[petsc-users] Errors in installing PETSc
Jason Hou jason.hou at ncsu.edu
Tue Sep 13 11:25:34 CDT 2016
Hi there,
I was trying to install MOOSE, which uses PETSc as the solver; however, I
was stuck during the installation of PETSc.
[jhou8 at rdfmg petsc-3.6.4]$ pwd
/tmp/cluster_temp.FFxzAF/petsc-3.6.4
[jhou8 at rdfmg petsc-3.6.4]$ ./configure --prefix=$PETSC_DIR
--download-hypre=1 --with-ssl=0 --with-debugging=1 --with-pic=1
--with-shared-libraries=1 --with-cc=mpicc --with-cxx=mpicxx
--with-fc=mpif90 --download-fblaslapack=1 --download-metis=1
--download-parmetis=1 --download-superlu_dist=1 --download-scalapack=1
--download-mumps=1 CC=mpicc CXX=mpicxx FC=mpif90 F77=mpif77 F90=mpif90
CFLAGS='-fPIC -fopenmp' CXXFLAGS='-fPIC -fopenmp' FFLAGS='-fPIC -fopenmp'
FCFLAGS='-fPIC -fopenmp' F90FLAGS='-fPIC -fopenmp' F77FLAGS='-fPIC
-fopenmp' PETSC_DIR=`pwd`
(sections removed)
                Compiling and installing Scalapack; this may take several
minutes
                                                            TESTING: check
from config.libraries(config/BuildSystem/config/libraries.py:146)
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for
details):
Downloaded scalapack could not be used. Please check install in
/cm/shared/modulefiles/moose-compilers/petsc/petsc-3.6.4/gcc-opt
Also attached is the configure.log file and I hope you could help me with
that. Thank you in advance for your effort.
Jason
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160913/88b17ec4/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20160913/88b17ec4/attachment-0001.obj>
