[petsc-users] HDF5 and ParaView
Matthew Knepley
knepley at gmail.com
Thu Jul 9 14:17:52 CDT 2020
On Thu, Jul 9, 2020 at 2:51 PM David Scott <d.scott at epcc.ed.ac.uk> wrote:
> Hello,
> I have written out a Vec using the (Fortran) HDF5 routines provided by
> PETSc.
> I now want to import the data into ParaView 5.8.0 and display a contour.
> I can read the data in using VisItPixieReader but the contour tool is
> not available. Can I use the HDF5 files produced by PETSc 13.3.3 with
> ParaView and, if so, how?
When you call VecView(), it just writes an array of real numbers to the
HDF5 file. If Paraview can use an array
of real numbers, then you are all set. I don't know how to make Paraview do
that. What I do is to write an
Xdmf file that points to the HDF5 file for the data and specifies the mesh
using XML. Note that you can have
a DMDA or DMPlex write VTK files, which Paraview can read directly.
Matt
> David
> The University of Edinburgh is a charitable body, registered in Scotland,
> with registration number SC005336.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20200709/49bdd5ba/attachment.html>
