[petsc-users] Trouble when viewing a subDM in vtk format
Aldo Bonfiglioli aldo.bonfiglioli at unibas.it
Mon Dec 1 07:22:21 CST 2025
Dear developers,
I wrote a code that extracts subDMs corresponding to the various strata
in the Face Sets.
I run into troubles when I view a subDM or a Vec attached to the subDM
using the VTK format.
More precisely, the problem only occurs on more than one processor when
the rank=0 processor has no points on a given subDM.
For instance, when the attached reproducer is run on 2 procs, the
u_01.vtu file (global u Vec mapped to the subDM corresponding to stratum=1)
only includes the header, but no data. All other u_0?.vtu files can
successfully be loaded and viewed in paraview.
The problem does NOT arise when I view the same objects in HDF5 format.
However, my problem in using the HDF5 lies in the fact that:
while the hdf5 file obtained with DMView can be post-processed with
"petsc/lib/petsc/bin/petsc_gen_xdmf.py" to create a xmf file readable by
paraview
I do not know how to view the field(s) associated with the DM when the
hdf5 file is obtained from VecView.
The reproducer compiles with the latest petsc release.
Aldo
Dr. Aldo Bonfiglioli
Associate professor of Fluid Mechanics
Dipartimento di Ingegneria
Universita' della Basilicata
V.le dell'Ateneo Lucano, 10 85100 Potenza ITALY
tel:+39.0971.205203 fax:+39.0971.205215
web: https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!eXE2csxUb1J5bnRosf9LIGxLs17TdstMxQcGs0mbXFroRjzLN81jVmeAWfMr41X8JGEuVm286lVTmDgmi5s1zfsfegJNuWVVWTM$
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251201/aeae59e0/attachment-0001.bin>
-dm_plex_dim 3
-dm_plex_shape box
-dm_plex_box_faces 20,20,20
-dm_plex_box_lower 0.,0.,0.
-dm_plex_box_upper 1.,1.,1.
##-dm_plex_filename cube6.msh
##-dm_plex_simplex false
-dm_plex_simplex true
-dm_plex_interpolate
##-dm_plex_check_all
##-dm_plex_filename /home/abonfi/grids/3D/MASA_ns3d/unnested/cube1/cube1.msh
# read a solution from an existing file
#-viewer_type hdf5
#-viewer_format vtk
#-viewer_filename /home/abonfi/testcases/3D/scalar/advdiff/hiro/DMPlex/Re100/cube0/u.h5
##-viewer_binary_filename /home/abonfi/testcases/3D/scalar/advdiff/hiro/DMPlex/Re100/cube1/sol.bin
# and write it to u.*
###-vec_view hdf5:u.h5
-vec_view vtk:u.vtu
## I can read both mesh.h5 and mesh.vtu in paraview
-dm_view hdf5:mesh.h5
##-dm_view vtk:mesh.vtu
# uncomment the following to write each boundary patch separately in an HDF5 file
# works both serial and parallel
-patch_01_dm_view hdf5:patch_01.h5
-patch_02_dm_view hdf5:patch_02.h5
-patch_03_dm_view hdf5:patch_03.h5
-patch_04_dm_view hdf5:patch_04.h5
-patch_05_dm_view hdf5:patch_05.h5
-patch_06_dm_view hdf5:patch_06.h5
# uncomment the following to write each boundary patch separately in a VTK file
# it work on one processor, but fails whenever the rank=0 processor has no points
# on a given submesh
#-patch_01_dm_view vtk:patch_01.vtu
#-patch_02_dm_view vtk:patch_02.vtu
#-patch_03_dm_view vtk:patch_03.vtu
#-patch_04_dm_view vtk:patch_04.vtu
#-patch_05_dm_view vtk:patch_05.vtu
#-patch_06_dm_view vtk:patch_06.vtu
##-dm_plex_view_labels "marker"
##-dm_plex_view_labels "Face Sets"
-petscpartitioner_view
####-dm_petscsection_view
-options_left
