[Swift-devel] Re: catsn on beagle
    ketan
    ketancmaheshwari at gmail.com
    Sat Jun  4 12:37:05 CDT 2011
Ok, I see that there is this variable in the commandline option that
might be causing the error:
-DGLOBUS_HOSTNAME=login2.beagle.ci.uchicago.edu.(none)
I do not know why there is (none) in your environment.
On 6/4/11 12:26 PM, Jonathan S Monette wrote:
> Same result. Same error
> On Sat, Jun 4, 2011 at 12:24 PM, ketan <ketancmaheshwari at gmail.com
> <mailto:ketancmaheshwari at gmail.com>> wrote:
>     can you try running the commandline by copying from run.sh and
>     pasting it at the prompt.
>     On 6/4/11 12:18 PM, Jonathan S Monette wrote:
>>     I do have that project.  I did projects --avail and got back
>>     Project      PI                      Title
>>     CI-CCR000013 Michael Wilde           The Swift Parallel Scripting
>>     System
>>     Here is my run.sh file.  I execute with ./run.sh after I did
>>     chmod +x run.sh
>>     #!/bin/bash
>>     swift -config cf -tc.file tc -sites.file beagle-coaster.xml
>>     catsn.swift -n=1
>>     I do have sh and cat in my path.  I can execute them.  Here is
>>     what which sh and which cat produced.
>>     sh is /usr/bin/sh
>>     cat is /bin/cat
>>     On Sat, Jun 4, 2011 at 12:10 PM, ketan
>>     <ketancmaheshwari at gmail.com <mailto:ketancmaheshwari at gmail.com>>
>>     wrote:
>>         Can you try "projects --avail" command on beagle to see if
>>         you are member of a project.
>>         Else you will need to request membership. You can do this
>>         from this page:
>>         http://pads.ci.uchicago.edu/access/
>>         In any case, your error does not seem to be because of the
>>         above. Looks like '(' has sneaked in because of some
>>         unexpected typo in commandline .. can you doublecheck it.
>>         Also can you make sure that you have all the files: tc,
>>         beagle-coasters.xml cf in PATH, ie. are you able to access
>>         them w/o ./
>>         On 6/4/11 12:03 PM, Jonathan S Monette wrote:
>>>         I did change the work directory.  I however did not change
>>>         the project name.  I do not know my project name so I kept
>>>         the same project that was in there.  Here is my modified
>>>         beagle-coasters.xml
>>>         <config>
>>>         <pool handle="pbs">
>>>         <execution provider="coaster" jobmanager="local:pbs"/>
>>>         <profile namespace="globus" key="project">CI-CCR000013</profile>
>>>         <profile namespace="globus" key="ppn">24:cray:pack</profile>
>>>         <profile namespace="globus" key="workersPerNode">24</profile>
>>>         <profile namespace="globus" key="maxTime">1000</profile>
>>>         <profile namespace="globus" key="slots">1</profile>
>>>         <profile namespace="globus" key="nodeGranularity">1</profile>
>>>         <profile namespace="globus" key="maxNodes">1</profile>
>>>         <profile namespace="karajan" key="jobThrottle">.63</profile>
>>>         <profile namespace="karajan" key="initialScore">10000</profile>
>>>         <filesystem provider="local"/>
>>>         <workdirectory >/lustre/beagle/jonmon/Swift/work</workdirectory>
>>>         </pool>
>>>         </config>
>>>         On Sat, Jun 4, 2011 at 12:00 PM, Ketan Maheshwari
>>>             Jon,
>>>             Thanks for trying out catsn on Beagle.
>>>             I just tried it myself but could not reproduce the error
>>>             you are getting. Have you made the changes that are
>>>             mentioned in the README:
>>>             Change workdir location in beagle-coaster.xml
>>>             Change the project entry in the beagle-coaster.xml to
>>>             your project name
>>>             Ketan
>>>             On Sat, Jun 4, 2011 at 11:50 AM, Jonathan S Monette
>>>             <jonmon at utexas.edu <mailto:jonmon at utexas.edu>> wrote:
>>>                 Hello,
>>>                    I am trying to run the catsn test on beagle using
>>>                 the files in ~ketan/catsn.  I have copied over this
>>>                 directory over to my home directory and I believe I
>>>                 set it up correctly.  I did module load swift and
>>>                 the ran run.sh that was in this directory.  I get
>>>                 this error.
>>>                 /soft/swift/0.92/bin/swift: eval: line 152: syntax
>>>                 error near unexpected token `('
>>>                 /soft/swift/0.92/bin/swift: eval: line 152: `java
>>>                 -Xmx8192M
>>>                 -Djava.endorsed.dirs=/soft/swift/0.92/bin/../lib/endorsed
>>>                 -DUID=1881
>>>                 -DCOG_INSTALL_PATH=/soft/swift/0.92/bin/..
>>>                 -Dswift.home=/soft/swift/0.92/bin/..
>>>                 -Djava.security.egd=file:///dev/urandom -classpath
>>>                 /soft/swift/0.92/bin/../etc:/soft/swift/0.92/bin/../libexec:/soft/swift/0.92/bin/../lib/addressing-1.0.jar:/soft/swift/0.92/bin/../lib/ant.jar:/soft/swift/0.92/bin/../lib/antlr-2.7.5.jar:/soft/swift/0.92/bin/../lib/axis.jar:/soft/swift/0.92/bin/../lib/axis-url.jar:/soft/swift/0.92/bin/../lib/backport-util-concurrent.jar:/soft/swift/0.92/bin/../lib/castor-0.9.6.jar:/soft/swift/0.92/bin/../lib/coaster-bootstrap.jar:/soft/swift/0.92/bin/../lib/cog-abstraction-common-2.4.jar:/soft/swift/0.92/bin/../lib/cog-axis.jar:/soft/swift/0.92/bin/../lib/cog-grapheditor-0.47.jar:/soft/swift/0.92/bin/../lib/cog-jglobus-1.7.0.jar:/soft/swift/0.92/bin/../lib/cog-karajan-0.36-dev.jar:/soft/swift/0.92/bin/../lib/cog-provider-clref-gt4_0_0.jar:/soft/swift/0.92/bin/../lib/cog-provider-coaster-0.3.jar:/soft/swift/0.92/bin/../lib/cog-provider-dcache-0.1.jar:/soft/swift/0.92/bin/../lib/cog-provider-gt2-2.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-gt4_0_0-2.5.jar:/soft/swift/0.92/bin/../lib/cog-pro
>>>                 vider-local-2.2.jar:/soft/swift/0.92/bin/../lib/cog-provider-localscheduler-0.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-ssh-2.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-webdav-2.1.jar:/soft/swift/0.92/bin/../lib/cog-resources-1.0.jar:/soft/swift/0.92/bin/../lib/cog-swift-svn.jar:/soft/swift/0.92/bin/../lib/cog-trap-1.0.jar:/soft/swift/0.92/bin/../lib/cog-url.jar:/soft/swift/0.92/bin/../lib/cog-util-0.92.jar:/soft/swift/0.92/bin/../lib/commonj.jar:/soft/swift/0.92/bin/../lib/commons-beanutils.jar:/soft/swift/0.92/bin/../lib/commons-collections-3.0.jar:/soft/swift/0.92/bin/../lib/commons-digester.jar:/soft/swift/0.92/bin/../lib/commons-discovery.jar:/soft/swift/0.92/bin/../lib/commons-httpclient.jar:/soft/swift/0.92/bin/../lib/commons-logging-1.1.jar:/soft/swift/0.92/bin/../lib/concurrent.jar:/soft/swift/0.92/bin/../lib/cryptix32.jar:/soft/swift/0.92/bin/../lib/cryptix-asn1.jar:/soft/swift/0.92/bin/../lib/cryptix.jar:/soft/swift/0.92/bin/../lib/globus_delegation_servic
>>>                 e.jar:/soft/swift/0.92/bin/../lib/globus_delegation_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_mds_aggregator_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rendezvous_service.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rendezvous_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rft_stubs.jar:/soft/swift/0.92/bin/../lib/gram-client.jar:/soft/swift/0.92/bin/../lib/gram-stubs.jar:/soft/swift/0.92/bin/../lib/gram-utils.jar:/soft/swift/0.92/bin/../lib/j2ssh-common-0.2.2.jar:/soft/swift/0.92/bin/../lib/j2ssh-core-0.2.2-patch-b.jar:/soft/swift/0.92/bin/../lib/jakarta-regexp-1.2.jar:/soft/swift/0.92/bin/../lib/jakarta-slide-webdavlib-2.0.jar:/soft/swift/0.92/bin/../lib/jaxrpc.jar:/soft/swift/0.92/bin/../lib/jce-jdk13-131.jar:/soft/swift/0.92/bin/../lib/jgss.jar:/soft/swift/0.92/bin/../lib/jline-0.9.94.jar:/soft/swift/0.92/bin/../lib/jsr173_1.0_api.jar:/soft/swift/0.92/bin/../lib/jug-lgpl-2.0.0.jar:/soft/swift/0.92/bin/../lib/junit.jar:/soft/swift/0.92/bin/../lib/log4j-1.2
>>>                 .8.jar:/soft/swift/0.92/bin/../lib/naming-common.jar:/soft/swift/0.92/bin/../lib/naming-factory.jar:/soft/swift/0.92/bin/../lib/naming-java.jar:/soft/swift/0.92/bin/../lib/naming-resources.jar:/soft/swift/0.92/bin/../lib/opensaml.jar:/soft/swift/0.92/bin/../lib/puretls.jar:/soft/swift/0.92/bin/../lib/resolver.jar:/soft/swift/0.92/bin/../lib/saaj.jar:/soft/swift/0.92/bin/../lib/stringtemplate.jar:/soft/swift/0.92/bin/../lib/vdldefinitions.jar:/soft/swift/0.92/bin/../lib/wsdl4j.jar:/soft/swift/0.92/bin/../lib/wsrf_core.jar:/soft/swift/0.92/bin/../lib/wsrf_core_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_mds_index_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_mds_usefulrp_schema_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_provider_jce.jar:/soft/swift/0.92/bin/../lib/wsrf_tools.jar:/soft/swift/0.92/bin/../lib/wss4j.jar:/soft/swift/0.92/bin/../lib/xalan.jar:/soft/swift/0.92/bin/../lib/xbean.jar:/soft/swift/0.92/bin/../lib/xbean_xpath.jar:/soft/swift/0.92/bin/../lib/xercesImpl.jar:/soft
>>>                 /swift/0.92/bin/../lib/xml-apis.jar:/soft/swift/0.92/bin/../lib/xmlsec.jar:/soft/swift/0.92/bin/../lib/xpp3-1.1.3.4d_b4_min.jar:/soft/swift/0.92/bin/../lib/xstream-1.1.1-patched.jar:
>>>                 org.griphyn.vdl.karajan.Loader '-config' 'cf'
>>>                 '-tc.file' 'tc' '-sites.file' 'beagle-coaster.xml'
>>>                 'catsn.swift' '-n=1''
>>>                 I there something else I need to load on beagle to
>>>                 make swift run accordingly?
>>>                 Any intelligent fool can make things bigger and more
>>>                 complex... It takes a touch of genius - and a lot of
>>>                 courage to move in the opposite direction.
>>>                 - Albert Einstein
>>>         complex... It takes a touch of genius - and a lot of courage
>>>         - Albert Einstein
>>     Any intelligent fool can make things bigger and more complex...
>>     It takes a touch of genius - and a lot of courage to move in the
>>     opposite direction.
>>     - Albert Einstein
> Any intelligent fool can make things bigger and more complex... It
> takes a touch of genius - and a lot of courage to move in the opposite
> direction.
> - Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110604/2421752c/attachment.html>
