[petsc-users] How to use DMPlex_Distribute(_Overlap) without redistribution of the mesh
Wed Oct 2 05:19:40 CDT 2019
On Tue, Oct 1, 2019 at 7:39 PM Fabian.Jakub via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear Petsc team,
> dear Matt,
> I have a 3D, distributed DMPlex with 0 overlap in FVM adjacency.
> Now, I would like to add overlap but not change the local portions.
> I was wondering if you could suggest how to do that best/easiest.
> My problem is that just using DMPlexDistribute changes the partitioning,
> i.e. cells change owners.
> I guess I could trace the steps you took in
> DMPlexDistributeOverlap
DistributeOverlap() should not change the partition. Are you sure it does?
I think you just call that.
    Matt
> and the following stuff you have in
> DMPlexDistribute() { if overlap > 0 }
> Another thought was to use a custom partitioner so as not to change the
> local layouts. Is this a good idea?
> In case that you suggest to go for first steps (the duplication of the
> DMPlexDistributeOverlap stuff) could you add a fortran stub for it?
> Many thanks,
> Fabian
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20191002/1d36642f/attachment.html>
