[Swift-devel] resume feature in trunk
Ketan Maheshwari
ketancmaheshwari at gmail.com
Sat Oct 5 18:40:28 CDT 2013
Hi Mihael,
Attached is the simplified version of my script and apps which has the same
resume behavior I reported.
Ketan
On Thu, Oct 3, 2013 at 9:52 PM, Mihael Hategan <hategan at mcs.anl.gov> wrote:
> Yeah, please send me the script or a simplified one. I have been using
> resume for a while, so it's not a general resume issue.
> Mihael
> On Thu, 2013-10-03 at 20:45 -0500, Ketan Maheshwari wrote:
> > Hi,
> > It seems that the resume feature in trunk has some problems.
> > When I try to resume a workflow I am running, I get the following error:
> > $ swift -sites.file sites.gordon.xml -tc.file apps -config cf
> > workflow.swift -resume workflow-20131004-0107-09cxqmd5.0.rlog
> > Swift trunk swift-r7089 cog-r3775 (cog modified locally)
> > RunID: 20131004-0142-7l1ym0y9
> > Progress: time: Fri, 04 Oct 2013 01:42:37 +0000
> > Execution failed:
> > java.lang.IndexOutOfBoundsException: Invalid index [14] for mA_file
> > swift:stageIn @ workflow, line: 347
> > Caused by: java.lang.IndexOutOfBoundsException: Invalid index [14] for
> > mA_file
> > at
> org.griphyn.vdl.mapping.AbstractDataNode.checkNoValue(AbstractDataNode.java:716)
> > at
> org.griphyn.vdl.mapping.AbstractDataNode.waitFor(AbstractDataNode.java:682)
> > at org.griphyn.vdl.karajan.lib.Stagein.function(Stagein.java:81)
> > at
> org.griphyn.vdl.karajan.lib.SwiftFunction.runBody(SwiftFunction.java:108)
> > at
> org.globus.cog.karajan.compiled.nodes.InternalFunction.run(InternalFunction.java:155)
> > at
> org.globus.cog.karajan.compiled.nodes.CompoundNode.runChild(CompoundNode.java:87)
> > at
> org.globus.cog.karajan.compiled.nodes.user.InvocationWrapper.run(InvocationWrapper.java:66)
> > at
> > at
> org.globus.cog.karajan.compiled.nodes.Sequential.run(Sequential.java:22)
> > at
> org.globus.cog.karajan.compiled.nodes.user.Function.runBody(Function.java:99)
> > at
> org.globus.cog.karajan.compiled.nodes.user.InvocationWrapper.runBody(InvocationWrapper.java:245)
> > at
> org.globus.cog.karajan.compiled.nodes.user.InvocationWrapper.run(InvocationWrapper.java:69)
> > at
> > at
> > at
> > at
> org.globus.cog.karajan.compiled.nodes.UParallel$1.run(UParallel.java:68)
> > at k.thr.LWThread.run(LWThread.java:228)
> > at
> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
> > at
> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
> > at java.lang.Thread.run(Thread.java:724)
> > I am trying to reproduce with a simpler example.
> > Thanks,
> > Hi,
> > error:
> > Execution failed:
> > mA_file
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at org.globus.cog.karajan.compiled.nodes.UParallel
> > at
> > at java.util.concurrent.ThreadPoolExecutor
> > Thanks,
> > Ketan
> > _______________________________________________
> > Swift-devel mailing list
> > Swift-devel at ci.uchicago.edu
> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20131005/f426fd1c/attachment.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20131005/f426fd1c/attachment.obj>
Type: text/xml
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20131005/f426fd1c/attachment.xml>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20131005/f426fd1c/attachment-0001.obj>
