[petsc-users] The exact Jacobian for ASPIN
    Barry Smith
    bsmith at petsc.dev
    Mon Nov  8 21:18:41 CST 2021
  Lulu,
    Sorry for not responding quicker. This question will take a little research to figure out exactly what is needed, I am not sure it is possible.
    I note below you have a J_{I} is that intentional? If so what does it mean, or is a typo that should be J_{j} as in the next equation?
  Barry
> On Nov 6, 2021, at 7:19 AM, Lulu Liu <lulu.liu at kaust.edu.sa> wrote:
> Hi,
> For ASPIN, the local problem F_{j}(x-T_{j})=0 (j=1,2,...N)  is solved. The exact Jacobian of the preconditioned Jacobian is
> J_exact=\sum_{j=1}^{N}J_{I}(x-T_{i})J(x-T_{j}).
> It seems that PETSc uses the approximate Jacobian,
> J_exact=\sum_{j=1}^{N}J_{j}(x-T_{i})J(x-\sum_{j=1}^{N}T_{j}).
> I want to implement RASPEN, which requires the exact Jacobian of ASPIN.  Is there any easy way to compute J(x-T_{j}) (j=1,2,..N)? How can I get the global vectors like  x-T_{j}  ? PETSc only provides  the vector x-T_{j} on the subdomain now.
> Thanks very much!
> Best wishes,
> Lulu Liu
> This message and its contents, including attachments are intended solely for the original recipient. If you are not the intended recipient or have received this message in error, please notify me immediately and delete this message from your computer system. Any unauthorized use or distribution is prohibited. Please consider the environment before printing this email.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211108/b4048d07/attachment-0001.html>
