[petsc-users] How to use DMPlex_Distribute(_Overlap) without redistribution of the mesh
Fabian.Jakub Fabian.Jakub at physik.uni-muenchen.de
Tue Oct 1 18:38:21 CDT 2019
Dear Petsc team,
dear Matt,
I have a 3D, distributed DMPlex with 0 overlap in FVM adjacency.
Now, I would like to add overlap but not change the local portions.
I was wondering if you could suggest how to do that best/easiest.
My problem is that just using DMPlexDistribute changes the partitioning,
i.e. cells change owners.
I guess I could trace the steps you took in
DMPlexDistributeOverlap
and the following stuff you have in
DMPlexDistribute() { if overlap > 0 }
Another thought was to use a custom partitioner so as not to change the
local layouts. Is this a good idea?
In case that you suggest to go for first steps (the duplication of the
DMPlexDistributeOverlap stuff) could you add a fortran stub for it?
Many thanks,
Fabian
