[petsc-users] Solvers for phase field fracture
Sanjay Govindjee
s_g at berkeley.edu
Thu Jan 4 01:35:38 CST 2018
Are you sure your problem is stable? Also have you tried adding mass?
On 1/3/18 10:12 PM, Avtar Singh wrote:
> Hello Petsc Users,
> I am solving a fortran framework to simulate phase-field fracture
> problem. Upto the failure point the code is working fine. But as the
> crack-phase starts to propagate, there is abrupt changes in the
> Stiffness Matrix, so determinant becomes nearly equal to zero. Hence,
> the code crashes.
> I tried with mumps package with pc lu. Also tried, superlu, gmres and
> fgmres with jacobi, bjacobi, lu. But the problem still persist.
> Can anyone suggest, Which solver and preconditioner should i use?
> Thank you
> Avtar Singh
> Research Scholar
> Multiscale Mechanics and Multiphysics Lab
> IIT Roorkee, Roorkee
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180103/5bcb46c1/attachment.html>
