[petsc-users] Trouble when viewing a subDM in vtk format
Aldo Bonfiglioli
aldo.bonfiglioli at unibas.it
Mon Dec 15 02:43:45 CST 2025
On 12/2/25 15:02, Matthew Knepley wrote:
> On Mon, Dec 1, 2025 at 8:22 AM Aldo Bonfiglioli
> <aldo.bonfiglioli at unibas.it> wrote:
> Dear developers,
> I wrote a code that extracts subDMs corresponding to the various
> strata
> in the Face Sets.
> I run into troubles when I view a subDM or a Vec attached to the
> subDM
> using the VTK format.
> More precisely, the problem only occurs on more than one processor
> when
> the rank=0 processor has no points on a given subDM.
> For instance, when the attached reproducer is run on 2 procs, the
> u_01.vtu file (global u Vec mapped to the subDM corresponding to
> stratum=1)
> only includes the header, but no data. All other u_0?.vtu files can
> successfully be loaded and viewed in paraview.
> The problem does NOT arise when I view the same objects in HDF5
> format.
> However, my problem in using the HDF5 lies in the fact that:
> while the hdf5 file obtained with DMView can be post-processed with
> "petsc/lib/petsc/bin/petsc_gen_xdmf.py" to create a xmf file
> readable by
> paraview
> Hi Aldo,
> Sorry about this, I would like to make it more intuitive. First, the
> solution (I think)
> -dm_plex_view_hdf5_storage_version 1.1.0
> will write the Viz field by default, so that PAraview will see it. Can
> you try this?
> Why do we need this? I have now made version-controlled output
> formats. There is something about
> this in the manual, but not enough. Paraview only supports
> vertex-based fields and cell-based fields
> (at least that I understand), so we need to write a separate copy of
> the field (since Plex supports any
> layout). Lots of people do not want a separate copy, since they are
> checkpointing, so we control this
> with a format (PETSC_VIEWER_HDF5_VIZ). You can pass this for specific
> output, or use the format
> version that does it automatically.
> Let me know if this works.
> Thanks,
> Matt
> I do not know how to view the field(s) associated with the DM when
> the
> hdf5 file is obtained from VecView.
> The reproducer compiles with the latest petsc release.
> Thanks,
> Aldo
> Dr. Aldo Bonfiglioli
> Associate professor of Fluid Mechanics
> Dipartimento di Ingegneria
> Universita' della Basilicata
> V.le dell'Ateneo Lucano, 10 85100 Potenza ITALY
> tel:+39.0971.205203 fax:+39.0971.205215
> web:
> https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!eXE2csxUb1J5bnRosf9LIGxLs17TdstMxQcGs0mbXFroRjzLN81jVmeAWfMr41X8JGEuVm286lVTmDgmi5s1zfsfegJNuWVVWTM$
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Zla-FYPeT9khxXRG5MuCbh6NLunsaK0ljFdIlNk-3XDnbGEJPBARoshmLdtN7p3kHgPJbQDyNgvHIi-GT6IyAxxdaZ2jTWw_kEg$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Zla-FYPeT9khxXRG5MuCbh6NLunsaK0ljFdIlNk-3XDnbGEJPBARoshmLdtN7p3kHgPJbQDyNgvHIi-GT6IyAxxdaZ2jObGUdDk$ >
Matt,
use of the option "-dm_plex_view_hdf5_storage_version 1.1.0" is indeed
necessary,
but I also realized, thanks to a suggestion from
matteo.semplice at uninsubria.it, that I have to View BOTH the dm and vec
in the same hdf5 file, i.e.
> ! dump the dm+u to the same HDF5 file
> filename ="test.h5"
> PetscCall(PetscViewerHDF5Open(PETSC_COMM_WORLD, trim(filename),
> FILE_MODE_WRITE, viewer, ierr))
> PetscCall(DMView(dm, viewer, ierr))
> PetscCall(PetscViewerDestroy(viewer, ierr))
> FILE_MODE_APPEND, viewer, ierr))
> PetscCall(VecView(u, viewer, ierr))
Once test.h5 has been processed with "petsc_gen_xdmf.py", I can load the
xmf file in paraview e see the solution (there is NO solution unless
-dm_plex_view_hdf5_storage_version 1.1.0 is in the options db).
I was probably misled by the fact that a single VecView in VTK format
gives both the mesh and solution in the same file.
Does this make sense?
Final question:
is it possible to specify, using command line options or the options db,
that vecview should be appended to an existing file?
Aldo
web:https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!Zla-FYPeT9khxXRG5MuCbh6NLunsaK0ljFdIlNk-3XDnbGEJPBARoshmLdtN7p3kHgPJbQDyNgvHIi-GT6IyAxxdaZ2jJl4AAbM$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251215/3a8c67f3/attachment.html>
