[petsc-users] HDF5 and ParaView
Matthew Knepley
knepley at gmail.com
Thu Jul 9 15:10:34 CDT 2020
On Thu, Jul 9, 2020 at 3:28 PM David Scott <d.scott at epcc.ed.ac.uk> wrote:
> Matt,
> I'll have a go at writing Xdmf files.
> Am I right in thinking that VTK files are written sequentially?
Yes, it is a rightly despised format, suitable only for beggars and serial
jobs :)
Matt
> Thanks,
> David
> On 09/07/2020 20:17, Matthew Knepley wrote:
> On Thu, Jul 9, 2020 at 2:51 PM David Scott <d.scott at epcc.ed.ac.uk> wrote:
>> Hello,
>> I have written out a Vec using the (Fortran) HDF5 routines provided by
>> PETSc.
>> I now want to import the data into ParaView 5.8.0 and display a contour.
>> I can read the data in using VisItPixieReader but the contour tool is
>> not available. Can I use the HDF5 files produced by PETSc 13.3.3 with
>> ParaView and, if so, how?
> When you call VecView(), it just writes an array of real numbers to the
> HDF5 file. If Paraview can use an array
> of real numbers, then you are all set. I don't know how to make Paraview
> do that. What I do is to write an
> Xdmf file that points to the HDF5 file for the data and specifies the mesh
> using XML. Note that you can have
> a DMDA or DMPlex write VTK files, which Paraview can read directly.
> Thanks,
> Matt
>> David
>> The University of Edinburgh is a charitable body, registered in Scotland,
>> with registration number SC005336.
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200709/98dc9cb6/attachment.html>
