[petsc-users] Solvers for phase field fracture
Karin&NiKo
niko.karin at gmail.com
Thu Jan 4 02:36:14 CST 2018
What you describe is typical of strain softening. In the solid mechanics
community, arc length methods are often prefered to solve this kind of
problems. The classical references are Riks and Crisfield. You can also
take a look at this technique :
http://onlinelibrary.wiley.com/doi/10.1002/nme.971/abstract.
But I am not aware of the avalability of such approach in the TS objects of
PETSc.
Nicolas
2018-01-04 8:35 GMT+01:00 Sanjay Govindjee <s_g at berkeley.edu>:
> Are you sure your problem is stable? Also have you tried adding mass?
> On 1/3/18 10:12 PM, Avtar Singh wrote:
> Hello Petsc Users,
> I am solving a fortran framework to simulate phase-field fracture problem.
> Upto the failure point the code is working fine. But as the crack-phase
> starts to propagate, there is abrupt changes in the Stiffness Matrix, so
> determinant becomes nearly equal to zero. Hence, the code crashes.
> I tried with mumps package with pc lu. Also tried, superlu, gmres and
> fgmres with jacobi, bjacobi, lu. But the problem still persist.
> Can anyone suggest, Which solver and preconditioner should i use?
> Thank you
> Avtar Singh
> Research Scholar
> Multiscale Mechanics and Multiphysics Lab
> IIT Roorkee, Roorkee
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180104/99c71a79/attachment.html>
