 2013 at 8:50 PM, Mihael Hategan <hategan at mcs.anl.gov
> >wrote:
> > > >> Odd. Can you send me the swift jar file from the dist/[...]/lib dir?
> > > >> Mihael
> > > >> On Wed, 2013-08-28 at 20:35 -0500, Ketan Maheshwari wrote:
> > > >> > Hi Mihael,
> > > >> > I tried with the updated version. The log is attached.
> > > >> > In the browser, I type: localhost:8080
> > > >> > The exact message is same as earlier:
> > > >> > Error: The requested resource is not available (in large fonts)
> > > >> > Thanks,
> > > >> > Ketan
> > > > Ketan
> > > Mihael,
> > >                 dist/[...]/lib dir?
> > >                 Mihael
> > >                 wrote:
> > >                 > Hi Mihael,
> > >                 attached.
> > >                 large fonts)
> > >                 > Thanks,
> > >                 > Ketan
> > >         Ketan
> > > Ketan
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130903/011d8ba6/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20130903/011d8ba6/attachment.png>
