[petsc-users] The exact Jacobian for ASPIN
Lulu Liu lulu.liu at kaust.edu.sa
Sat Nov 6 06:19:59 CDT 2021
For ASPIN, the local problem F_{j}(x-T_{j})=0 (j=1,2,...N)  is solved. The
exact Jacobian of the preconditioned Jacobian is
J_exact=\sum_{j=1}^{N}J_{I}(x-T_{i})J(x-T_{j}).
It seems that PETSc uses the approximate Jacobian,
J_exact=\sum_{j=1}^{N}J_{j}(x-T_{i})J(x-\sum_{j=1}^{N}T_{j}).
I want to implement RASPEN, which requires the exact Jacobian of
ASPIN.  Is there
any easy way to compute J(x-T_{j}) (j=1,2,..N)? How can I get the global
vectors like  x-T_{j}  ? PETSc only provides  the vector x-T_{j} on the
subdomain now.
Thanks very much!
Best wishes,
Lulu Liu
This message and its contents, including attachments are intended solely
for the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete
this message from your computer system. Any unauthorized use or
distribution is prohibited. Please consider the environment before printing
this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211106/1aa84edf/attachment.html>
