[petsc-users] Trouble when viewing a subDM in vtk format
Matthew Knepley
knepley at gmail.com
Tue Dec 2 08:02:18 CST 2025
On Mon, Dec 1, 2025 at 8:22 AM Aldo Bonfiglioli <aldo.bonfiglioli at unibas.it>
wrote:
> Dear developers,
> I wrote a code that extracts subDMs corresponding to the various strata
> in the Face Sets.
> I run into troubles when I view a subDM or a Vec attached to the subDM
> using the VTK format.
> More precisely, the problem only occurs on more than one processor when
> the rank=0 processor has no points on a given subDM.
> For instance, when the attached reproducer is run on 2 procs, the
> u_01.vtu file (global u Vec mapped to the subDM corresponding to stratum=1)
> only includes the header, but no data. All other u_0?.vtu files can
> successfully be loaded and viewed in paraview.
> The problem does NOT arise when I view the same objects in HDF5 format.
> However, my problem in using the HDF5 lies in the fact that:
> while the hdf5 file obtained with DMView can be post-processed with
> "petsc/lib/petsc/bin/petsc_gen_xdmf.py" to create a xmf file readable by
> paraview
Hi Aldo,
Sorry about this, I would like to make it more intuitive. First, the
solution (I think)
-dm_plex_view_hdf5_storage_version 1.1.0
will write the Viz field by default, so that PAraview will see it. Can you
try this?
Why do we need this? I have now made version-controlled output formats.
There is something about
this in the manual, but not enough. Paraview only supports vertex-based
fields and cell-based fields
(at least that I understand), so we need to write a separate copy of the
field (since Plex supports any
layout). Lots of people do not want a separate copy, since they are
checkpointing, so we control this
with a format (PETSC_VIEWER_HDF5_VIZ). You can pass this for specific
output, or use the format
version that does it automatically.
Let me know if this works.
Matt
> I do not know how to view the field(s) associated with the DM when the
> hdf5 file is obtained from VecView.
> The reproducer compiles with the latest petsc release.
> Thanks,
> Aldo
> Dr. Aldo Bonfiglioli
> Associate professor of Fluid Mechanics
> Dipartimento di Ingegneria
> Universita' della Basilicata
> V.le dell'Ateneo Lucano, 10 85100 Potenza ITALY
> tel:+39.0971.205203 fax:+39.0971.205215
> web:
> https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!eXE2csxUb1J5bnRosf9LIGxLs17TdstMxQcGs0mbXFroRjzLN81jVmeAWfMr41X8JGEuVm286lVTmDgmi5s1zfsfegJNuWVVWTM$
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!f1RvXE2KMeUsh5sgUBZzIIBhluwlYswPKT9rJ68dK6QgBnEwc3sSJnMK0IaiZzswk8NZNJjy-jh0mT2gw3zP$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!f1RvXE2KMeUsh5sgUBZzIIBhluwlYswPKT9rJ68dK6QgBnEwc3sSJnMK0IaiZzswk8NZNJjy-jh0mdAuSKFQ$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251202/6fc759ff/attachment.html>
