[petsc-users] Errors in installing PETSc
    Scott Dossa
    doss0032 at umn.edu
    Tue Sep 13 11:40:40 CDT 2016
Hi Jason,
I have two tips for configuring PETSc.
While I can't speak for all Cluster Computing, I know that many of the
libraries you are attempting to link might require loading when logging
into a cluster.
For example, here at MSI, one needs to call
> module load mkl
to load the intel math kernel library (which includes blas-lapack).
Since you are downloading blas-lapack, that example would not be necessary,
but it may be for other libraries you are using.
Also I found I had to search manually for where the shared-libraries
resided and explicitly tell PETSc where they live. For example, when I
configure PETSc, I had to include options like
> ./configure (. . .)
> --with-mpi-dir=/panfs/roc/itascasoft/openmpi/el6/1.7.2/intel-2013-update5
to tell PETSc where openmpi lives. I had to do this for nearly all
libraries I wished to link to PETSc.
Hope this helps!
-Scott Dossa
On Tue, Sep 13, 2016 at 11:25 AM, Jason Hou <jason.hou at ncsu.edu> wrote:
> Hi there,
> I was trying to install MOOSE, which uses PETSc as the solver; however, I
> was stuck during the installation of PETSc.
> [jhou8 at rdfmg petsc-3.6.4]$ pwd
> /tmp/cluster_temp.FFxzAF/petsc-3.6.4
> [jhou8 at rdfmg petsc-3.6.4]$ ./configure --prefix=$PETSC_DIR
> --download-hypre=1 --with-ssl=0 --with-debugging=1 --with-pic=1
> --with-shared-libraries=1 --with-cc=mpicc --with-cxx=mpicxx
> --with-fc=mpif90 --download-fblaslapack=1 --download-metis=1
> --download-parmetis=1 --download-superlu_dist=1 --download-scalapack=1
> --download-mumps=1 CC=mpicc CXX=mpicxx FC=mpif90 F77=mpif77 F90=mpif90
> CFLAGS='-fPIC -fopenmp' CXXFLAGS='-fPIC -fopenmp' FFLAGS='-fPIC -fopenmp'
> FCFLAGS='-fPIC -fopenmp' F90FLAGS='-fPIC -fopenmp' F77FLAGS='-fPIC
> -fopenmp' PETSC_DIR=`pwd`
> (sections removed)
>                 Compiling and installing Scalapack; this may take several
> minutes
>                                                               TESTING:
> check from config.libraries(config/BuildSystem/config/libraries.py:146)
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
> details):
> Downloaded scalapack could not be used. Please check install in
> /cm/shared/modulefiles/moose-compilers/petsc/petsc-3.6.4/gcc-opt
> Also attached is the configure.log file and I hope you could help me with
> that. Thank you in advance for your effort.
> Jason
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160913/b5826ae3/attachment.html>
