[petsc-users] A similar question of "Enquiry regarding log summary results"
Jed Brown
jedbrown at mcs.anl.gov
Fri Oct 5 12:00:18 CDT 2012
On Fri, Oct 5, 2012 at 11:51 AM, Zhenglun (Alan) Wei <zhenglun.wei at gmail.com
> wrote:
> Dear folks,
> I hope you're having a nice day.
> I've been reading the thread of "Enquiry regarding log summary
> results" and tried the similar things with -log_summary with my code.
> However, my output seems totally different from Dr. TAY Wee-beng's. I
> attached it here. My code adopts the /src/ksp/ksp/example/tutorial/**ex45.c
> from Dr. Yang to solve the Poisson equation (twice). The "Event Stage 3"
> and "Event Stage 5" are just for "KSPSolve", for example:
> ierr = PetscLogStagePush(stages[2]); CHKERRQ(ierr); // Start Pressure
> Poisson Equation Solve
> ierr = KSPSolve(ksp,PETSC_NULL,PETSC_**NULL);CHKERRQ(ierr);
> ierr = PetscLogStagePop(); CHKERRQ(ierr); // Finish Pressure Poisson
> Equation Solve
> Therefore, solving the equation takes most of my times. In the
> procedure of solving the equation, VecMDot, MatMult, MatMultAdd,
> MatMultTranspose takes lots of time.
> Event Count Time (sec) Flops
> --- Global --- --- Stage --- Total
> Max Ratio Max Ratio Max Ratio Mess Avg len
> Reduct %T %f %M %L %R %T %f %M %L %R Mflop/s
> --- Event Stage 3: Pressure Solve
> KSPGMRESOrthog 8643 1.0 2.0476e+0313.1 5.84e+09 1.0 0.0e+00 0.0e+00
> 8.6e+03 17 13 0 0 17 39 29 0 0 36 270
> KSPSetUp 5 1.0 1.0729e-05 3.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 0
> KSPSolve 5 1.0 4.0481e+03 1.0 2.05e+10 1.0 4.0e+07 1.2e+03
> 2.4e+04 44 46 47 44 46 100100100100100 477
> VecMDot 8643 1.0 2.0424e+0313.5 2.92e+09 1.0 0.0e+00 0.0e+00
> 8.6e+03 17 7 0 0 17 39 14 0 0 36 135
> VecNorm 14503 1.0 8.7184e+02 6.4 8.47e+08 1.0 0.0e+00 0.0e+00
> 1.5e+04 7 2 0 0 28 15 4 0 0 61 92
> VecScale 14503 1.0 3.7836e+00 4.7 4.23e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 1 0 0 0 0 2 0 0 0 10598
> VecCopy 5767 1.0 2.0257e+00 3.8 0.00e+00 0.0 0.0e+00 0.0e+00
> VecSet 34670 1.0 5.5035e+00 4.7 0.00e+00 0.0 0.0e+00 0.0e+00
> VecAXPY 8741 1.0 2.9888e+00 4.5 5.10e+08 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 1 0 0 0 0 3 0 0 0 16172
> VecAYPX 2881 1.0 1.7167e+00 7.2 8.41e+07 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 4640
> VecWAXPY 93 1.0 5.3297e-02 4.8 2.71e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 4824
> VecMAXPY 14503 1.0 1.5191e+01 3.1 3.42e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 8 0 0 0 0 17 0 0 0 21342
> VecAssemblyBegin 5 1.0 3.7097e+0012.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.5e+01 0 0 0 0 0 0 0 0 0 0 0
> VecAssemblyEnd 5 1.0 2.9087e-05 5.8 0.00e+00 0.0 0.0e+00 0.0e+00
> VecScatterBegin 26022 1.0 1.1726e+01 4.2 0.00e+00 0.0 4.0e+07 1.2e+03
> 0.0e+00 0 0 47 44 0 0 0100100 0 0
> VecScatterEnd 26022 1.0 3.5268e+03 3.5 0.00e+00 0.0 0.0e+00 0.0e+00
> 0.0e+00 19 0 0 0 0 43 0 0 0 0 0
> VecNormalize 11524 1.0 8.4214e+02 7.2 1.01e+09 1.0 0.0e+00 0.0e+00
> 1.2e+04 6 2 0 0 22 15 5 0 0 49 114
> MatMult 14498 1.0 3.0545e+0382.7 5.50e+09 1.0 6.4e+06 7.6e+03
> 0.0e+00 9 12 8 44 0 21 27 16 98 0 169
This load imbalance is totally unreasonable. Either you have an atrocious
partition or there is contention on the machine (over-subscribed or other
things running). The load balance for MatMult() should be close to 1.0 and
the MFlop/s (last column) should be at least 10000 or so.
> MatMultAdd 2881 1.0 1.8177e+0218.6 1.09e+09 1.1 3.6e+06 1.5e+01
> 0.0e+00 1 2 4 0 0 2 5 9 0 0 560
> MatMultTranspose 2881 1.0 7.1296e+0274.9 1.09e+09 1.1 3.6e+06 1.5e+01
> 0.0e+00 5 2 4 0 0 11 5 9 0 0 143
> MatSolve 14405 1.0 3.9663e+01 3.3 4.56e+09 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 10 0 0 0 1 22 0 0 0 10890
> MatLUFactorNum 5 1.0 3.9389e-02 1.6 3.05e+06 1.0 0.0e+00 0.0e+00
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 7322
> MatILUFactorSym 5 1.0 4.2221e-02 3.2 0.00e+00 0.0 0.0e+00 0.0e+00
> 5.0e+00 0 0 0 0 0 0 0 0 0 0 0
> MatGetRowIJ 5 1.0 9.7752e-06 5.1 0.00e+00 0.0 0.0e+00 0.0e+00
> MatGetOrdering 5 1.0 2.9373e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.0e+01 0 0 0 0 0 0 0 0 0 0 0
> PCSetUp 5 1.0 8.3110e-02 2.0 3.05e+06 1.0 0.0e+00 0.0e+00
> 1.5e+01 0 0 0 0 0 0 0 0 0 0 3470
> PCSetUpOnBlocks 5762 1.0 9.9790e-02 2.0 3.05e+06 1.0 0.0e+00 0.0e+00
> 1.5e+01 0 0 0 0 0 0 0 0 0 0 2890
> PCApply 2881 1.0 3.3151e+03 1.0 1.37e+10 1.0 3.8e+07 1.0e+03
> 1.7e+04 36 31 46 36 33 82 67 97 80 73 390
> BTW, how to really calculate the time that a function costs? For
> example, it shows that "VecMDot, 2.0424e+0313.5". Would that be
> 2.0424*10^313.5 sec?
No, the imbalance is just spilling over. The amount of time is 2042 seconds.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121005/e53a2389/attachment.html>
