[petsc-users] Vec Ownership ranges with Global Section Offsets
Nicholas Arnold-Medabalimi narnoldm at umich.edu
Fri Jan 6 10:31:59 CST 2023
Hi Matt
This was generated using the DMPlexDistributeField which we discussed a
while back. Everything seemed to be working fine when I only had cells dofs
but I recently added face dofs, which seems to have caused some issues.
Whats weird is that I'm feeding the same distribution SF and inputting a
vector and section that are consistent to the DMPlexDistributeField so I'd
expect the vectors and section output to be consistent. I'll take a closer
look at that.
Thanks
Nicholas
On Fri, Jan 6, 2023 at 10:59 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jan 6, 2023 at 10:41 AM Nicholas Arnold-Medabalimi <
> narnoldm at umich.edu> wrote:
>> Hi Matt
>> I appreciate the help. The section view is quite extensive because each
>> cell has 55 dofs located at the cells and on certain faces. I've appended
>> the first of these which corresponds with the output in the first email, to
>> save space. The following 54 are exactly the same but offset incremented by
>> 1. (or negative 1 for negative offsets)
> Okay, from the output it is clear that this vector does not match your
> global section. Did you get stateVec by calling DMCreateGlobalVector()?
>   Thanks,
>      Matt
>> Thanks for your time
>> Nicholas
>> On Fri, Jan 6, 2023 at 10:23 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Fri, Jan 6, 2023 at 10:10 AM Nicholas Arnold-Medabalimi <
>>>> Hi Matt
>>>> I apologize for any lack of clarity in the initial email.
>>>> looking at the initial output on rank 1
>>>> write(*,*) "cell",i,"offset",offset,'oStart',oStart, offset-oStart
>>>> cell           0 offset        2475 oStart        2640        -165
>>>>  cell           1 offset        2530 oStart        2640        -110
>>>>  cell           2 offset        2585 oStart        2640         -55
>>>>  cell           3 offset        2640 oStart        2640           0
>>>> cell          15 offset        -771 oStart        2640       -3411
>>>> cell 15 provides a negative offset because it is the overlap cell (that
>>>> is unowned)
>>>> The remained of cells are all owned. However, the first 3 cells (0,1,2)
>>>> return an offset that is less than the starting ownership range. I would
>>>> expect cell 0 to start at offset 2640 at minimum.
>>> Send the output for this section
>>>   call PetscSectionView(section, PETSC_VIEWER_STDOUT_WORLD);
>>>   Thanks,
>>>      Matt
>>>> Sincerely
>>>> Nicholas
>>>> On Fri, Jan 6, 2023 at 10:05 AM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Fri, Jan 6, 2023 at 9:56 AM Nicholas Arnold-Medabalimi <
>>>>>> Apologies. If it helps, there is one cell of overlap in this small
>>>>>> test case for a 2D mesh that is 1 cell in height and a number of cells in
>>>>>> length. .
>>>>>> process 0
>>>>>>  Petsc VecGetLocalSize        2750
>>>>>>  size(stateVecV)        2750
>>>>>> process 1
>>>>>>  Petsc VecGetLocalSize        2640
>>>>>>  size(stateVecV)        2640
>>>>> The offsets shown below are well-within these sizes. I do not
>>>>> understand the problem.
>>>>>   Thanks,
>>>>>      Matt
>>>>>> On Fri, Jan 6, 2023 at 9:51 AM Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Fri, Jan 6, 2023 at 9:37 AM Nicholas Arnold-Medabalimi <
>>>>>>>> Hi Matt
>>>>>>>> I made a typo on the line statVecV(offset) = <set to something> in
>>>>>>>> my example, I agree. (I wrote that offhand since the actual assignment is
>>>>>>>> much larger) I should be statVecV(offset+1) = <assignment> so I'm confident
>>>>>>>> it's not a 1 0 indexing thing.
>>>>>>>> My question is more related to what is happening in the offsets. c0
>>>>>>>> and c1 are pulled using DMplexgetheight stratum, so they are zero-indexed
>>>>>>>> (which is why I loop from c0 to (c1-1)).
>>>>>>>> For the size inquiries. on processor 0
>>>>>>>>  Petsc VecGetSize(stateVec)        5390
>>>>>>> I need to see VecGetLocalSize()
>>>>>>>   Matt
>>>>>>>> on processor 1
>>>>>>>> Petsc VecGetSize 5390
>>>>>>>> It's quite weird to me that processor one can have a positive
>>>>>>>> offset that is less than its starting ownership index (in the initial email
>>>>>>>> output).
>>>>>>>> Thanks for the assistance
>>>>>>>> Nicholas
>>>>>>>> On Fri, Jan 6, 2023 at 9:20 AM Matthew Knepley <knepley at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> On Fri, Jan 6, 2023 at 2:28 AM Nicholas Arnold-Medabalimi <
>>>>>>>>>> Hi Petsc Users,
>>>>>>>>>> I'm working with a dmplex system with a subsampled mesh
>>>>>>>>>> distributed with an overlap of 1.
>>>>>>>>>> I'm encountering unusual situations when using
>>>>>>>>>> VecGetOwnershipRange to adjust the offset received from a global section.
>>>>>>>>>> The logic of the following code is first to get the offset needed to index
>>>>>>>>>> a global vector while still being able to check if it is an overlapped cell
>>>>>>>>>> and skip if needed while counting the owned cells.
>>>>>>>>>> call DMGetGlobalSection(dmplex,section,ierr)
>>>>>>>>>> call VecGetArrayF90(stateVec,stateVecV,ierr)
>>>>>>>>>> call VecGetOwnershipRange(stateVec,oStart,oEnd,ierr)
>>>>>>>>>> do i = c0, (c1-1)
>>>>>>>>>>     call PetscSectionGetOffset(section,i,offset,ierr)
>>>>>>>>>> oStart
>>>>>>>>>>     if(offset<0) then
>>>>>>>>>>         cycle
>>>>>>>>>>     endif
>>>>>>>>>> offset=offset-oStart
>>>>>>>>>> plexcells=plexcells+1
>>>>>>>>>> stateVecV(offset)= <set to something> enddo
>>>>>>>>>> I'm noticing some very weird results that I've appended below.
>>>>>>>>>> The GetOffset documentation notes that a negative offset indicates an
>>>>>>>>>> unowned point (which I use to cycle). However, the offset subtraction with
>>>>>>>>>> oStart will yield an illegal index for the Vector access. I see that on the
>>>>>>>>>> documentation for GetOwnershipRange, it notes that this may be
>>>>>>>>>> "ill-defined"  but I wanted to see if this is type of ill-defined I can
>>>>>>>>>> expect or there is just something terribly wrong with my PetscSection.(both
>>>>>>>>>> the Vec and Section were produced from DMPlexDistributeField so should by
>>>>>>>>>> definition have synchronized section information) I was wondering if there
>>>>>>>>>> is a possible output and/or the best way to index the vector. I'm thinking
>>>>>>>>>> of subtracting the offset of cell 0 perhaps?
>>>>>>>>> Can you show your vector sizes? Are you sure it is not the fact
>>>>>>>>> that F90 arrays use 1-based indices, but these are 0-based offsets?
>>>>>>>>>   Thanks,
>>>>>>>>>      Matt
>>>>>>>>>> on rank 0
>>>>>>>>>>  cell           0 offset           0 oStart           0
>>>>>>>>>> 0
>>>>>>>>>>  cell           1 offset          55 oStart           0
>>>>>>>>>>  55
>>>>>>>>>>  cell           2 offset         110 oStart           0
>>>>>>>>>> 110
>>>>>>>>>>  cell           3 offset         165 oStart           0
>>>>>>>>>> 165
>>>>>>>>>>  cell           4 offset         220 oStart           0
>>>>>>>>>> 220
>>>>>>>>>>  cell           5 offset         275 oStart           0
>>>>>>>>>> 275
>>>>>>>>>>  cell           6 offset         330 oStart           0
>>>>>>>>>> 330
>>>>>>>>>>  cell           7 offset         385 oStart           0
>>>>>>>>>> 385
>>>>>>>>>>  cell           8 offset         440 oStart           0
>>>>>>>>>> 440
>>>>>>>>>>  cell           9 offset         495 oStart           0
>>>>>>>>>> 495
>>>>>>>>>>  cell          10 offset         550 oStart           0
>>>>>>>>>> 550
>>>>>>>>>>  cell          11 offset         605 oStart           0
>>>>>>>>>> 605
>>>>>>>>>>  cell          12 offset         660 oStart           0
>>>>>>>>>> 660
>>>>>>>>>>  cell          13 offset         715 oStart           0
>>>>>>>>>> 715
>>>>>>>>>> and on rank one
>>>>>>>>>>  -110
>>>>>>>>>> -55
>>>>>>>>>> 0
>>>>>>>>>>  cell           4 offset        2695 oStart        2640
>>>>>>>>>>  55
>>>>>>>>>>  cell           5 offset        2750 oStart        2640
>>>>>>>>>> 110
>>>>>>>>>>  cell           6 offset        2805 oStart        2640
>>>>>>>>>> 165
>>>>>>>>>>  cell           7 offset        2860 oStart        2640
>>>>>>>>>> 220
>>>>>>>>>>  cell           8 offset        2915 oStart        2640
>>>>>>>>>> 275
>>>>>>>>>>  cell           9 offset        2970 oStart        2640
>>>>>>>>>> 330
>>>>>>>>>>  cell          10 offset        3025 oStart        2640
>>>>>>>>>> 385
>>>>>>>>>>  cell          11 offset        3080 oStart        2640
>>>>>>>>>> 440
>>>>>>>>>>  cell          12 offset        3135 oStart        2640
>>>>>>>>>> 495
>>>>>>>>>>  cell          13 offset        3190 oStart        2640
>>>>>>>>>> 550
>>>>>>>>>>  cell          14 offset        3245 oStart        2640
>>>>>>>>>> 605
>>>>>>>>>> -3411
>>>>>>>>>> Sincerely
>>>>>>>>>> Nicholas
>>>>>>>>>> Ph.D. Candidate
>>>>>>>>>> Computational Aeroscience Lab
>>>>>>>>>> University of Michigan
>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>> Ph.D. Candidate
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> Ph.D. Candidate
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> Ph.D. Candidate
>>> experiments lead.
>>> -- Norbert Wiener
>> Ph.D. Candidate
> experiments lead.
> -- Norbert Wiener
Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230106/4516a1ae/attachment-0001.html>
