[Swift-devel] resume feature in trunk
Ketan Maheshwari ketancmaheshwari at gmail.com
Sat Oct 5 18:41:18 CDT 2013
Attached the dummy apps now.
On Sat, Oct 5, 2013 at 6:40 PM, Ketan Maheshwari <ketancmaheshwari at gmail.com
> wrote:
> Hi Mihael,
> Attached is the simplified version of my script and apps which has the
> same resume behavior I reported.
> Thanks,
> Ketan
> On Thu, Oct 3, 2013 at 9:52 PM, Mihael Hategan <hategan at mcs.anl.gov>wrote:
>> Yeah, please send me the script or a simplified one. I have been using
>> resume for a while, so it's not a general resume issue.
>> Mihael
>> On Thu, 2013-10-03 at 20:45 -0500, Ketan Maheshwari wrote:
>> > Hi,
>> > It seems that the resume feature in trunk has some problems.
>> > When I try to resume a workflow I am running, I get the following error:
>> > $ swift -sites.file sites.gordon.xml -tc.file apps -config cf
>> > workflow.swift -resume workflow-20131004-0107-09cxqmd5.0.rlog
>> > Swift trunk swift-r7089 cog-r3775 (cog modified locally)
>> > RunID: 20131004-0142-7l1ym0y9
>> > Progress:  time: Fri, 04 Oct 2013 01:42:37 +0000
>> > Execution failed:
>> > java.lang.IndexOutOfBoundsException: Invalid index [14] for mA_file
>> > swift:stageIn @ workflow, line: 347
>> > Caused by: java.lang.IndexOutOfBoundsException: Invalid index [14] for
>> > mA_file
>> > at
>> org.griphyn.vdl.mapping.AbstractDataNode.checkNoValue(AbstractDataNode.java:716)
>> > at
>> org.griphyn.vdl.mapping.AbstractDataNode.waitFor(AbstractDataNode.java:682)
>> > at org.griphyn.vdl.karajan.lib.Stagein.function(Stagein.java:81)
>> > at
>> org.griphyn.vdl.karajan.lib.SwiftFunction.runBody(SwiftFunction.java:108)
>> > at
>> org.globus.cog.karajan.compiled.nodes.InternalFunction.run(InternalFunction.java:155)
>> > at
>> org.globus.cog.karajan.compiled.nodes.CompoundNode.runChild(CompoundNode.java:87)
>> > at
>> org.globus.cog.karajan.compiled.nodes.user.InvocationWrapper.run(InvocationWrapper.java:66)
>> > at
>> > at
>> org.globus.cog.karajan.compiled.nodes.Sequential.run(Sequential.java:22)
>> > at
>> org.globus.cog.karajan.compiled.nodes.user.Function.runBody(Function.java:99)
>> > at
>> org.globus.cog.karajan.compiled.nodes.user.InvocationWrapper.runBody(InvocationWrapper.java:245)
>> > at
>> org.globus.cog.karajan.compiled.nodes.user.InvocationWrapper.run(InvocationWrapper.java:69)
>> > at
>> > at
>> > at
>> > at
>> org.globus.cog.karajan.compiled.nodes.UParallel$1.run(UParallel.java:68)
>> > at k.thr.LWThread.run(LWThread.java:228)
>> > at
>> java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
>> > at
>> java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
>> > at java.lang.Thread.run(Thread.java:724)
>> > I am trying to reproduce with a simpler example.
>> > Thanks,
>> > Hi,
>> > error:
>> > Execution failed:
>> > mA_file
>> > at
>> > at
>> > at
>> > at
>> > at
>> > at
>> > at
>> > at
>> > at
>> > at
>> > at
>> > at
>> > at
>> > at
>> > at org.globus.cog.karajan.compiled.nodes.UParallel
>> > at
>> > at java.util.concurrent.ThreadPoolExecutor
>> > Thanks,
>> > Ketan
>> > _______________________________________________
>> > Swift-devel mailing list
>> > Swift-devel at ci.uchicago.edu
>> > https://lists.ci.uchicago.edu/cgi-bin/mailman/listinfo/swift-devel
> Ketan
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20131005/05a6b7f4/attachment.html>
Type: application/x-sh
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20131005/05a6b7f4/attachment.sh>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20131005/05a6b7f4/attachment-0001.sh>
