[Swift-devel] ui http error on browser
Mihael Hategan
hategan at mcs.anl.gov
Tue Sep 3 18:44:18 CDT 2013
I noticed those.
I'll remove the text stuff. Was only there for debugging.
The graphs tab should be fine if you click on "+" to add a graph. You
can then move and resize the graph and add data series to it.
Mihael
On Tue, 2013-09-03 at 17:57 -0500, Ketan Maheshwari wrote:
> Works now, Thanks!
> I see summary tab showing graphical output. The other tabs are showing
> numbers.
> Also, the Graph tab shows tabs garbled on my browser. See attached
> screenshot.
> Thanks,
> Ketan
> On Tue, Sep 3, 2013 at 5:27 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> > There is a fix in SVN for this.
> > The issue was that there was an extra "/" between the path elements.
> > I.e.: httpmonitor//index.html.
> > I was running this from eclipse and 'resources' was a filesystem
> > directory. The lookup went fine. However, when the same path points to
> > something in a jar file (as happens in normal swift invocations), the
> > lookup fails.
> > Mihael
> > On Tue, 2013-09-03 at 14:27 -0700, Mihael Hategan wrote:
> > > It's in the jar file: httpmonitor/
> > > In the source tree it would be in resources/httpmonitor/
> > > Mihael
> > > On Tue, 2013-09-03 at 15:08 -0500, Ketan Maheshwari wrote:
> > > > Mihael,
> > > > Which directory does the http serve index.html from?
> > > > On Wed, Aug 28, 2013 at 9:41 PM, Ketan Maheshwari <
> > > > ketancmaheshwari at gmail.com> wrote:
> > > > > Please find attached.
> > > > > On Wed, Aug 28, 2013 at 8:50 PM, Mihael Hategan <hategan at mcs.anl.gov
> > >wrote:
> > > > >> Odd. Can you send me the swift jar file from the dist/[...]/lib dir?
> > > > >> Mihael
> > > > >> On Wed, 2013-08-28 at 20:35 -0500, Ketan Maheshwari wrote:
> > > > >> > Hi Mihael,
> > > > >> > I tried with the updated version. The log is attached.
> > > > >> > In the browser, I type: localhost:8080
> > > > >> > The exact message is same as earlier:
> > > > >> > Error: The requested resource is not available (in large fonts)
> > > > >> > Thanks,
> > > > >> > Ketan
> > > > > Ketan
> > > > Mihael,
> > > > dist/[...]/lib dir?
> > > > Mihael
> > > > wrote:
> > > > > Hi Mihael,
> > > > attached.
> > > > large fonts)
> > > > > Thanks,
> > > > > Ketan
> > > > Ketan
> > > > Ketan
> > > _______________________________________________
> > > Swift-devel mailing list
> > > Swift-devel at ci.uchicago.edu
> > > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Works now, Thanks!
> numbers.
> screenshot.
> Thanks,
> Ketan
> elements.
> filesystem
> points to
> invocations), the
> lookup fails.
> Mihael
> > Mihael
> > > Mihael,
> dist/[...]/lib dir?
> > > >> Mihael
> wrote:
> > > >> > Hi Mihael,
> attached.
> large fonts)
> > > >> > Thanks,
> > > >> > Ketan
> > > > Ketan
> > > Mihael,
> from the
> > > dist/[...]/lib dir?
> > > Mihael
> Maheshwari
> > > wrote:
> > > > Hi Mihael,
> log is
> > > attached.
> available (in
> > > large fonts)
> > > > Thanks,
> > > > Ketan
> > > Ketan
> > > Ketan
> Ketan
