[petsc-users] Vec Ownership ranges with Global Section Offsets
Nicholas Arnold-Medabalimi narnoldm at umich.edu
Fri Jan 6 11:17:51 CST 2023
I am doing that as well (although not for vertex dofs). And I had it
working quite well for purely cell-associated DOFs. But I realized later
that I also wanted to transmit some DOFs associated with faces so I suspect
I'm messing something up there.
Something we discussed back on 12/26 (email subject:Getting a vector from a
DM to output VTK)  was associating a vector generated this way with the DM
so it can be more easily visualized using vtk files is
VecSetOperation(state_dist, VECOP_VIEW, (void(*)(void))VecView_Plex);
If there is an easy way to get this working in Fortran I would very much
appreciate it as it was very helpful when I was debugging in C.
Thanks
Nicholas
On Fri, Jan 6, 2023 at 11:37 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jan 6, 2023 at 11:32 AM Nicholas Arnold-Medabalimi <
> narnoldm at umich.edu> wrote:
>> Hi Matt
>> This was generated using the DMPlexDistributeField which we discussed a
>> while back. Everything seemed to be working fine when I only had cells dofs
>> but I recently added face dofs, which seems to have caused some issues.
>> Whats weird is that I'm feeding the same distribution SF and inputting a
>> vector and section that are consistent to the DMPlexDistributeField so I'd
>> expect the vectors and section output to be consistent. I'll take a closer
>> look at that.
> The way I use DistributeField(), for example to distribute coordinates, is
> that I give it the migrationSF, the local coordinate section, and the local
> coordinate vector. It gives me back the new local coordinate section (which
> I set into the distributed DM), and the local coordinate vector. It seems
> like you are doing something else. Maybe the documentation is misleading.
>   Thanks,
>     Matt
>> Thanks
>> Nicholas
>> On Fri, Jan 6, 2023 at 10:59 AM Matthew Knepley <knepley at gmail.com>
>> wrote:
>>> On Fri, Jan 6, 2023 at 10:41 AM Nicholas Arnold-Medabalimi <
>>>> Hi Matt
>>>> I appreciate the help. The section view is quite extensive because each
>>>> cell has 55 dofs located at the cells and on certain faces. I've appended
>>>> the first of these which corresponds with the output in the first email, to
>>>> save space. The following 54 are exactly the same but offset incremented by
>>>> 1. (or negative 1 for negative offsets)
>>> Okay, from the output it is clear that this vector does not match your
>>> global section. Did you get stateVec by calling DMCreateGlobalVector()?
>>>   Thanks,
>>>      Matt
>>>> Thanks for your time
>>>> Nicholas
>>>> On Fri, Jan 6, 2023 at 10:23 AM Matthew Knepley <knepley at gmail.com>
>>>> wrote:
>>>>> On Fri, Jan 6, 2023 at 10:10 AM Nicholas Arnold-Medabalimi <
>>>>>> Hi Matt
>>>>>> I apologize for any lack of clarity in the initial email.
>>>>>> looking at the initial output on rank 1
>>>>>> write(*,*) "cell",i,"offset",offset,'oStart',oStart, offset-oStart
>>>>>> cell           0 offset        2475 oStart        2640        -165
>>>>>>  cell           1 offset        2530 oStart        2640        -110
>>>>>>  cell           2 offset        2585 oStart        2640         -55
>>>>>>  cell           3 offset        2640 oStart        2640           0
>>>>>> cell          15 offset        -771 oStart        2640       -3411
>>>>>> cell 15 provides a negative offset because it is the overlap cell
>>>>>> (that is unowned)
>>>>>> The remained of cells are all owned. However, the first 3 cells
>>>>>> (0,1,2) return an offset that is less than the starting ownership range. I
>>>>>> would expect cell 0 to start at offset 2640 at minimum.
>>>>> Send the output for this section
>>>>>   call PetscSectionView(section, PETSC_VIEWER_STDOUT_WORLD);
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Sincerely
>>>>>> Nicholas
>>>>>> On Fri, Jan 6, 2023 at 10:05 AM Matthew Knepley <knepley at gmail.com>
>>>>>> wrote:
>>>>>>> On Fri, Jan 6, 2023 at 9:56 AM Nicholas Arnold-Medabalimi <
>>>>>>>> Apologies. If it helps, there is one cell of overlap in this small
>>>>>>>> test case for a 2D mesh that is 1 cell in height and a number of cells in
>>>>>>>> length. .
>>>>>>>> process 0
>>>>>>>>  Petsc VecGetLocalSize        2750
>>>>>>>>  size(stateVecV)        2750
>>>>>>>> process 1
>>>>>>>>  Petsc VecGetLocalSize        2640
>>>>>>>>  size(stateVecV)        2640
>>>>>>> The offsets shown below are well-within these sizes. I do not
>>>>>>> understand the problem.
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>> On Fri, Jan 6, 2023 at 9:51 AM Matthew Knepley <knepley at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> On Fri, Jan 6, 2023 at 9:37 AM Nicholas Arnold-Medabalimi <
>>>>>>>>>> Hi Matt
>>>>>>>>>> I made a typo on the line statVecV(offset) = <set to something>
>>>>>>>>>> in my example, I agree. (I wrote that offhand since the actual assignment
>>>>>>>>>> is much larger) I should be statVecV(offset+1) = <assignment> so I'm
>>>>>>>>>> confident it's not a 1 0 indexing thing.
>>>>>>>>>> My question is more related to what is happening in the offsets.
>>>>>>>>>> c0 and c1 are pulled using DMplexgetheight stratum, so they are
>>>>>>>>>> zero-indexed (which is why I loop from c0 to (c1-1)).
>>>>>>>>>> For the size inquiries. on processor 0
>>>>>>>>>>  Petsc VecGetSize(stateVec)        5390
>>>>>>>>> I need to see VecGetLocalSize()
>>>>>>>>>   Matt
>>>>>>>>>> on processor 1
>>>>>>>>>> Petsc VecGetSize 5390
>>>>>>>>>> It's quite weird to me that processor one can have a positive
>>>>>>>>>> offset that is less than its starting ownership index (in the initial email
>>>>>>>>>> output).
>>>>>>>>>> Thanks for the assistance
>>>>>>>>>> Nicholas
>>>>>>>>>> On Fri, Jan 6, 2023 at 9:20 AM Matthew Knepley <knepley at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>>> On Fri, Jan 6, 2023 at 2:28 AM Nicholas Arnold-Medabalimi <
>>>>>>>>>>>> Hi Petsc Users,
>>>>>>>>>>>> I'm working with a dmplex system with a subsampled mesh
>>>>>>>>>>>> distributed with an overlap of 1.
>>>>>>>>>>>> I'm encountering unusual situations when using
>>>>>>>>>>>> VecGetOwnershipRange to adjust the offset received from a global section.
>>>>>>>>>>>> The logic of the following code is first to get the offset needed to index
>>>>>>>>>>>> a global vector while still being able to check if it is an overlapped cell
>>>>>>>>>>>> and skip if needed while counting the owned cells.
>>>>>>>>>>>> call DMGetGlobalSection(dmplex,section,ierr)
>>>>>>>>>>>> call VecGetArrayF90(stateVec,stateVecV,ierr)
>>>>>>>>>>>> call VecGetOwnershipRange(stateVec,oStart,oEnd,ierr)
>>>>>>>>>>>> do i = c0, (c1-1)
>>>>>>>>>>>>     call PetscSectionGetOffset(section,i,offset,ierr)
>>>>>>>>>>>> -oStart
>>>>>>>>>>>>     if(offset<0) then
>>>>>>>>>>>>         cycle
>>>>>>>>>>>>     endif
>>>>>>>>>>>> offset=offset-oStart
>>>>>>>>>>>> plexcells=plexcells+1
>>>>>>>>>>>> stateVecV(offset)= <set to something> enddo
>>>>>>>>>>>> I'm noticing some very weird results that I've appended below.
>>>>>>>>>>>> The GetOffset documentation notes that a negative offset indicates an
>>>>>>>>>>>> unowned point (which I use to cycle). However, the offset subtraction with
>>>>>>>>>>>> oStart will yield an illegal index for the Vector access. I see that on the
>>>>>>>>>>>> documentation for GetOwnershipRange, it notes that this may be
>>>>>>>>>>>> "ill-defined"  but I wanted to see if this is type of ill-defined I can
>>>>>>>>>>>> expect or there is just something terribly wrong with my PetscSection.(both
>>>>>>>>>>>> the Vec and Section were produced from DMPlexDistributeField so should by
>>>>>>>>>>>> definition have synchronized section information) I was wondering if there
>>>>>>>>>>>> is a possible output and/or the best way to index the vector. I'm thinking
>>>>>>>>>>>> of subtracting the offset of cell 0 perhaps?
>>>>>>>>>>> Can you show your vector sizes? Are you sure it is not the fact
>>>>>>>>>>> that F90 arrays use 1-based indices, but these are 0-based offsets?
>>>>>>>>>>>   Thanks,
>>>>>>>>>>>      Matt
>>>>>>>>>>>> on rank 0
>>>>>>>>>>>>  cell           0 offset           0 oStart           0
>>>>>>>>>>>>   0
>>>>>>>>>>>>  cell           1 offset          55 oStart           0
>>>>>>>>>>>>  55
>>>>>>>>>>>>  cell           2 offset         110 oStart           0
>>>>>>>>>>>> 110
>>>>>>>>>>>>  cell           3 offset         165 oStart           0
>>>>>>>>>>>> 165
>>>>>>>>>>>>  cell           4 offset         220 oStart           0
>>>>>>>>>>>> 220
>>>>>>>>>>>>  cell           5 offset         275 oStart           0
>>>>>>>>>>>> 275
>>>>>>>>>>>>  cell           6 offset         330 oStart           0
>>>>>>>>>>>> 330
>>>>>>>>>>>>  cell           7 offset         385 oStart           0
>>>>>>>>>>>> 385
>>>>>>>>>>>>  cell           8 offset         440 oStart           0
>>>>>>>>>>>> 440
>>>>>>>>>>>>  cell           9 offset         495 oStart           0
>>>>>>>>>>>> 495
>>>>>>>>>>>>  cell          10 offset         550 oStart           0
>>>>>>>>>>>> 550
>>>>>>>>>>>>  cell          11 offset         605 oStart           0
>>>>>>>>>>>> 605
>>>>>>>>>>>>  cell          12 offset         660 oStart           0
>>>>>>>>>>>> 660
>>>>>>>>>>>>  cell          13 offset         715 oStart           0
>>>>>>>>>>>> 715
>>>>>>>>>>>> and on rank one
>>>>>>>>>>>>  -165
>>>>>>>>>>>>  -110
>>>>>>>>>>>> -55
>>>>>>>>>>>>   0
>>>>>>>>>>>>  cell           4 offset        2695 oStart        2640
>>>>>>>>>>>>  55
>>>>>>>>>>>>  cell           5 offset        2750 oStart        2640
>>>>>>>>>>>> 110
>>>>>>>>>>>>  cell           6 offset        2805 oStart        2640
>>>>>>>>>>>> 165
>>>>>>>>>>>>  cell           7 offset        2860 oStart        2640
>>>>>>>>>>>> 220
>>>>>>>>>>>>  cell           8 offset        2915 oStart        2640
>>>>>>>>>>>> 275
>>>>>>>>>>>>  cell           9 offset        2970 oStart        2640
>>>>>>>>>>>> 330
>>>>>>>>>>>>  cell          10 offset        3025 oStart        2640
>>>>>>>>>>>> 385
>>>>>>>>>>>>  cell          11 offset        3080 oStart        2640
>>>>>>>>>>>> 440
>>>>>>>>>>>>  cell          12 offset        3135 oStart        2640
>>>>>>>>>>>> 495
>>>>>>>>>>>>  cell          13 offset        3190 oStart        2640
>>>>>>>>>>>> 550
>>>>>>>>>>>>  cell          14 offset        3245 oStart        2640
>>>>>>>>>>>> 605
>>>>>>>>>>>> -3411
>>>>>>>>>>>> Sincerely
>>>>>>>>>>>> Nicholas
>>>>>>>>>>>> Ph.D. Candidate
>>>>>>>>>>>> Computational Aeroscience Lab
>>>>>>>>>>>> University of Michigan
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>>>>>>>> Ph.D. Candidate
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>>> Ph.D. Candidate
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> Ph.D. Candidate
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> Ph.D. Candidate
>>> experiments lead.
>>> -- Norbert Wiener
>> Ph.D. Candidate
> experiments lead.
> -- Norbert Wiener
Ph.D. Candidate
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230106/e7f9caf4/attachment-0001.html>
