[petsc-users] petsc-3.5 quadruple precision mixed with double
Hao Zhang hbcbh1999 at gmail.com
Wed Jun 28 21:00:37 CDT 2017
thanks, @Matthew
I was worried about this. is there a way to convert double to PetscScalar?
incompressible code are double type everywhere else except for PETSc. could
this be the problem?
it was double type for the entire code  including PETSc before this
quadruple test.
On Wed, Jun 28, 2017 at 9:27 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Jun 28, 2017 at 8:22 PM, Hao Zhang <hbcbh1999 at gmail.com> wrote:
>> It's 3d incompressible RT simulation. My pressure between serial and
>> parallel calculation is off by 10^(-14) in relative error.
> This could just be reordering of the calculation.
>> it eventually build up at later time. I want to rule out the
>> possibilities that PETSc give me bad solution. pressure scale is 10^(-2).
>> I use PetscScalar. thanks @Jed Brown for confirming that but I have
>> Segmentation Violation when retrieving x. I allocated memory for the array
>> x (PetscScalar type). if not for quadruple precision, there is no error.
> It sounds like maybe you are passing a double where a PetscScalar is
> expected, or vice versa. Run under valgrind.
>   Matt
>> thanks @Satish Balay. I will update code petsc-3.7 later.
> experiments lead.
> -- Norbert Wiener
> http://www.caam.rice.edu/~mk51/
hao
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20170628/90ccfe0f/attachment.html>
