[Swift-devel] catsn on beagle
Mihael Hategan
hategan at mcs.anl.gov
Tue Jun 7 12:16:46 CDT 2011
On Sat, 2011-06-04 at 11:50 -0500, Jonathan S Monette wrote:
> Hello,
> I am trying to run the catsn test on beagle using the files in
> ~ketan/catsn. I have copied over this directory over to my home
> directory and I believe I set it up correctly. I did module load
> swift and the ran run.sh that was in this directory. I get this
> error.
> /soft/swift/0.92/bin/swift: eval: line 152: syntax error near
> unexpected token `('
> /soft/swift/0.92/bin/swift: eval: line 152: `java -Xmx8192M
> -Djava.endorsed.dirs=/soft/swift/0.92/bin/../lib/endorsed -DUID=1881
> -DGLOBUS_HOSTNAME=login2.beagle.ci.uchicago.edu.(none)
What's the "(none)" in there and where is it coming from?
