[petsc-users] HDF5 and ParaView
    David Scott
    d.scott at epcc.ed.ac.uk
    Thu Jul  9 14:28:46 CDT 2020
Matt,
I'll have a go at writing Xdmf files.
Am I right in thinking that VTK files are written sequentially?
David
On 09/07/2020 20:17, Matthew Knepley wrote:
> On Thu, Jul 9, 2020 at 2:51 PM David Scott <d.scott at epcc.ed.ac.uk
> <mailto:d.scott at epcc.ed.ac.uk>> wrote:
>     Hello,
>     I have written out a Vec using the (Fortran) HDF5 routines provided by
>     PETSc.
>     I now want to import the data into ParaView 5.8.0 and display a
>     contour.
>     I can read the data in using VisItPixieReader but the contour tool is
>     not available. Can I use the HDF5 files produced by PETSc 13.3.3 with
>     ParaView and, if so, how?
> When you call VecView(), it just writes an array of real numbers to
> the HDF5 file. If Paraview can use an array
> of real numbers, then you are all set. I don't know how to make
> Paraview do that. What I do is to write an
> Xdmf file that points to the HDF5 file for the data and specifies the
> mesh using XML. Note  that you can have
> a DMDA or DMPlex write VTK files, which Paraview can read directly.
>   Thanks,
>      Matt
>     David
>     The University of Edinburgh is a charitable body, registered in
>     Scotland, with registration number SC005336.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200709/97d6d20e/attachment-0001.html>
