[Swift-devel] ui http error on browser
    Mihael Hategan
    hategan at mcs.anl.gov
    Tue Sep  3 17:27:48 CDT 2013
There is a fix in SVN for this.
The issue was that there was an extra "/" between the path elements.
I.e.: httpmonitor//index.html.
I was running this from eclipse and 'resources' was a filesystem
directory. The lookup went fine. However, when the same path points to
something in a jar file (as happens in normal swift invocations), the
lookup fails.
Mihael
On Tue, 2013-09-03 at 14:27 -0700, Mihael Hategan wrote:
> It's in the jar file: httpmonitor/
> In the source tree it would be in resources/httpmonitor/
> Mihael
> On Tue, 2013-09-03 at 15:08 -0500, Ketan Maheshwari wrote:
> > Mihael,
> > Which directory does the http serve index.html from?
> > On Wed, Aug 28, 2013 at 9:41 PM, Ketan Maheshwari <
> > ketancmaheshwari at gmail.com> wrote:
> > > Please find attached.
> > > On Wed, Aug 28, 2013 at 8:50 PM, Mihael Hategan <hategan at mcs.anl.gov>wrote:
> > >> Odd. Can you send me the swift jar file from the dist/[...]/lib dir?
> > >> Mihael
> > >> On Wed, 2013-08-28 at 20:35 -0500, Ketan Maheshwari wrote:
> > >> > Hi Mihael,
> > >> > I tried with the updated version. The log is attached.
> > >> > In the browser, I type: localhost:8080
> > >> > The exact message is same as earlier:
> > >> > Error: The requested resource is not available (in large fonts)
> > >> > Thanks,
> > >> > Ketan
> > > Ketan
> > Mihael,
> >                 dist/[...]/lib dir?
> >                 Mihael
> >                 wrote:
> >                 > Hi Mihael,
> >                 attached.
> >                 large fonts)
> >                 > Thanks,
> >                 > Ketan
> >         Ketan
> > Ketan
> Swift-devel mailing list
> Swift-devel at ci.uchicago.edu
> https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
