[petsc-users] petsc-3.5 quadruple precision mixed with double
Matthew Knepley
knepley at gmail.com
Wed Jun 28 20:27:19 CDT 2017
On Wed, Jun 28, 2017 at 8:22 PM, Hao Zhang <hbcbh1999 at gmail.com> wrote:
> It's 3d incompressible RT simulation. My pressure between serial and
> parallel calculation is off by 10^(-14) in relative error.
This could just be reordering of the calculation.
> it eventually build up at later time. I want to rule out the possibilities
> that PETSc give me bad solution. pressure scale is 10^(-2).
> I use PetscScalar. thanks @Jed Brown for confirming that but I have
> Segmentation Violation when retrieving x. I allocated memory for the array
> x (PetscScalar type). if not for quadruple precision, there is no error.
It sounds like maybe you are passing a double where a PetscScalar is
expected, or vice versa. Run under valgrind.
Matt
> thanks @Satish Balay. I will update code petsc-3.7 later.
experiments lead.
-- Norbert Wiener
http://www.caam.rice.edu/~mk51/
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170628/361d83db/attachment-0001.html>
