[petsc-users] Vec Ownership ranges with Global Section Offsets
Matthew Knepley
knepley at gmail.com
Fri Jan 6 10:37:03 CST 2023
On Fri, Jan 6, 2023 at 11:32 AM Nicholas Arnold-Medabalimi <
narnoldm at umich.edu> wrote:
> Hi Matt
> This was generated using the DMPlexDistributeField which we discussed a
> while back. Everything seemed to be working fine when I only had cells dofs
> but I recently added face dofs, which seems to have caused some issues.
> Whats weird is that I'm feeding the same distribution SF and inputting a
> vector and section that are consistent to the DMPlexDistributeField so I'd
> expect the vectors and section output to be consistent. I'll take a closer
> look at that.
The way I use DistributeField(), for example to distribute coordinates, is
that I give it the migrationSF, the local coordinate section, and the local
coordinate vector. It gives me back the new local coordinate section (which
I set into the distributed DM), and the local coordinate vector. It seems
like you are doing something else. Maybe the documentation is misleading.
Matt
> Thanks
> Nicholas
> On Fri, Jan 6, 2023 at 10:59 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Jan 6, 2023 at 10:41 AM Nicholas Arnold-Medabalimi <
>>> Hi Matt
>>> I appreciate the help. The section view is quite extensive because each
>>> cell has 55 dofs located at the cells and on certain faces. I've appended
>>> the first of these which corresponds with the output in the first email, to
>>> save space. The following 54 are exactly the same but offset incremented by
>>> 1. (or negative 1 for negative offsets)
>> Okay, from the output it is clear that this vector does not match your
>> global section. Did you get stateVec by calling DMCreateGlobalVector()?
>> Thanks,
>> Matt
>>> Thanks for your time
>>> Nicholas
>>> On Fri, Jan 6, 2023 at 10:23 AM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Fri, Jan 6, 2023 at 10:10 AM Nicholas Arnold-Medabalimi <
>>>>> Hi Matt
>>>>> I apologize for any lack of clarity in the initial email.
>>>>> looking at the initial output on rank 1
>>>>> write(*,*) "cell",i,"offset",offset,'oStart',oStart, offset-oStart
>>>>> cell 0 offset 2475 oStart 2640 -165
>>>>> cell 1 offset 2530 oStart 2640 -110
>>>>> cell 2 offset 2585 oStart 2640 -55
>>>>> cell 3 offset 2640 oStart 2640 0
>>>>> cell 15 offset -771 oStart 2640 -3411
>>>>> cell 15 provides a negative offset because it is the overlap cell
>>>>> (that is unowned)
>>>>> The remained of cells are all owned. However, the first 3 cells
>>>>> (0,1,2) return an offset that is less than the starting ownership range. I
>>>>> would expect cell 0 to start at offset 2640 at minimum.
>>>> Send the output for this section
>>>> call PetscSectionView(section, PETSC_VIEWER_STDOUT_WORLD);
>>>> Thanks,
>>>> Matt
>>>>> Sincerely
>>>>> Nicholas
>>>>> On Fri, Jan 6, 2023 at 10:05 AM Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>>> On Fri, Jan 6, 2023 at 9:56 AM Nicholas Arnold-Medabalimi <
>>>>>>> Apologies. If it helps, there is one cell of overlap in this small
>>>>>>> test case for a 2D mesh that is 1 cell in height and a number of cells in
>>>>>>> length. .
>>>>>>> process 0
>>>>>>> Petsc VecGetLocalSize 2750
>>>>>>> size(stateVecV) 2750
>>>>>>> process 1
>>>>>>> Petsc VecGetLocalSize 2640
>>>>>>> size(stateVecV) 2640
>>>>>> The offsets shown below are well-within these sizes. I do not
>>>>>> understand the problem.
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> On Fri, Jan 6, 2023 at 9:51 AM Matthew Knepley <knepley at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Fri, Jan 6, 2023 at 9:37 AM Nicholas Arnold-Medabalimi <
>>>>>>>>> Hi Matt
>>>>>>>>> I made a typo on the line statVecV(offset) = <set to something> in
>>>>>>>>> my example, I agree. (I wrote that offhand since the actual assignment is
>>>>>>>>> much larger) I should be statVecV(offset+1) = <assignment> so I'm confident
>>>>>>>>> it's not a 1 0 indexing thing.
>>>>>>>>> My question is more related to what is happening in the offsets.
>>>>>>>>> c0 and c1 are pulled using DMplexgetheight stratum, so they are
>>>>>>>>> zero-indexed (which is why I loop from c0 to (c1-1)).
>>>>>>>>> For the size inquiries. on processor 0
>>>>>>>>> Petsc VecGetSize(stateVec) 5390
>>>>>>>> I need to see VecGetLocalSize()
>>>>>>>> Matt
>>>>>>>>> on processor 1
>>>>>>>>> Petsc VecGetSize 5390
>>>>>>>>> It's quite weird to me that processor one can have a positive
>>>>>>>>> offset that is less than its starting ownership index (in the initial email
>>>>>>>>> output).
>>>>>>>>> Thanks for the assistance
>>>>>>>>> Nicholas
>>>>>>>>> On Fri, Jan 6, 2023 at 9:20 AM Matthew Knepley <knepley at gmail.com>
>>>>>>>>> wrote:
>>>>>>>>>> On Fri, Jan 6, 2023 at 2:28 AM Nicholas Arnold-Medabalimi <
>>>>>>>>>>> Hi Petsc Users,
>>>>>>>>>>> I'm working with a dmplex system with a subsampled mesh
>>>>>>>>>>> distributed with an overlap of 1.
>>>>>>>>>>> I'm encountering unusual situations when using
>>>>>>>>>>> VecGetOwnershipRange to adjust the offset received from a global section.
>>>>>>>>>>> The logic of the following code is first to get the offset needed to index
>>>>>>>>>>> a global vector while still being able to check if it is an overlapped cell
>>>>>>>>>>> and skip if needed while counting the owned cells.
>>>>>>>>>>> call DMGetGlobalSection(dmplex,section,ierr)
>>>>>>>>>>> call VecGetArrayF90(stateVec,stateVecV,ierr)
>>>>>>>>>>> call VecGetOwnershipRange(stateVec,oStart,oEnd,ierr)
>>>>>>>>>>> do i = c0, (c1-1)
>>>>>>>>>>> call PetscSectionGetOffset(section,i,offset,ierr)
>>>>>>>>>>> oStart
>>>>>>>>>>> if(offset<0) then
>>>>>>>>>>> cycle
>>>>>>>>>>> endif
>>>>>>>>>>> offset=offset-oStart
>>>>>>>>>>> plexcells=plexcells+1
>>>>>>>>>>> stateVecV(offset)= <set to something> enddo
>>>>>>>>>>> I'm noticing some very weird results that I've appended below.
>>>>>>>>>>> The GetOffset documentation notes that a negative offset indicates an
>>>>>>>>>>> unowned point (which I use to cycle). However, the offset subtraction with
>>>>>>>>>>> oStart will yield an illegal index for the Vector access. I see that on the
>>>>>>>>>>> documentation for GetOwnershipRange, it notes that this may be
>>>>>>>>>>> "ill-defined" but I wanted to see if this is type of ill-defined I can
>>>>>>>>>>> expect or there is just something terribly wrong with my PetscSection.(both
>>>>>>>>>>> the Vec and Section were produced from DMPlexDistributeField so should by
>>>>>>>>>>> definition have synchronized section information) I was wondering if there
>>>>>>>>>>> is a possible output and/or the best way to index the vector. I'm thinking
>>>>>>>>>>> of subtracting the offset of cell 0 perhaps?
>>>>>>>>>> Can you show your vector sizes? Are you sure it is not the fact
>>>>>>>>>> that F90 arrays use 1-based indices, but these are 0-based offsets?
>>>>>>>>>> Thanks,
>>>>>>>>>> Matt
>>>>>>>>>>> on rank 0
>>>>>>>>>>> cell 0 offset 0 oStart 0
>>>>>>>>>>> 0
>>>>>>>>>>> cell 1 offset 55 oStart 0
>>>>>>>>>>> 55
>>>>>>>>>>> cell 2 offset 110 oStart 0
>>>>>>>>>>> 110
>>>>>>>>>>> cell 3 offset 165 oStart 0
>>>>>>>>>>> 165
>>>>>>>>>>> cell 4 offset 220 oStart 0
>>>>>>>>>>> 220
>>>>>>>>>>> cell 5 offset 275 oStart 0
>>>>>>>>>>> 275
>>>>>>>>>>> cell 6 offset 330 oStart 0
>>>>>>>>>>> 330
>>>>>>>>>>> cell 7 offset 385 oStart 0
>>>>>>>>>>> 385
>>>>>>>>>>> cell 8 offset 440 oStart 0
>>>>>>>>>>> 440
>>>>>>>>>>> cell 9 offset 495 oStart 0
>>>>>>>>>>> 495
>>>>>>>>>>> cell 10 offset 550 oStart 0
>>>>>>>>>>> 550
>>>>>>>>>>> cell 11 offset 605 oStart 0
>>>>>>>>>>> 605
>>>>>>>>>>> cell 12 offset 660 oStart 0
>>>>>>>>>>> 660
>>>>>>>>>>> cell 13 offset 715 oStart 0
>>>>>>>>>>> 715
>>>>>>>>>>> and on rank one
>>>>>>>>>>> -165
>>>>>>>>>>> -110
>>>>>>>>>>> -55
>>>>>>>>>>> 0
>>>>>>>>>>> cell 4 offset 2695 oStart 2640
>>>>>>>>>>> 55
>>>>>>>>>>> cell 5 offset 2750 oStart 2640
>>>>>>>>>>> 110
>>>>>>>>>>> cell 6 offset 2805 oStart 2640
>>>>>>>>>>> 165
>>>>>>>>>>> cell 7 offset 2860 oStart 2640
>>>>>>>>>>> 220
>>>>>>>>>>> cell 8 offset 2915 oStart 2640
>>>>>>>>>>> 275
>>>>>>>>>>> cell 9 offset 2970 oStart 2640
>>>>>>>>>>> 330
>>>>>>>>>>> cell 10 offset 3025 oStart 2640
>>>>>>>>>>> 385
>>>>>>>>>>> cell 11 offset 3080 oStart 2640
>>>>>>>>>>> 440
>>>>>>>>>>> cell 12 offset 3135 oStart 2640
>>>>>>>>>>> 495
>>>>>>>>>>> cell 13 offset 3190 oStart 2640
>>>>>>>>>>> 550
>>>>>>>>>>> cell 14 offset 3245 oStart 2640
>>>>>>>>>>> 605
>>>>>>>>>>> -3411
>>>>>>>>>>> Sincerely
>>>>>>>>>>> Nicholas
>>>>>>>>>>> Ph.D. Candidate
>>>>>>>>>>> Computational Aeroscience Lab
>>>>>>>>>>> University of Michigan
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>>> Ph.D. Candidate
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>> Ph.D. Candidate
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> Ph.D. Candidate
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> Ph.D. Candidate
>> experiments lead.
>> -- Norbert Wiener
> Ph.D. Candidate
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230106/1aab6f5e/attachment-0001.html>
