[Swift-devel] Re: catsn on beagle
Jonathan S Monette jonmon at utexas.edu
Mon Jun 6 14:30:28 CDT 2011
This fixed it.  I can now run the catsn test script on beagle.  Thanks
Ketan.
On Mon, Jun 6, 2011 at 2:16 PM, ketan <ketancmaheshwari at gmail.com> wrote:
>  Jon,
> Turns out beagle was not properly up and circumstantial evidence indicates
> it was causing the issue that seems now to be resolved (see quoted mesg from
> beagle admins below).
> Could you try it again and report back what you get.
> Thanks,
> Ketan
> The five Beagle storage nodes were found offline this morning.  These nodes provide DSL, GPFS, and NFS via DVS to compute nodes throughout the system.  These nodes have been rebooted and the jobs are running through the scheduler as expected.  We are continuing to investigate why the storage nodes went offline, but users may resume running their jobs at this time
> On 6/5/11 8:17 PM, Jonathan S Monette wrote:
> So you are seeing the same problem?
> On Sun, Jun 5, 2011 at 8:13 PM, ketan <ketancmaheshwari at gmail.com> wrote:
>>  I do not know the reason why you are getting this. The PBS submit throws
>> the following stderr:
>> aprun: Apid 327667: Caught signal Terminated, sending to application
>> Also on my another swift submission I am getting this as PBS submit
>> stderr:
>> [NID 00065] 2011-06-05 19:34:26 distributeControlMsg: Apid 327688 write
>> failure to node 66, 10.128.0.67, port 607, Connection reset by peer
>> I suspect the last maintenance/upgrade of Beagle might have caused this.
>> Ketan
>> On 6/5/11 1:35 PM, Jonathan S Monette wrote:
>> I still have problems running this script.  I does not seem to ever
>> execute.  I get this to stdout
>>  Swift svn swift-r4252 (swift modified locally) cog-r3088 (cog modified
>> locally)
>>  RunID: 20110604-2338-5eik2hbb
>> Progress:
>> Progress:  Submitted:1
>> Canceling job 173155.sdb
>> Canceling job 173182.sdb
>>  I had to C-c the run.  I would check qstat and it would say the job was
>> executing in the development queue but it seems like it never ran.  Also it
>> seems that the coasters job was cancelled twice during the Swift execution.
>> On Sat, Jun 4, 2011 at 1:12 PM, Jonathan S Monette <jonmon at utexas.edu>wrote:
>>> Ok.  Thanks.  and the (none) also appeared when I was on
>>> login1.beagle.ci.uchicago.edu.  Thanks Ketan.
>>>  On Sat, Jun 4, 2011 at 1:09 PM, ketan <ketancmaheshwari at gmail.com>wrote:
>>>>  Yes, you should bring this to the attention of beagle sysadmins.
>>>> On 6/4/11 1:01 PM, Jonathan S Monette wrote:
>>>> Ok.  I have my job submitted and it is currently waiting in the queue.
>>>>  besides manually resetting this variable everytime I am on beagle what else
>>>> can be done?  Is this something that I should bring to the attention of the
>>>> sys admins for beagle?
>>>> On Sat, Jun 4, 2011 at 12:51 PM, Ketan Maheshwari <
>>>>> Alright, so this is the issue. GLOBUS_HOSTNAME is picked up from
>>>>> HOSTNAME and I do not know where does this none comes in your case.
>>>>> In my case I get hostname: login2.beagle.ci.uchicago.edu
>>>>> see if you can manually change this env variable and try to run again.
>>>>> On Sat, Jun 4, 2011 at 12:49 PM, Jonathan S Monette <jonmon at utexas.edu
>>>>> > wrote:
>>>>>> login2.beagle.ci.uchicago.edu.(none)
>>>>>>  when you ran your test was in on login1 or login2?
>>>>>> On Sat, Jun 4, 2011 at 12:47 PM, Ketan Maheshwari <
>>>>>>> What does
>>>>>>> echo $HOSTNAME give?
>>>>>>> On Sat, Jun 4, 2011 at 12:44 PM, Jonathan S Monette <
>>>>>>> jonmon at utexas.edu> wrote:
>>>>>>>> I am not sure why that (none) appears.  Is this a variable that the
>>>>>>>> system sets or do I need to set it?
>>>>>>>> On Sat, Jun 4, 2011 at 12:39 PM, Ketan Maheshwari <
>>>>>>>>> This suprises me because, I do not see that (none) in my
>>>>>>>>> commandline.
>>>>>>>>>  On Sat, Jun 4, 2011 at 12:38 PM, Jonathan S Monette <
>>>>>>>>>> I added
>>>>>>>>>> echo ${OPTIONS}
>>>>>>>>>>     echo ${COG_OPTS}
>>>>>>>>>>     echo ${LOCALCLASSPATH}
>>>>>>>>>>     echo ${EXEC}
>>>>>>>>>>     echo ${CMDLINE}
>>>>>>>>>>  to the script.  It seems in the $OPTIONS variable this appears.
>>>>>>>>>>  -Xmx8192M
>>>>>>>>>> -Djava.endorsed.dirs=/home/jonmon/Library/Swift/swift-0.92/bin/../lib/endorsed
>>>>>>>>>> -DUID=1881 -DGLOBUS_HOSTNAME=login2.beagle.ci.uchicago.edu.(none)
>>>>>>>>>> -DCOG_INSTALL_PATH=/home/jonmon/Library/Swift/swift-0.92/bin/..
>>>>>>>>>> -Dswift.home=/home/jonmon/Library/Swift/swift-0.92/bin/..
>>>>>>>>>> -Djava.security.egd=file:///dev/urandom
>>>>>>>>>>  There is the line
>>>>>>>>>> DGLOBUS_HOSTNAME=login2.beagle.ci.uchicago.edu.(none)  I believe that is the
>>>>>>>>>> parenthesis that is causing this to fail.  Now How do I fix it.
>>>>>>>>>> On Sat, Jun 4, 2011 at 12:36 PM, Jonathan S Monette <
>>>>>>>>>>> I may have found the error.  I download 0.92 binaries and changed
>>>>>>>>>>> the swift command script.  I added
>>>>>>>>>>> On Sat, Jun 4, 2011 at 12:26 PM, Jonathan S Monette <
>>>>>>>>>>>> Same result. Same error
>>>>>>>>>>>> On Sat, Jun 4, 2011 at 12:24 PM, ketan <
>>>>>>>>>>>>>  can you try running the commandline by copying from run.sh and
>>>>>>>>>>>>> pasting it at the prompt.
>>>>>>>>>>>>> On 6/4/11 12:18 PM, Jonathan S Monette wrote:
>>>>>>>>>>>>> I do have that project.  I did projects --avail and got back
>>>>>>>>>>>>>  Project      PI                      Title
>>>>>>>>>>>>> CI-CCR000013 Michael Wilde           The Swift Parallel
>>>>>>>>>>>>> Scripting System
>>>>>>>>>>>>>  Here is my run.sh file.  I execute with ./run.sh after I did
>>>>>>>>>>>>> chmod +x run.sh
>>>>>>>>>>>>>  #!/bin/bash
>>>>>>>>>>>>> swift -config cf -tc.file tc -sites.file beagle-coaster.xml
>>>>>>>>>>>>> catsn.swift -n=1
>>>>>>>>>>>>>  I do have sh and cat in my path.  I can execute them.  Here
>>>>>>>>>>>>> is what which sh and which cat produced.
>>>>>>>>>>>>>  sh is /usr/bin/sh
>>>>>>>>>>>>> cat is /bin/cat
>>>>>>>>>>>>> On Sat, Jun 4, 2011 at 12:10 PM, ketan <
>>>>>>>>>>>>>>  Can you try "projects --avail" command on beagle to see if
>>>>>>>>>>>>>> you are member of a project.
>>>>>>>>>>>>>> Else you will need to request membership. You can do this from
>>>>>>>>>>>>>> this page:
>>>>>>>>>>>>>> http://pads.ci.uchicago.edu/access/
>>>>>>>>>>>>>> In any case, your error does not seem to be because of the
>>>>>>>>>>>>>> above. Looks like '(' has sneaked in because of some unexpected typo in
>>>>>>>>>>>>>> commandline .. can you doublecheck it.
>>>>>>>>>>>>>> Also can you make sure that you have all the files: tc,
>>>>>>>>>>>>>> beagle-coasters.xml cf in PATH, ie. are you able to access them w/o ./
>>>>>>>>>>>>>> On 6/4/11 12:03 PM, Jonathan S Monette wrote:
>>>>>>>>>>>>>>  I did change the work directory.  I however did not change
>>>>>>>>>>>>>> the project name.  I do not know my project name so I kept the same project
>>>>>>>>>>>>>> that was in there.  Here is my modified beagle-coasters.xml
>>>>>>>>>>>>>>    <config>
>>>>>>>>>>>>>>   <pool handle="pbs">
>>>>>>>>>>>>>>     <execution provider="coaster" jobmanager="local:pbs"/>
>>>>>>>>>>>>>>     <profile namespace="globus"
>>>>>>>>>>>>>> key="project">CI-CCR000013</profile>
>>>>>>>>>>>>>> key="ppn">24:cray:pack</profile>
>>>>>>>>>>>>>> key="workersPerNode">24</profile>
>>>>>>>>>>>>>>     <profile namespace="globus" key="maxTime">1000</profile>
>>>>>>>>>>>>>>     <profile namespace="globus" key="slots">1</profile>
>>>>>>>>>>>>>> key="nodeGranularity">1</profile>
>>>>>>>>>>>>>>     <profile namespace="globus" key="maxNodes">1</profile>
>>>>>>>>>>>>>>      <profile namespace="karajan"
>>>>>>>>>>>>>> key="jobThrottle">.63</profile>
>>>>>>>>>>>>>> key="initialScore">10000</profile>
>>>>>>>>>>>>>>      <filesystem provider="local"/>
>>>>>>>>>>>>>>     <workdirectory
>>>>>>>>>>>>>> >/lustre/beagle/jonmon/Swift/work</workdirectory>
>>>>>>>>>>>>>>   </pool>
>>>>>>>>>>>>>> </config>
>>>>>>>>>>>>>>   On Sat, Jun 4, 2011 at 12:00 PM, Ketan Maheshwari <
>>>>>>>>>>>>>>>  Jon,
>>>>>>>>>>>>>>> Thanks for trying out catsn on Beagle.
>>>>>>>>>>>>>>> I just tried it myself but could not reproduce the error you
>>>>>>>>>>>>>>> are getting. Have you made the changes that are mentioned in the README:
>>>>>>>>>>>>>>> Change workdir location in beagle-coaster.xml
>>>>>>>>>>>>>>> Change the project entry in the beagle-coaster.xml to your
>>>>>>>>>>>>>>> project name
>>>>>>>>>>>>>>> Ketan
>>>>>>>>>>>>>>>  On Sat, Jun 4, 2011 at 11:50 AM, Jonathan S Monette <
>>>>>>>>>>>>>>>>  Hello,
>>>>>>>>>>>>>>>>    I am trying to run the catsn test on beagle using the
>>>>>>>>>>>>>>>> files in ~ketan/catsn.  I have copied over this directory over to my home
>>>>>>>>>>>>>>>> directory and I believe I set it up correctly.  I did module load swift and
>>>>>>>>>>>>>>>> the ran run.sh that was in this directory.  I get this error.
>>>>>>>>>>>>>>>>    /soft/swift/0.92/bin/swift: eval: line 152: syntax error
>>>>>>>>>>>>>>>> near unexpected token `('
>>>>>>>>>>>>>>>>  /soft/swift/0.92/bin/swift: eval: line 152: `java
>>>>>>>>>>>>>>>> -Xmx8192M -Djava.endorsed.dirs=/soft/swift/0.92/bin/../lib/endorsed
>>>>>>>>>>>>>>>> -DCOG_INSTALL_PATH=/soft/swift/0.92/bin/..
>>>>>>>>>>>>>>>> -Dswift.home=/soft/swift/0.92/bin/.. -Djava.security.egd=
>>>>>>>>>>>>>>>> file:///dev/urandom -classpath
>>>>>>>>>>>>>>>> /soft/swift/0.92/bin/../etc:/soft/swift/0.92/bin/../libexec:/soft/swift/0.92/bin/../lib/addressing-1.0.jar:/soft/swift/0.92/bin/../lib/ant.jar:/soft/swift/0.92/bin/../lib/antlr-2.7.5.jar:/soft/swift/0.92/bin/../lib/axis.jar:/soft/swift/0.92/bin/../lib/axis-url.jar:/soft/swift/0.92/bin/../lib/backport-util-concurrent.jar:/soft/swift/0.92/bin/../lib/castor-0.9.6.jar:/soft/swift/0.92/bin/../lib/coaster-bootstrap.jar:/soft/swift/0.92/bin/../lib/cog-abstraction-common-2.4.jar:/soft/swift/0.92/bin/../lib/cog-axis.jar:/soft/swift/0.92/bin/../lib/cog-grapheditor-0.47.jar:/soft/swift/0.92/bin/../lib/cog-jglobus-1.7.0.jar:/soft/swift/0.92/bin/../lib/cog-karajan-0.36-dev.jar:/soft/swift/0.92/bin/../lib/cog-provider-clref-gt4_0_0.jar:/soft/swift/0.92/bin/../lib/cog-provider-coaster-0.3.jar:/soft/swift/0.92/bin/../lib/cog-provider-dcache-0.1.jar:/soft/swift/0.92/bin/../lib/cog-provider-gt2-2.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-gt4_0_0-2.5.jar:/soft/swift/0.92/bin/../lib/cog-pro
>>>>>>>>>>>>>>>> vider-local-2.2.jar:/soft/swift/0.92/bin/../lib/cog-provider-localscheduler-0.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-ssh-2.4.jar:/soft/swift/0.92/bin/../lib/cog-provider-webdav-2.1.jar:/soft/swift/0.92/bin/../lib/cog-resources-1.0.jar:/soft/swift/0.92/bin/../lib/cog-swift-svn.jar:/soft/swift/0.92/bin/../lib/cog-trap-1.0.jar:/soft/swift/0.92/bin/../lib/cog-url.jar:/soft/swift/0.92/bin/../lib/cog-util-0.92.jar:/soft/swift/0.92/bin/../lib/commonj.jar:/soft/swift/0.92/bin/../lib/commons-beanutils.jar:/soft/swift/0.92/bin/../lib/commons-collections-3.0.jar:/soft/swift/0.92/bin/../lib/commons-digester.jar:/soft/swift/0.92/bin/../lib/commons-discovery.jar:/soft/swift/0.92/bin/../lib/commons-httpclient.jar:/soft/swift/0.92/bin/../lib/commons-logging-1.1.jar:/soft/swift/0.92/bin/../lib/concurrent.jar:/soft/swift/0.92/bin/../lib/cryptix32.jar:/soft/swift/0.92/bin/../lib/cryptix-asn1.jar:/soft/swift/0.92/bin/../lib/cryptix.jar:/soft/swift/0.92/bin/../lib/globus_delegation_servic
>>>>>>>>>>>>>>>> e.jar:/soft/swift/0.92/bin/../lib/globus_delegation_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_mds_aggregator_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rendezvous_service.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rendezvous_stubs.jar:/soft/swift/0.92/bin/../lib/globus_wsrf_rft_stubs.jar:/soft/swift/0.92/bin/../lib/gram-client.jar:/soft/swift/0.92/bin/../lib/gram-stubs.jar:/soft/swift/0.92/bin/../lib/gram-utils.jar:/soft/swift/0.92/bin/../lib/j2ssh-common-0.2.2.jar:/soft/swift/0.92/bin/../lib/j2ssh-core-0.2.2-patch-b.jar:/soft/swift/0.92/bin/../lib/jakarta-regexp-1.2.jar:/soft/swift/0.92/bin/../lib/jakarta-slide-webdavlib-2.0.jar:/soft/swift/0.92/bin/../lib/jaxrpc.jar:/soft/swift/0.92/bin/../lib/jce-jdk13-131.jar:/soft/swift/0.92/bin/../lib/jgss.jar:/soft/swift/0.92/bin/../lib/jline-0.9.94.jar:/soft/swift/0.92/bin/../lib/jsr173_1.0_api.jar:/soft/swift/0.92/bin/../lib/jug-lgpl-2.0.0.jar:/soft/swift/0.92/bin/../lib/junit.jar:/soft/swift/0.92/bin/../lib/log4j-1.2
>>>>>>>>>>>>>>>> .8.jar:/soft/swift/0.92/bin/../lib/naming-common.jar:/soft/swift/0.92/bin/../lib/naming-factory.jar:/soft/swift/0.92/bin/../lib/naming-java.jar:/soft/swift/0.92/bin/../lib/naming-resources.jar:/soft/swift/0.92/bin/../lib/opensaml.jar:/soft/swift/0.92/bin/../lib/puretls.jar:/soft/swift/0.92/bin/../lib/resolver.jar:/soft/swift/0.92/bin/../lib/saaj.jar:/soft/swift/0.92/bin/../lib/stringtemplate.jar:/soft/swift/0.92/bin/../lib/vdldefinitions.jar:/soft/swift/0.92/bin/../lib/wsdl4j.jar:/soft/swift/0.92/bin/../lib/wsrf_core.jar:/soft/swift/0.92/bin/../lib/wsrf_core_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_mds_index_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_mds_usefulrp_schema_stubs.jar:/soft/swift/0.92/bin/../lib/wsrf_provider_jce.jar:/soft/swift/0.92/bin/../lib/wsrf_tools.jar:/soft/swift/0.92/bin/../lib/wss4j.jar:/soft/swift/0.92/bin/../lib/xalan.jar:/soft/swift/0.92/bin/../lib/xbean.jar:/soft/swift/0.92/bin/../lib/xbean_xpath.jar:/soft/swift/0.92/bin/../lib/xercesImpl.jar:/soft
>>>>>>>>>>>>>>>> /swift/0.92/bin/../lib/xml-apis.jar:/soft/swift/0.92/bin/../lib/xmlsec.jar:/soft/swift/0.92/bin/../lib/xpp3-1.1.3.4d_b4_min.jar:/soft/swift/0.92/bin/../lib/xstream-1.1.1-patched.jar:
>>>>>>>>>>>>>>>> org.griphyn.vdl.karajan.Loader '-config' 'cf' '-tc.file' 'tc' '-sites.file'
>>>>>>>>>>>>>>>> 'beagle-coaster.xml' 'catsn.swift' '-n=1''
>>>>>>>>>>>>>>>>  I there something else I need to load on beagle to make
>>>>>>>>>>>>>>>> swift run accordingly?
>>>>>>>>>>>>>>>> Any intelligent fool can make things bigger and more
>>>>>>>>>>>>>>>> complex... It takes a touch of genius - and a lot of courage to move in the
>>>>>>>>>>>>>>>> opposite direction.
>>>>>>>>>>>>>>>> - Albert Einstein
>>>>>>>>>>>>>> opposite direction.
>>>>>>>>>>>>>> - Albert Einstein
>>>>>>>>>>>>> Any intelligent fool can make things bigger and more complex...
>>>>>>>>>>>>> It takes a touch of genius - and a lot of courage to move in the opposite
>>>>>>>>>>>>> direction.
>>>>>>>>>>>>> - Albert Einstein
>>>>>>>>>>>> direction.
>>>>>>>>>>>> - Albert Einstein
>>>>>>>>>>> direction.
>>>>>>>>>>> - Albert Einstein
>>>>>>>>>> Any intelligent fool can make things bigger and more complex... It
>>>>>>>>>> direction.
>>>>>>>>>> - Albert Einstein
>>>>>>>> direction.
>>>>>>>> - Albert Einstein
>>>>>> direction.
>>>>>> - Albert Einstein
>>>> Any intelligent fool can make things bigger and more complex... It takes
>>>> a touch of genius - and a lot of courage to move in the opposite direction.
>>>> - Albert Einstein
>>> - Albert Einstein
>> Any intelligent fool can make things bigger and more complex... It takes a
>> - Albert Einstein
> - Albert Einstein
- Albert Einstein
URL: <http://lists.mcs.anl.gov/pipermail/swift-devel/attachments/20110606/11e40e2c/attachment.html>
