[petsc-users] A similar question of "Enquiry regarding log summary results"
Zhenglun (Alan) Wei zhenglun.wei at gmail.com
Fri Oct 5 14:33:18 CDT 2012
Dear Dr. Brown,
      Thanks for your reply. I checked my grid partition by output the
corner points of the local domain. There is no problem according to that.
      I ran the same case with smaller grid size with 8 cores and find
that the code occupy a lot of memory and slow if I use the original
script file which is
/mpiexec -np 8 ./ex45 -pc_type exotic -ksp_type fgmres
-mg_levels_ksp_type gmres -mg_levels_ksp_max_it 1 -mg_levels_pc_type
bjacobi -ksp_rtol 1.0e-7 -ksp_monitor_true_residual
-ksp_converged_reason -log_summary > out/
      If I simply use
/mpiexec -np 8 ./ex45 -ksp_monitor_true_residual -ksp_converged_reason
-log_summary > out/
      Everything works fine. Therefore, I did more tests and found out
that the "-pc_type exotic" has some problem. Now I changed it to
"-pc_type gamg"; like,
/mpiexec -np 8 ./ex45 -pc_type gamg -ksp_type fgmres -mg_levels_ksp_type
gmres -mg_levels_ksp_max_it 1 -mg_levels_pc_type bjacobi -ksp_rtol
1.0e-7 -ksp_monitor_true_residual -ksp_converged_reason -log_summary > out//
      it is super fast now, the log file is attached. However, I have
another question that it always show that "unpreconditioned " although I
already put pc_type over there.
       " 0 KSP unpreconditioned resid norm 1.800295456670e+01 true resid
norm 1.800295456670e+01 ||r(i)||/||b|| 1.000000000000e+00"
       However, if I changed the 'ksp_type' from 'fgmres' to 'cg', it
would give me:
       "0 KSP preconditioned resid norm 1.117293929796e+02 true resid
norm 1.800293604638e+01 ||r(i)||/||b|| 1.000000000000e+00"
       The finial question: what are the choice for the
/'/-mg_levels_ksp_type'. Are they as the same as 'ksp_type'?
thank you so much,
Alan
On 10/5/2012 12:00 PM, Jed Brown wrote:
> On Fri, Oct 5, 2012 at 11:51 AM, Zhenglun (Alan) Wei
> <zhenglun.wei at gmail.com <mailto:zhenglun.wei at gmail.com>> wrote:
>     Dear folks,
>         I hope you're having a nice day.
>         I've been reading the thread of "Enquiry regarding log summary
>     results" and tried the similar things with -log_summary with my
>     code. However, my output seems totally different from Dr. TAY
>     Wee-beng's. I attached it here. My code adopts the
>     /src/ksp/ksp/example/tutorial/ex45.c from Dr. Yang to solve the
>     Poisson equation (twice). The "Event Stage 3" and "Event Stage 5"
>     are just for "KSPSolve", for example:
>         ierr = PetscLogStagePush(stages[2]);  CHKERRQ(ierr); // Start
>     Pressure Poisson Equation Solve
>         ierr = KSPSolve(ksp,PETSC_NULL,PETSC_NULL);CHKERRQ(ierr);
>         ierr = PetscLogStagePop();  CHKERRQ(ierr); // Finish Pressure
>          Therefore, solving the equation takes most of my times. In
>     the procedure of solving the equation, VecMDot, MatMult,
>     MatMultAdd, MatMultTranspose takes lots of time.
>     Event                Count      Time (sec) Flops               ---
>     Global ---  --- Stage --- Total
>                        Max Ratio  Max     Ratio   Max  Ratio  Mess
>     Avg len Reduct  %T %f %M %L %R  %T %f %M %L %R Mflop/s
>     --- Event Stage 3: Pressure Solve
>     KSPGMRESOrthog      8643 1.0 2.0476e+0313.1 5.84e+09 1.0 0.0e+00
>     0.0e+00 8.6e+03 17 13  0  0 17  39 29  0  0 36   270
>     KSPSetUp               5 1.0 1.0729e-05 3.5 0.00e+00 0.0 0.0e+00
>     0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
>     KSPSolve               5 1.0 4.0481e+03 1.0 2.05e+10 1.0 4.0e+07
>     1.2e+03 2.4e+04 44 46 47 44 46 100100100100100   477
>     VecMDot             8643 1.0 2.0424e+0313.5 2.92e+09 1.0 0.0e+00
>     0.0e+00 8.6e+03 17  7  0  0 17  39 14  0  0 36   135
>     VecNorm            14503 1.0 8.7184e+02 6.4 8.47e+08 1.0 0.0e+00
>     0.0e+00 1.5e+04  7  2  0  0 28  15  4  0  0 61    92
>     VecScale           14503 1.0 3.7836e+00 4.7 4.23e+08 1.0 0.0e+00
>     0.0e+00 0.0e+00  0  1  0  0  0   0  2  0  0  0 10598
>     VecCopy             5767 1.0 2.0257e+00 3.8 0.00e+00 0.0 0.0e+00
>     VecSet             34670 1.0 5.5035e+00 4.7 0.00e+00 0.0 0.0e+00
>     VecAXPY             8741 1.0 2.9888e+00 4.5 5.10e+08 1.0 0.0e+00
>     0.0e+00 0.0e+00  0  1  0  0  0   0  3  0  0  0 16172
>     VecAYPX             2881 1.0 1.7167e+00 7.2 8.41e+07 1.0 0.0e+00
>     0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4640
>     VecWAXPY              93 1.0 5.3297e-02 4.8 2.71e+06 1.0 0.0e+00
>     0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4824
>     VecMAXPY           14503 1.0 1.5191e+01 3.1 3.42e+09 1.0 0.0e+00
>     0.0e+00 0.0e+00  0  8  0  0  0   0 17  0  0  0 21342
>     VecAssemblyBegin       5 1.0 3.7097e+0012.5 0.00e+00 0.0 0.0e+00
>     0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  0     0
>     VecAssemblyEnd         5 1.0 2.9087e-05 5.8 0.00e+00 0.0 0.0e+00
>     VecScatterBegin    26022 1.0 1.1726e+01 4.2 0.00e+00 0.0 4.0e+07
>     1.2e+03 0.0e+00  0  0 47 44  0   0  0100100  0     0
>     VecScatterEnd      26022 1.0 3.5268e+03 3.5 0.00e+00 0.0 0.0e+00
>     0.0e+00 0.0e+00 19  0  0  0  0  43  0  0  0  0     0
>     VecNormalize       11524 1.0 8.4214e+02 7.2 1.01e+09 1.0 0.0e+00
>     0.0e+00 1.2e+04  6  2  0  0 22  15  5  0  0 49   114
>     MatMult            14498 1.0 3.0545e+0382.7 5.50e+09 1.0 6.4e+06
>     7.6e+03 0.0e+00  9 12  8 44  0  21 27 16 98  0   169
> This load imbalance is totally unreasonable. Either you have an
> atrocious partition or there is contention on the machine
> (over-subscribed or other things running). The load balance for
> MatMult() should be close to 1.0 and the MFlop/s (last column) should
> be at least 10000 or so.
>     MatMultAdd          2881 1.0 1.8177e+0218.6 1.09e+09 1.1 3.6e+06
>     1.5e+01 0.0e+00  1  2  4  0  0   2  5  9  0  0   560
>     MatMultTranspose    2881 1.0 7.1296e+0274.9 1.09e+09 1.1 3.6e+06
>     1.5e+01 0.0e+00  5  2  4  0  0  11  5  9  0  0   143
>     MatSolve           14405 1.0 3.9663e+01 3.3 4.56e+09 1.0 0.0e+00
>     0.0e+00 0.0e+00  0 10  0  0  0   1 22  0  0  0 10890
>     MatLUFactorNum         5 1.0 3.9389e-02 1.6 3.05e+06 1.0 0.0e+00
>     0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  7322
>     MatILUFactorSym        5 1.0 4.2221e-02 3.2 0.00e+00 0.0 0.0e+00
>     0.0e+00 5.0e+00  0  0  0  0  0   0  0  0  0  0     0
>     MatGetRowIJ            5 1.0 9.7752e-06 5.1 0.00e+00 0.0 0.0e+00
>     MatGetOrdering         5 1.0 2.9373e-03 1.9 0.00e+00 0.0 0.0e+00
>     0.0e+00 1.0e+01  0  0  0  0  0   0  0  0  0  0     0
>     PCSetUp                5 1.0 8.3110e-02 2.0 3.05e+06 1.0 0.0e+00
>     0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  0  3470
>     PCSetUpOnBlocks     5762 1.0 9.9790e-02 2.0 3.05e+06 1.0 0.0e+00
>     0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  0  2890
>     PCApply             2881 1.0 3.3151e+03 1.0 1.37e+10 1.0 3.8e+07
>     1.0e+03 1.7e+04 36 31 46 36 33  82 67 97 80 73   390
>            BTW, how to really calculate the time that a function
>     costs? For example, it shows that "VecMDot, 2.0424e+0313.5". Would
>     that be 2.0424*10^313.5 sec?
> No, the imbalance is just spilling over. The amount of time is 2042
> seconds.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20121005/22d36e60/attachment-0001.html>
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
NumRank = 48
node = 11 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 11 xs = 114  ys = 48  zs = 0  xw = 38  yw = 48  zw = 32
node = 12 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 12 xs = 152  ys = 48  zs = 0  xw = 37  yw = 48  zw = 32
node = 28 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 28 xs = 152  ys = 48  zs = 32  xw = 37  yw = 48  zw = 32
node = 36 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 36 xs = 152  ys = 0  zs = 64  xw = 37  yw = 48  zw = 32
node = 44 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 44 xs = 152  ys = 48  zs = 64  xw = 37  yw = 48  zw = 32
node = 43 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 43 xs = 114  ys = 48  zs = 64  xw = 38  yw = 48  zw = 32
node = 27 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 27 xs = 114  ys = 48  zs = 32  xw = 38  yw = 48  zw = 32
node = 19 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 19 xs = 114  ys = 0  zs = 32  xw = 38  yw = 48  zw = 32
node = 3 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 3 xs = 114  ys = 0  zs = 0  xw = 38  yw = 48  zw = 32
node = 35 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 35 xs = 114  ys = 0  zs = 64  xw = 38  yw = 48  zw = 32
node = 2 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 2 xs = 76  ys = 0  zs = 0  xw = 38  yw = 48  zw = 32
node = 0 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 0 xs = 0  ys = 0  zs = 0  xw = 38  yw = 48  zw = 32
node = 18 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 18 xs = 76  ys = 0  zs = 32  xw = 38  yw = 48  zw = 32
node = 10 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 10 xs = 76  ys = 48  zs = 0  xw = 38  yw = 48  zw = 32
node = 8 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 8 xs = 0  ys = 48  zs = 0  xw = 38  yw = 48  zw = 32
node = 32 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 32 xs = 0  ys = 0  zs = 64  xw = 38  yw = 48  zw = 32
node = 33 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 33 xs = 38  ys = 0  zs = 64  xw = 38  yw = 48  zw = 32
node = 1 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 1 xs = 38  ys = 0  zs = 0  xw = 38  yw = 48  zw = 32
node = 16 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 16 xs = 0  ys = 0  zs = 32  xw = 38  yw = 48  zw = 32
node = 24 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 24 xs = 0  ys = 48  zs = 32  xw = 38  yw = 48  zw = 32
node = 40 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 34 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 34 xs = 76  ys = 0  zs = 64  xw = 38  yw = 48  zw = 32
node = 26 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 26 xs = 76  ys = 48  zs = 32  xw = 38  yw = 48  zw = 32
node = 40 xs = 0  ys = 48  zs = 64  xw = 38  yw = 48  zw = 32
node = 42 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 42 xs = 76  ys = 48  zs = 64  xw = 38  yw = 48  zw = 32
node = 13 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 13 xs = 189  ys = 48  zs = 0  xw = 37  yw = 48  zw = 32
node = 21 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 21 xs = 189  ys = 0  zs = 32  xw = 37  yw = 48  zw = 32
node = 45 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 45 xs = 189  ys = 48  zs = 64  xw = 37  yw = 48  zw = 32
node = 37 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 37 xs = 189  ys = 0  zs = 64  xw = 37  yw = 48  zw = 32
node = 38 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 38 xs = 226  ys = 0  zs = 64  xw = 37  yw = 48  zw = 32
node = 39 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 39 xs = 263  ys = 0  zs = 64  xw = 37  yw = 48  zw = 32
node = 47 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 47 xs = 263  ys = 48  zs = 64  xw = 37  yw = 48  zw = 32
node = 25 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 25 xs = 38  ys = 48  zs = 32  xw = 38  yw = 48  zw = 32
node = 41 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 41 xs = 38  ys = 48  zs = 64  xw = 38  yw = 48  zw = 32
node = 17 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 17 xs = 38  ys = 0  zs = 32  xw = 38  yw = 48  zw = 32
node = 29 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 29 xs = 189  ys = 48  zs = 32  xw = 37  yw = 48  zw = 32
node = 31 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 31 xs = 263  ys = 48  zs = 32  xw = 37  yw = 48  zw = 32
node = 9 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 9 xs = 38  ys = 48  zs = 0  xw = 38  yw = 48  zw = 32
node = 20 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 20 xs = 152  ys = 0  zs = 32  xw = 37  yw = 48  zw = 32
node = 15 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 15 xs = 263  ys = 48  zs = 0  xw = 37  yw = 48  zw = 32
node = 23 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 23 xs = 263  ys = 0  zs = 32  xw = 37  yw = 48  zw = 32
node = 4 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 4 xs = 152  ys = 0  zs = 0  xw = 37  yw = 48  zw = 32
node = 6 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 6 xs = 226  ys = 0  zs = 0  xw = 37  yw = 48  zw = 32
node = 7 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 7 xs = 263  ys = 0  zs = 0  xw = 37  yw = 48  zw = 32
node = 22 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 22 xs = 226  ys = 0  zs = 32  xw = 37  yw = 48  zw = 32
node = 30 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 30 xs = 226  ys = 48  zs = 32  xw = 37  yw = 48  zw = 32
node = 5 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 5 xs = 189  ys = 0  zs = 0  xw = 37  yw = 48  zw = 32
node = 14 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 14 xs = 226  ys = 48  zs = 0  xw = 37  yw = 48  zw = 32
node = 46 mx = 300  my = 96  mz = 96  mm = 8  nn = 2  pp = 3
node = 46 xs = 226  ys = 48  zs = 64  xw = 37  yw = 48  zw = 32
rank 18 Cylinder: neighbor = left: 108 right: 114  bottom: 35  top: 48  aft: 35  front: 59
rank = 18, NbrRanks are: L: 17, R: 19, B:10, T:26, A:2, F:34!!
rank = 18: xs = 76, ys = 0, zs = 32, mx = 300, my = 96, mz = 96!
rank = 18:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 0, front BC = 0
rank = 18:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 10 Cylinder: neighbor = left: 108 right: 114  bottom: 48  top: 59  aft: 35  front: 32
rank = 10, NbrRanks are: L: 9, R: 11, B:2, T:18, A:-6, F:26!!
rank = 10: xs = 76, ys = 48, zs = 0, mx = 300, my = 96, mz = 96!
rank = 10:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 1, front BC = 0
rank = 10:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 46 Cylinder: neighbor = left: 226 right: 132  bottom: 48  top: 59  aft: 64  front: 59
rank 9 Cylinder: neighbor = left: 108 right: 76  bottom: 48  top: 59  aft: 35  front: 32
rank = 46, NbrRanks are: L: 45, R: 47, B:38, T:54, A:30, F:62!!
rank = 9, NbrRanks are: L: 8, R: 10, B:1, T:17, A:-7, F:25!!
rank = 46: xs = 226, ys = 48, zs = 64, mx = 300, my = 96, mz = 96!
rank = 9: xs = 38, ys = 48, zs = 0, mx = 300, my = 96, mz = 96!
rank = 46:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 0, front BC = 1
rank = 9:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 1, front BC = 0
rank = 46:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank = 9:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 11 Cylinder: neighbor = left: 114 right: 132  bottom: 48  top: 59  aft: 35  front: 32
rank = 11, NbrRanks are: L: 10, R: 12, B:3, T:19, A:-5, F:27!!
rank = 11: xs = 114, ys = 48, zs = 0, mx = 300, my = 96, mz = 96!
rank = 11:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 1, front BC = 0
rank = 11:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 45 Cylinder: neighbor = left: 189 right: 132  bottom: 48  top: 59  aft: 64  front: 59
rank = 45, NbrRanks are: L: 44, R: 46, B:37, T:53, A:29, F:61!!
rank 6 Cylinder: neighbor = left: 226 right: 132  bottom: 35  top: 48  aft: 35  front: 32
rank = 6, NbrRanks are: L: 5, R: 7, B:-2, T:14, A:-10, F:22!!
rank = 6: xs = 226, ys = 0, zs = 0, mx = 300, my = 96, mz = 96!
rank = 6:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 1, front BC = 0
rank = 6:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank = 45: xs = 189, ys = 48, zs = 64, mx = 300, my = 96, mz = 96!
rank = 45:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 0, front BC = 1
rank = 45:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 47 Cylinder: neighbor = left: 263 right: 132  bottom: 48  top: 59  aft: 64  front: 59
rank 8 Cylinder: neighbor = left: 108 right: 38  bottom: 48  top: 59  aft: 35  front: 32
rank = 8, NbrRanks are: L: 7, R: 9, B:0, T:16, A:-8, F:24!!
rank = 8: xs = 0, ys = 48, zs = 0, mx = 300, my = 96, mz = 96!
rank = 8:  left BC = 1,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 1, front BC = 0
rank = 8:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 44 Cylinder: neighbor = left: 152 right: 132  bottom: 48  top: 59  aft: 64  front: 59
rank = 44, NbrRanks are: L: 43, R: 45, B:36, T:52, A:28, F:60!!
rank = 44: xs = 152, ys = 48, zs = 64, mx = 300, my = 96, mz = 96!
rank = 44:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 0, front BC = 1
rank = 44:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank = 47, NbrRanks are: L: 46, R: 48, B:39, T:55, A:31, F:63!!
rank = 47: xs = 263, ys = 48, zs = 64, mx = 300, my = 96, mz = 96!
rank = 47:  left BC = 0,  rightBC = 1, bottom BC = 0, top BC = 1, aft BC = 0, front BC = 1
rank = 47:  xc = 36, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 16 Cylinder: neighbor = left: 108 right: 38  bottom: 35  top: 48  aft: 35  front: 59
rank = 16, NbrRanks are: L: 15, R: 17, B:8, T:24, A:0, F:32!!
rank = 16: xs = 0, ys = 0, zs = 32, mx = 300, my = 96, mz = 96!
rank = 16:  left BC = 1,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 0, front BC = 0
rank = 16:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 17 Cylinder: neighbor = left: 108 right: 76  bottom: 35  top: 48  aft: 35  front: 59
rank = 17, NbrRanks are: L: 16, R: 18, B:9, T:25, A:1, F:33!!
rank = 17: xs = 38, ys = 0, zs = 32, mx = 300, my = 96, mz = 96!
rank = 17:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 0, front BC = 0
rank = 17:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 19 Cylinder: neighbor = left: 114 right: 132  bottom: 35  top: 48  aft: 35  front: 59
rank = 19, NbrRanks are: L: 18, R: 20, B:11, T:27, A:3, F:35!!
rank = 19: xs = 114, ys = 0, zs = 32, mx = 300, my = 96, mz = 96!
rank = 19:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 0, front BC = 0
rank = 19:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 4 Cylinder: neighbor = left: 152 right: 132  bottom: 35  top: 48  aft: 35  front: 32
rank = 4, NbrRanks are: L: 3, R: 5, B:-4, T:12, A:-12, F:20!!
rank = 4: xs = 152, ys = 0, zs = 0, mx = 300, my = 96, mz = 96!
rank = 4:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 1, front BC = 0
rank = 4:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 5 Cylinder: neighbor = left: 189 right: 132  bottom: 35  top: 48  aft: 35  front: 32
rank = 5, NbrRanks are: L: 4, R: 6, B:-3, T:13, A:-11, F:21!!
rank = 5: xs = 189, ys = 0, zs = 0, mx = 300, my = 96, mz = 96!
rank = 5:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 1, front BC = 0
rank = 5:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 7 Cylinder: neighbor = left: 263 right: 132  bottom: 35  top: 48  aft: 35  front: 32
rank = 7, NbrRanks are: L: 6, R: 8, B:-1, T:15, A:-9, F:23!!
rank = 7: xs = 263, ys = 0, zs = 0, mx = 300, my = 96, mz = 96!
rank = 7:  left BC = 0,  rightBC = 1, bottom BC = 1, top BC = 0, aft BC = 1, front BC = 0
rank = 7:  xc = 36, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 38 Cylinder: neighbor = left: 226 right: 132  bottom: 35  top: 48  aft: 64  front: 59
rank = 38, NbrRanks are: L: 37, R: 39, B:30, T:46, A:22, F:54!!
rank = 38: xs = 226, ys = 0, zs = 64, mx = 300, my = 96, mz = 96!
rank = 38:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 0, front BC = 1
rank = 38:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 14 Cylinder: neighbor = left: 226 right: 132  bottom: 48  top: 59  aft: 35  front: 32
rank = 14, NbrRanks are: L: 13, R: 15, B:6, T:22, A:-2, F:30!!
rank = 14: xs = 226, ys = 48, zs = 0, mx = 300, my = 96, mz = 96!
rank = 14:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 1, front BC = 0
rank = 14:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 22 Cylinder: neighbor = left: 226 right: 132  bottom: 35  top: 48  aft: 35  front: 59
rank = 22, NbrRanks are: L: 21, R: 23, B:14, T:30, A:6, F:38!!
rank = 22: xs = 226, ys = 0, zs = 32, mx = 300, my = 96, mz = 96!
rank = 22:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 0, front BC = 0
rank = 22:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 37 Cylinder: neighbor = left: 189 right: 132  bottom: 35  top: 48  aft: 64  front: 59
rank = 37, NbrRanks are: L: 36, R: 38, B:29, T:45, A:21, F:53!!
rank = 37: xs = 189, ys = 0, zs = 64, mx = 300, my = 96, mz = 96!
rank 13 Cylinder: neighbor = left: 189 right: 132  bottom: 48  top: 59  aft: 35  front: 32
rank 21 Cylinder: neighbor = left: 189 right: 132  bottom: 35  top: 48  aft: 35  front: 59
rank 0 Cylinder: neighbor = left: 108 right: 38  bottom: 35  top: 48  aft: 35  front: 32
rank = 0, NbrRanks are: L: -1, R: 1, B:-8, T:8, A:-16, F:16!!
rank = 0: xs = 0, ys = 0, zs = 0, mx = 300, my = 96, mz = 96!
rank = 0:  left BC = 1,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 1, front BC = 0
rank = 0:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank = 37:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 0, front BC = 1
rank = 37:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank = 13, NbrRanks are: L: 12, R: 14, B:5, T:21, A:-3, F:29!!
rank = 13: xs = 189, ys = 48, zs = 0, mx = 300, my = 96, mz = 96!
rank = 13:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 1, front BC = 0
rank = 21, NbrRanks are: L: 20, R: 22, B:13, T:29, A:5, F:37!!
rank = 21: xs = 189, ys = 0, zs = 32, mx = 300, my = 96, mz = 96!
rank = 21:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 0, front BC = 0
rank 2 Cylinder: neighbor = left: 108 right: 114  bottom: 35  top: 48  aft: 35  front: 32
rank = 2, NbrRanks are: L: 1, R: 3, B:-6, T:10, A:-14, F:18!!
rank = 2: xs = 76, ys = 0, zs = 0, mx = 300, my = 96, mz = 96!
rank = 2:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 1, front BC = 0
rank = 2:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank = 13:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank = 21:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 3 Cylinder: neighbor = left: 114 right: 132  bottom: 35  top: 48  aft: 35  front: 32
rank = 3, NbrRanks are: L: 2, R: 4, B:-5, T:11, A:-13, F:19!!
rank = 3: xs = 114, ys = 0, zs = 0, mx = 300, my = 96, mz = 96!
rank = 3:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 1, front BC = 0
rank = 3:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 20 Cylinder: neighbor = left: 152 right: 132  bottom: 35  top: 48  aft: 35  front: 59
rank = 20, NbrRanks are: L: 19, R: 21, B:12, T:28, A:4, F:36!!
rank = 20: xs = 152, ys = 0, zs = 32, mx = 300, my = 96, mz = 96!
rank = 20:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 0, front BC = 0
rank = 20:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 12 Cylinder: neighbor = left: 152 right: 132  bottom: 48  top: 59  aft: 35  front: 32
rank = 12, NbrRanks are: L: 11, R: 13, B:4, T:20, A:-4, F:28!!
rank = 12: xs = 152, ys = 48, zs = 0, mx = 300, my = 96, mz = 96!
rank 15 Cylinder: neighbor = left: 263 right: 132  bottom: 48  top: 59  aft: 35  front: 32
rank = 15, NbrRanks are: L: 14, R: 16, B:7, T:23, A:-1, F:31!!
rank = 15: xs = 263, ys = 48, zs = 0, mx = 300, my = 96, mz = 96!
rank = 12:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 1, front BC = 0
rank = 12:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank = 15:  left BC = 0,  rightBC = 1, bottom BC = 0, top BC = 1, aft BC = 1, front BC = 0
rank = 15:  xc = 36, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 24 Cylinder: neighbor = left: 108 right: 38  bottom: 48  top: 59  aft: 35  front: 59
rank = 24, NbrRanks are: L: 23, R: 25, B:16, T:32, A:8, F:40!!
rank = 24: xs = 0, ys = 48, zs = 32, mx = 300, my = 96, mz = 96!
rank = 24:  left BC = 1,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 0, front BC = 0
rank = 24:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 36 Cylinder: neighbor = left: 152 right: 132  bottom: 35  top: 48  aft: 64  front: 59
rank = 36, NbrRanks are: L: 35, R: 37, B:28, T:44, A:20, F:52!!
rank = 36: xs = 152, ys = 0, zs = 64, mx = 300, my = 96, mz = 96!
rank = 36:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 0, front BC = 1
rank = 36:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 40 Cylinder: neighbor = left: 108 right: 38  bottom: 48  top: 59  aft: 64  front: 59
rank = 40, NbrRanks are: L: 39, R: 41, B:32, T:48, A:24, F:56!!
rank = 40: xs = 0, ys = 48, zs = 64, mx = 300, my = 96, mz = 96!
rank = 40:  left BC = 1,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 0, front BC = 1
rank = 40:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 28 Cylinder: neighbor = left: 152 right: 132  bottom: 48  top: 59  aft: 35  front: 59
rank = 28, NbrRanks are: L: 27, R: 29, B:20, T:36, A:12, F:44!!
rank = 28: xs = 152, ys = 48, zs = 32, mx = 300, my = 96, mz = 96!
rank = 28:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 0, front BC = 0
rank = 28:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 23 Cylinder: neighbor = left: 263 right: 132  bottom: 35  top: 48  aft: 35  front: 59
rank = 23, NbrRanks are: L: 22, R: 24, B:15, T:31, A:7, F:39!!
rank = 23: xs = 263, ys = 0, zs = 32, mx = 300, my = 96, mz = 96!
rank = 23:  left BC = 0,  rightBC = 1, bottom BC = 1, top BC = 0, aft BC = 0, front BC = 0
rank = 23:  xc = 36, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 25 Cylinder: neighbor = left: 108 right: 76  bottom: 48  top: 59  aft: 35  front: 59
rank = 25, NbrRanks are: L: 24, R: 26, B:17, T:33, A:9, F:41!!
rank = 25: xs = 38, ys = 48, zs = 32, mx = 300, my = 96, mz = 96!
rank = 25:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 0, front BC = 0
rank = 25:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 39 Cylinder: neighbor = left: 263 right: 132  bottom: 35  top: 48  aft: 64  front: 59
rank = 39, NbrRanks are: L: 38, R: 40, B:31, T:47, A:23, F:55!!
rank = 39: xs = 263, ys = 0, zs = 64, mx = 300, my = 96, mz = 96!
rank = 39:  left BC = 0,  rightBC = 1, bottom BC = 1, top BC = 0, aft BC = 0, front BC = 1
rank = 39:  xc = 36, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 41 Cylinder: neighbor = left: 108 right: 76  bottom: 48  top: 59  aft: 64  front: 59
rank = 41, NbrRanks are: L: 40, R: 42, B:33, T:49, A:25, F:57!!
rank = 41: xs = 38, ys = 48, zs = 64, mx = 300, my = 96, mz = 96!
rank = 41:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 0, front BC = 1
rank = 41:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 29 Cylinder: neighbor = left: 189 right: 132  bottom: 48  top: 59  aft: 35  front: 59
rank = 29, NbrRanks are: L: 28, R: 30, B:21, T:37, A:13, F:45!!
rank = 29: xs = 189, ys = 48, zs = 32, mx = 300, my = 96, mz = 96!
rank = 29:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 0, front BC = 0
rank = 29:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 26 Cylinder: neighbor = left: 108 right: 114  bottom: 48  top: 59  aft: 35  front: 59
rank = 26, NbrRanks are: L: 25, R: 27, B:18, T:34, A:10, F:42!!
rank = 26: xs = 76, ys = 48, zs = 32, mx = 300, my = 96, mz = 96!
rank = 26:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 0, front BC = 0
rank = 26:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 42 Cylinder: neighbor = left: 108 right: 114  bottom: 48  top: 59  aft: 64  front: 59
rank = 42, NbrRanks are: L: 41, R: 43, B:34, T:50, A:26, F:58!!
rank = 42: xs = 76, ys = 48, zs = 64, mx = 300, my = 96, mz = 96!
rank = 42:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 0, front BC = 1
rank = 42:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 30 Cylinder: neighbor = left: 226 right: 132  bottom: 48  top: 59  aft: 35  front: 59
rank = 30, NbrRanks are: L: 29, R: 31, B:22, T:38, A:14, F:46!!
rank = 30: xs = 226, ys = 48, zs = 32, mx = 300, my = 96, mz = 96!
rank = 30:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 0, front BC = 0
rank = 30:  xc = 37, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 27 Cylinder: neighbor = left: 114 right: 132  bottom: 48  top: 59  aft: 35  front: 59
rank = 27, NbrRanks are: L: 26, R: 28, B:19, T:35, A:11, F:43!!
rank = 27: xs = 114, ys = 48, zs = 32, mx = 300, my = 96, mz = 96!
rank = 27:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 0, front BC = 0
rank = 27:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 43 Cylinder: neighbor = left: 114 right: 132  bottom: 48  top: 59  aft: 64  front: 59
rank = 43, NbrRanks are: L: 42, R: 44, B:35, T:51, A:27, F:59!!
rank = 43: xs = 114, ys = 48, zs = 64, mx = 300, my = 96, mz = 96!
rank = 43:  left BC = 0,  rightBC = 0, bottom BC = 0, top BC = 1, aft BC = 0, front BC = 1
rank = 43:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 31 Cylinder: neighbor = left: 263 right: 132  bottom: 48  top: 59  aft: 35  front: 59
rank = 31, NbrRanks are: L: 30, R: 32, B:23, T:39, A:15, F:47!!
rank = 31: xs = 263, ys = 48, zs = 32, mx = 300, my = 96, mz = 96!
rank = 31:  left BC = 0,  rightBC = 1, bottom BC = 0, top BC = 1, aft BC = 0, front BC = 0
rank = 31:  xc = 36, yc = 48, zc = 32, xw = 37, yw = 48, zw = 32
rank 1 Cylinder: neighbor = left: 108 right: 76  bottom: 35  top: 48  aft: 35  front: 32
rank = 1, NbrRanks are: L: 0, R: 2, B:-7, T:9, A:-15, F:17!!
rank = 1: xs = 38, ys = 0, zs = 0, mx = 300, my = 96, mz = 96!
rank = 1:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 1, front BC = 0
rank = 1:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 32 Cylinder: neighbor = left: 108 right: 38  bottom: 35  top: 48  aft: 64  front: 59
rank = 32, NbrRanks are: L: 31, R: 33, B:24, T:40, A:16, F:48!!
rank = 32: xs = 0, ys = 0, zs = 64, mx = 300, my = 96, mz = 96!
rank = 32:  left BC = 1,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 0, front BC = 1
rank = 32:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 33 Cylinder: neighbor = left: 108 right: 76  bottom: 35  top: 48  aft: 64  front: 59
rank = 33, NbrRanks are: L: 32, R: 34, B:25, T:41, A:17, F:49!!
rank = 33: xs = 38, ys = 0, zs = 64, mx = 300, my = 96, mz = 96!
rank = 33:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 0, front BC = 1
rank = 33:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 34 Cylinder: neighbor = left: 108 right: 114  bottom: 35  top: 48  aft: 64  front: 59
rank = 34, NbrRanks are: L: 33, R: 35, B:26, T:42, A:18, F:50!!
rank = 34: xs = 76, ys = 0, zs = 64, mx = 300, my = 96, mz = 96!
rank = 34:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 0, front BC = 1
rank = 34:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
rank 35 Cylinder: neighbor = left: 114 right: 132  bottom: 35  top: 48  aft: 64  front: 59
rank = 35, NbrRanks are: L: 34, R: 36, B:27, T:43, A:19, F:51!!
rank = 35: xs = 114, ys = 0, zs = 64, mx = 300, my = 96, mz = 96!
rank = 35:  left BC = 0,  rightBC = 0, bottom BC = 1, top BC = 0, aft BC = 0, front BC = 1
rank = 35:  xc = 38, yc = 48, zc = 32, xw = 38, yw = 48, zw = 32
Current time step = 0, Total time step number = 5
  0 KSP unpreconditioned resid norm 2.823135537733e+00 true resid norm 2.823135537733e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 2.154307416984e-01 true resid norm 2.154307416984e-01 ||r(i)||/||b|| 7.630903257002e-02
  2 KSP unpreconditioned resid norm 6.616308524617e-02 true resid norm 6.616308524617e-02 ||r(i)||/||b|| 2.343602861494e-02
  3 KSP unpreconditioned resid norm 3.244770285497e-02 true resid norm 3.244770285497e-02 ||r(i)||/||b|| 1.149349807024e-02
  4 KSP unpreconditioned resid norm 2.037399364799e-02 true resid norm 2.037399364799e-02 ||r(i)||/||b|| 7.216796138789e-03
  5 KSP unpreconditioned resid norm 1.115303682743e-02 true resid norm 1.115303682743e-02 ||r(i)||/||b|| 3.950584971341e-03
  6 KSP unpreconditioned resid norm 7.349490089262e-03 true resid norm 7.349490089262e-03 ||r(i)||/||b|| 2.603307560346e-03
  7 KSP unpreconditioned resid norm 5.032355046504e-03 true resid norm 5.032355046504e-03 ||r(i)||/||b|| 1.782541071530e-03
  8 KSP unpreconditioned resid norm 3.412030504773e-03 true resid norm 3.412030504773e-03 ||r(i)||/||b|| 1.208596066030e-03
  9 KSP unpreconditioned resid norm 2.506624879726e-03 true resid norm 2.506624879726e-03 ||r(i)||/||b|| 8.878868358331e-04
 10 KSP unpreconditioned resid norm 1.911583249761e-03 true resid norm 1.911583249761e-03 ||r(i)||/||b|| 6.771135229646e-04
 11 KSP unpreconditioned resid norm 1.450523741360e-03 true resid norm 1.450523741359e-03 ||r(i)||/||b|| 5.137988318210e-04
 12 KSP unpreconditioned resid norm 1.165820441830e-03 true resid norm 1.165820441830e-03 ||r(i)||/||b|| 4.129523454500e-04
 13 KSP unpreconditioned resid norm 9.075966183811e-04 true resid norm 9.075966183811e-04 ||r(i)||/||b|| 3.214853152640e-04
 14 KSP unpreconditioned resid norm 7.190731823975e-04 true resid norm 7.190731823977e-04 ||r(i)||/||b|| 2.547072830145e-04
 15 KSP unpreconditioned resid norm 5.738556352769e-04 true resid norm 5.738556352768e-04 ||r(i)||/||b|| 2.032688929054e-04
 16 KSP unpreconditioned resid norm 4.542858026836e-04 true resid norm 4.542858026837e-04 ||r(i)||/||b|| 1.609153356656e-04
 17 KSP unpreconditioned resid norm 3.691546556208e-04 true resid norm 3.691546556209e-04 ||r(i)||/||b|| 1.307605145722e-04
 18 KSP unpreconditioned resid norm 3.023816670689e-04 true resid norm 3.023816670686e-04 ||r(i)||/||b|| 1.071084483997e-04
 19 KSP unpreconditioned resid norm 2.446493662857e-04 true resid norm 2.446493662856e-04 ||r(i)||/||b|| 8.665873919820e-05
 20 KSP unpreconditioned resid norm 2.063235929689e-04 true resid norm 2.063235929687e-04 ||r(i)||/||b|| 7.308313405824e-05
 21 KSP unpreconditioned resid norm 1.690424749200e-04 true resid norm 1.690424749199e-04 ||r(i)||/||b|| 5.987756261099e-05
 22 KSP unpreconditioned resid norm 1.401907850897e-04 true resid norm 1.401907850896e-04 ||r(i)||/||b|| 4.965783017354e-05
 23 KSP unpreconditioned resid norm 1.144389156826e-04 true resid norm 1.144389156828e-04 ||r(i)||/||b|| 4.053610397137e-05
 24 KSP unpreconditioned resid norm 8.920795008676e-05 true resid norm 8.920795008653e-05 ||r(i)||/||b|| 3.159889027438e-05
 25 KSP unpreconditioned resid norm 6.909908488215e-05 true resid norm 6.909908488195e-05 ||r(i)||/||b|| 2.447600689319e-05
 26 KSP unpreconditioned resid norm 5.266847004343e-05 true resid norm 5.266847004323e-05 ||r(i)||/||b|| 1.865601893330e-05
 27 KSP unpreconditioned resid norm 4.064559966622e-05 true resid norm 4.064559966603e-05 ||r(i)||/||b|| 1.439732493278e-05
 28 KSP unpreconditioned resid norm 3.171947373934e-05 true resid norm 3.171947373916e-05 ||r(i)||/||b|| 1.123554760840e-05
 29 KSP unpreconditioned resid norm 2.462933869897e-05 true resid norm 2.462933869893e-05 ||r(i)||/||b|| 8.724107776529e-06
 30 KSP unpreconditioned resid norm 1.822375473757e-05 true resid norm 1.822375473757e-05 ||r(i)||/||b|| 6.455146943529e-06
 31 KSP unpreconditioned resid norm 1.574617811541e-05 true resid norm 1.574617811542e-05 ||r(i)||/||b|| 5.577549467591e-06
 32 KSP unpreconditioned resid norm 1.307785144339e-05 true resid norm 1.307785144340e-05 ||r(i)||/||b|| 4.632385256962e-06
 33 KSP unpreconditioned resid norm 1.142770280984e-05 true resid norm 1.142770280984e-05 ||r(i)||/||b|| 4.047876078603e-06
 34 KSP unpreconditioned resid norm 9.171371046918e-06 true resid norm 9.171371046933e-06 ||r(i)||/||b|| 3.248647089150e-06
 35 KSP unpreconditioned resid norm 7.576417541607e-06 true resid norm 7.576417541619e-06 ||r(i)||/||b|| 2.683688912684e-06
 36 KSP unpreconditioned resid norm 6.341122445581e-06 true resid norm 6.341122445582e-06 ||r(i)||/||b|| 2.246127527648e-06
 37 KSP unpreconditioned resid norm 5.520660583479e-06 true resid norm 5.520660583471e-06 ||r(i)||/||b|| 1.955506744074e-06
 38 KSP unpreconditioned resid norm 4.758050788581e-06 true resid norm 4.758050788571e-06 ||r(i)||/||b|| 1.685378092896e-06
 39 KSP unpreconditioned resid norm 4.119934417329e-06 true resid norm 4.119934417327e-06 ||r(i)||/||b|| 1.459347014078e-06
 40 KSP unpreconditioned resid norm 3.423330512164e-06 true resid norm 3.423330512170e-06 ||r(i)||/||b|| 1.212598710340e-06
 41 KSP unpreconditioned resid norm 2.843937477031e-06 true resid norm 2.843937477043e-06 ||r(i)||/||b|| 1.007368381373e-06
 42 KSP unpreconditioned resid norm 2.247136771553e-06 true resid norm 2.247136771556e-06 ||r(i)||/||b|| 7.959719756711e-07
 43 KSP unpreconditioned resid norm 1.767055534296e-06 true resid norm 1.767055534289e-06 ||r(i)||/||b|| 6.259194823171e-07
 44 KSP unpreconditioned resid norm 1.330561337297e-06 true resid norm 1.330561337289e-06 ||r(i)||/||b|| 4.713062194518e-07
 45 KSP unpreconditioned resid norm 1.002587660836e-06 true resid norm 1.002587660849e-06 ||r(i)||/||b|| 3.551326698448e-07
 46 KSP unpreconditioned resid norm 7.571869187267e-07 true resid norm 7.571869187577e-07 ||r(i)||/||b|| 2.682077812551e-07
 47 KSP unpreconditioned resid norm 5.557160212082e-07 true resid norm 5.557160212518e-07 ||r(i)||/||b|| 1.968435499551e-07
 48 KSP unpreconditioned resid norm 4.235338619283e-07 true resid norm 4.235338619715e-07 ||r(i)||/||b|| 1.500225038121e-07
 49 KSP unpreconditioned resid norm 3.213108718199e-07 true resid norm 3.213108718685e-07 ||r(i)||/||b|| 1.138134770981e-07
 50 KSP unpreconditioned resid norm 2.465819253483e-07 true resid norm 2.465819253946e-07 ||r(i)||/||b|| 8.734328270778e-08
Linear solve converged due to CONVERGED_RTOL iterations 50
Residual norm 2.46582e-07
  0 KSP unpreconditioned resid norm 2.464333785299e+00 true resid norm 2.464333785299e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 1.992196609304e-01 true resid norm 1.992196609304e-01 ||r(i)||/||b|| 8.084118398199e-02
  2 KSP unpreconditioned resid norm 6.477029955211e-02 true resid norm 6.477029955211e-02 ||r(i)||/||b|| 2.628308711202e-02
  3 KSP unpreconditioned resid norm 3.257461563671e-02 true resid norm 3.257461563671e-02 ||r(i)||/||b|| 1.321842675332e-02
  4 KSP unpreconditioned resid norm 2.205871203061e-02 true resid norm 2.205871203061e-02 ||r(i)||/||b|| 8.951186792227e-03
  5 KSP unpreconditioned resid norm 1.279229701970e-02 true resid norm 1.279229701970e-02 ||r(i)||/||b|| 5.190975790704e-03
  6 KSP unpreconditioned resid norm 8.642476440830e-03 true resid norm 8.642476440830e-03 ||r(i)||/||b|| 3.507023477252e-03
  7 KSP unpreconditioned resid norm 6.257653902253e-03 true resid norm 6.257653902254e-03 ||r(i)||/||b|| 2.539288281313e-03
  8 KSP unpreconditioned resid norm 4.265808118282e-03 true resid norm 4.265808118282e-03 ||r(i)||/||b|| 1.731018802619e-03
  9 KSP unpreconditioned resid norm 3.197638574989e-03 true resid norm 3.197638574989e-03 ||r(i)||/||b|| 1.297567153469e-03
 10 KSP unpreconditioned resid norm 2.541200054047e-03 true resid norm 2.541200054046e-03 ||r(i)||/||b|| 1.031191500602e-03
 11 KSP unpreconditioned resid norm 2.076630510557e-03 true resid norm 2.076630510557e-03 ||r(i)||/||b|| 8.426742038540e-04
 12 KSP unpreconditioned resid norm 1.800573752044e-03 true resid norm 1.800573752044e-03 ||r(i)||/||b|| 7.306533566131e-04
 13 KSP unpreconditioned resid norm 1.525854000374e-03 true resid norm 1.525854000374e-03 ||r(i)||/||b|| 6.191750522905e-04
 14 KSP unpreconditioned resid norm 1.295503220832e-03 true resid norm 1.295503220832e-03 ||r(i)||/||b|| 5.257011970377e-04
 15 KSP unpreconditioned resid norm 1.084042233066e-03 true resid norm 1.084042233065e-03 ||r(i)||/||b|| 4.398926150069e-04
 16 KSP unpreconditioned resid norm 9.072748281531e-04 true resid norm 9.072748281522e-04 ||r(i)||/||b|| 3.681623137111e-04
 17 KSP unpreconditioned resid norm 7.055698087217e-04 true resid norm 7.055698087231e-04 ||r(i)||/||b|| 2.863125981278e-04
 18 KSP unpreconditioned resid norm 5.647143297836e-04 true resid norm 5.647143297835e-04 ||r(i)||/||b|| 2.291549680292e-04
 19 KSP unpreconditioned resid norm 4.500753015708e-04 true resid norm 4.500753015704e-04 ||r(i)||/||b|| 1.826356901225e-04
 20 KSP unpreconditioned resid norm 3.751165957785e-04 true resid norm 3.751165957780e-04 ||r(i)||/||b|| 1.522182579388e-04
 21 KSP unpreconditioned resid norm 3.100897252663e-04 true resid norm 3.100897252655e-04 ||r(i)||/||b|| 1.258310571057e-04
 22 KSP unpreconditioned resid norm 2.538816813673e-04 true resid norm 2.538816813667e-04 ||r(i)||/||b|| 1.030224407429e-04
 23 KSP unpreconditioned resid norm 2.056390116417e-04 true resid norm 2.056390116429e-04 ||r(i)||/||b|| 8.344608708027e-05
 24 KSP unpreconditioned resid norm 1.608371013495e-04 true resid norm 1.608371013504e-04 ||r(i)||/||b|| 6.526595638539e-05
 25 KSP unpreconditioned resid norm 1.253589134032e-04 true resid norm 1.253589134030e-04 ||r(i)||/||b|| 5.086929138854e-05
 26 KSP unpreconditioned resid norm 9.775671156099e-05 true resid norm 9.775671156060e-05 ||r(i)||/||b|| 3.966861637971e-05
 27 KSP unpreconditioned resid norm 7.341573028295e-05 true resid norm 7.341573028263e-05 ||r(i)||/||b|| 2.979130940808e-05
 28 KSP unpreconditioned resid norm 5.564380420345e-05 true resid norm 5.564380420310e-05 ||r(i)||/||b|| 2.257965399616e-05
 29 KSP unpreconditioned resid norm 4.323591120259e-05 true resid norm 4.323591120220e-05 ||r(i)||/||b|| 1.754466519922e-05
 30 KSP unpreconditioned resid norm 3.368099812126e-05 true resid norm 3.368099812126e-05 ||r(i)||/||b|| 1.366738480078e-05
 31 KSP unpreconditioned resid norm 2.990017310739e-05 true resid norm 2.990017310738e-05 ||r(i)||/||b|| 1.213316689717e-05
 32 KSP unpreconditioned resid norm 2.518721971644e-05 true resid norm 2.518721971645e-05 ||r(i)||/||b|| 1.022070137848e-05
 33 KSP unpreconditioned resid norm 2.135321757357e-05 true resid norm 2.135321757358e-05 ||r(i)||/||b|| 8.664904771001e-06
 34 KSP unpreconditioned resid norm 1.708173255141e-05 true resid norm 1.708173255150e-05 ||r(i)||/||b|| 6.931582342212e-06
 35 KSP unpreconditioned resid norm 1.378692211645e-05 true resid norm 1.378692211657e-05 ||r(i)||/||b|| 5.594583898825e-06
 36 KSP unpreconditioned resid norm 1.075085218635e-05 true resid norm 1.075085218651e-05 ||r(i)||/||b|| 4.362579554216e-06
 37 KSP unpreconditioned resid norm 8.579543904874e-06 true resid norm 8.579543905050e-06 ||r(i)||/||b|| 3.481486134805e-06
 38 KSP unpreconditioned resid norm 6.663024149842e-06 true resid norm 6.663024149966e-06 ||r(i)||/||b|| 2.703783144034e-06
 39 KSP unpreconditioned resid norm 5.488872221286e-06 true resid norm 5.488872221412e-06 ||r(i)||/||b|| 2.227324989072e-06
 40 KSP unpreconditioned resid norm 4.402005575508e-06 true resid norm 4.402005575670e-06 ||r(i)||/||b|| 1.786286257945e-06
 41 KSP unpreconditioned resid norm 3.615398721527e-06 true resid norm 3.615398721731e-06 ||r(i)||/||b|| 1.467089703229e-06
 42 KSP unpreconditioned resid norm 2.967489745085e-06 true resid norm 2.967489745333e-06 ||r(i)||/||b|| 1.204175247296e-06
 43 KSP unpreconditioned resid norm 2.471957747140e-06 true resid norm 2.471957747409e-06 ||r(i)||/||b|| 1.003093721376e-06
 44 KSP unpreconditioned resid norm 2.088449399093e-06 true resid norm 2.088449399350e-06 ||r(i)||/||b|| 8.474701811129e-07
 45 KSP unpreconditioned resid norm 1.755508391147e-06 true resid norm 1.755508391304e-06 ||r(i)||/||b|| 7.123663205757e-07
 46 KSP unpreconditioned resid norm 1.489882203160e-06 true resid norm 1.489882203306e-06 ||r(i)||/||b|| 6.045780860507e-07
 47 KSP unpreconditioned resid norm 1.213783513857e-06 true resid norm 1.213783513883e-06 ||r(i)||/||b|| 4.925402237003e-07
 48 KSP unpreconditioned resid norm 1.021510479234e-06 true resid norm 1.021510479145e-06 ||r(i)||/||b|| 4.145179055040e-07
 49 KSP unpreconditioned resid norm 8.287946453344e-07 true resid norm 8.287946452356e-07 ||r(i)||/||b|| 3.363159041927e-07
 50 KSP unpreconditioned resid norm 6.668156473414e-07 true resid norm 6.668156471973e-07 ||r(i)||/||b|| 2.705865784802e-07
 51 KSP unpreconditioned resid norm 5.280582271016e-07 true resid norm 5.280582269962e-07 ||r(i)||/||b|| 2.142803179286e-07
 52 KSP unpreconditioned resid norm 4.157123103826e-07 true resid norm 4.157123102940e-07 ||r(i)||/||b|| 1.686915598747e-07
 53 KSP unpreconditioned resid norm 3.368064587348e-07 true resid norm 3.368064586986e-07 ||r(i)||/||b|| 1.366724186098e-07
 54 KSP unpreconditioned resid norm 2.710364540227e-07 true resid norm 2.710364539492e-07 ||r(i)||/||b|| 1.099836619398e-07
 55 KSP unpreconditioned resid norm 2.066135720810e-07 true resid norm 2.066135719884e-07 ||r(i)||/||b|| 8.384155312928e-08
Linear solve converged due to CONVERGED_RTOL iterations 55
Residual norm 2.06614e-07
Rank#24, time step = 0, continuity = 4.174955e-04 @ (41, 4, 4)
Rank#27, time step = 0, continuity = 4.094066e+00 @ (4, 11, 17)
Rank#10, time step = 0, continuity = 2.590009e-03 @ (39, 4, 35)
Rank#20, time step = 0, continuity = 1.437608e-02 @ (4, 51, 20)
Rank#11, time step = 0, continuity = 5.650684e-03 @ (4, 4, 35)
Rank#21, time step = 0, continuity = 9.027686e-03 @ (4, 51, 20)
Rank#1, time step = 0, continuity = 2.525042e-04 @ (4, 4, 4)
Rank#16, time step = 0, continuity = 3.678162e-04 @ (41, 51, 4)
Rank#4, time step = 0, continuity = 1.159767e-02 @ (4, 51, 35)
Rank#8, time step = 0, continuity = 4.915367e-05 @ (41, 4, 35)
Rank#34, time step = 0, continuity = 1.181571e-01 @ (40, 51, 4)
Rank#0, time step = 0, continuity = 3.137227e-08 @ (41, 51, 4)
Rank#17, time step = 0, continuity = 5.089529e-03 @ (41, 51, 4)
Rank#5, time step = 0, continuity = 8.826453e-03 @ (4, 51, 35)
Rank#2, time step = 0, continuity = 1.634919e-03 @ (4, 51, 35)
Rank#6, time step = 0, continuity = 8.433646e-03 @ (4, 51, 35)
Rank#12, time step = 0, continuity = 1.165931e-02 @ (4, 4, 35)
Rank#13, time step = 0, continuity = 8.826511e-03 @ (4, 5, 35)
Rank#14, time step = 0, continuity = 8.434087e-03 @ (4, 6, 35)
Rank#44, time step = 0, continuity = 1.167705e-02 @ (4, 4, 5)
Rank#45, time step = 0, continuity = 8.865762e-03 @ (4, 5, 4)
Rank#46, time step = 0, continuity = 8.451129e-03 @ (4, 6, 4)
Rank#25, time step = 0, continuity = 5.328321e-03 @ (41, 4, 4)
Rank#28, time step = 0, continuity = 1.454749e-02 @ (4, 4, 20)
Rank#33, time step = 0, continuity = 4.844833e-03 @ (41, 51, 4)
Rank#26, time step = 0, continuity = 1.016585e+00 @ (39, 4, 17)
Rank#40, time step = 0, continuity = 2.881710e-04 @ (41, 5, 4)
Rank#29, time step = 0, continuity = 9.027575e-03 @ (4, 5, 20)
Rank#32, time step = 0, continuity = 2.879931e-04 @ (41, 51, 4)
Rank#36, time step = 0, continuity = 1.161600e-02 @ (4, 51, 5)
Rank#41, time step = 0, continuity = 4.847584e-03 @ (41, 5, 4)
Rank#30, time step = 0, continuity = 8.459037e-03 @ (4, 6, 22)
Rank#37, time step = 0, continuity = 8.865921e-03 @ (4, 51, 4)
Rank#42, time step = 0, continuity = 1.182950e-01 @ (40, 5, 4)
Rank#31, time step = 0, continuity = 8.378688e-03 @ (4, 12, 28)
Rank#38, time step = 0, continuity = 8.450654e-03 @ (4, 51, 4)
Rank#43, time step = 0, continuity = 1.077929e-01 @ (4, 5, 4)
Rank#39, time step = 0, continuity = 8.377602e-03 @ (4, 51, 5)
Rank#35, time step = 0, continuity = 1.076056e-01 @ (4, 51, 4)
Rank#18, time step = 0, continuity = 9.940864e-02 @ (40, 51, 4)
Rank#9, time step = 0, continuity = 2.400260e-04 @ (4, 4, 35)
Rank#23, time step = 0, continuity = 8.378040e-03 @ (4, 51, 29)
Rank#22, time step = 0, continuity = 8.458582e-03 @ (4, 51, 22)
Rank#47, time step = 0, continuity = 8.378259e-03 @ (4, 12, 5)
Rank#3, time step = 0, continuity = 3.642321e-03 @ (4, 4, 4)
Rank#7, time step = 0, continuity = 8.373002e-03 @ (4, 51, 35)
Rank#15, time step = 0, continuity = 8.373655e-03 @ (4, 12, 35)
Rank#19, time step = 0, continuity = 4.094089e+00 @ (4, 45, 17)
Current time step = 1, Total time step number = 5
  0 KSP unpreconditioned resid norm 7.406650929703e+00 true resid norm 7.406650929703e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 5.561334348759e-01 true resid norm 5.561334348760e-01 ||r(i)||/||b|| 7.508568179523e-02
  2 KSP unpreconditioned resid norm 1.554698924650e-01 true resid norm 1.554698924650e-01 ||r(i)||/||b|| 2.099057913497e-02
  3 KSP unpreconditioned resid norm 5.829927905115e-02 true resid norm 5.829927905115e-02 ||r(i)||/||b|| 7.871206514857e-03
  4 KSP unpreconditioned resid norm 3.294371415430e-02 true resid norm 3.294371415430e-02 ||r(i)||/||b|| 4.447855645821e-03
  5 KSP unpreconditioned resid norm 2.126154585895e-02 true resid norm 2.126154585896e-02 ||r(i)||/||b|| 2.870601849709e-03
  6 KSP unpreconditioned resid norm 1.282632551143e-02 true resid norm 1.282632551143e-02 ||r(i)||/||b|| 1.731730796168e-03
  7 KSP unpreconditioned resid norm 8.505640366786e-03 true resid norm 8.505640366788e-03 ||r(i)||/||b|| 1.148378727108e-03
  8 KSP unpreconditioned resid norm 6.213706906443e-03 true resid norm 6.213706906443e-03 ||r(i)||/||b|| 8.389361082921e-04
  9 KSP unpreconditioned resid norm 4.308546423382e-03 true resid norm 4.308546423384e-03 ||r(i)||/||b|| 5.817131743181e-04
 10 KSP unpreconditioned resid norm 3.252806301386e-03 true resid norm 3.252806301386e-03 ||r(i)||/||b|| 4.391737010774e-04
 11 KSP unpreconditioned resid norm 2.550371639217e-03 true resid norm 2.550371639217e-03 ||r(i)||/||b|| 3.443353363649e-04
 12 KSP unpreconditioned resid norm 1.973664425127e-03 true resid norm 1.973664425127e-03 ||r(i)||/||b|| 2.664719107002e-04
 13 KSP unpreconditioned resid norm 1.548366484711e-03 true resid norm 1.548366484710e-03 ||r(i)||/||b|| 2.090508246448e-04
 14 KSP unpreconditioned resid norm 1.253035127943e-03 true resid norm 1.253035127943e-03 ||r(i)||/||b|| 1.691770193891e-04
 15 KSP unpreconditioned resid norm 9.627823525618e-04 true resid norm 9.627823525611e-04 ||r(i)||/||b|| 1.299888926451e-04
 16 KSP unpreconditioned resid norm 7.830570268883e-04 true resid norm 7.830570268888e-04 ||r(i)||/||b|| 1.057234955881e-04
 17 KSP unpreconditioned resid norm 6.258324642484e-04 true resid norm 6.258324642482e-04 ||r(i)||/||b|| 8.449601178563e-05
 18 KSP unpreconditioned resid norm 5.131714996563e-04 true resid norm 5.131714996560e-04 ||r(i)||/||b|| 6.928522817216e-05
 19 KSP unpreconditioned resid norm 4.157415220129e-04 true resid norm 4.157415220130e-04 ||r(i)||/||b|| 5.613083780495e-05
 20 KSP unpreconditioned resid norm 3.503809296735e-04 true resid norm 3.503809296738e-04 ||r(i)||/||b|| 4.730625663330e-05
 21 KSP unpreconditioned resid norm 2.855345717794e-04 true resid norm 2.855345717803e-04 ||r(i)||/||b|| 3.855110420220e-05
 22 KSP unpreconditioned resid norm 2.384533498881e-04 true resid norm 2.384533498885e-04 ||r(i)||/||b|| 3.219449008084e-05
 23 KSP unpreconditioned resid norm 1.934365375858e-04 true resid norm 1.934365375864e-04 ||r(i)||/||b|| 2.611659971859e-05
 24 KSP unpreconditioned resid norm 1.510009889378e-04 true resid norm 1.510009889395e-04 ||r(i)||/||b|| 2.038721554083e-05
 25 KSP unpreconditioned resid norm 1.178370506710e-04 true resid norm 1.178370506724e-04 ||r(i)||/||b|| 1.590962660328e-05
 26 KSP unpreconditioned resid norm 8.921055829265e-05 true resid norm 8.921055829443e-05 ||r(i)||/||b|| 1.204465542404e-05
 27 KSP unpreconditioned resid norm 6.903213040845e-05 true resid norm 6.903213041012e-05 ||r(i)||/||b|| 9.320289435172e-06
 28 KSP unpreconditioned resid norm 5.357460942945e-05 true resid norm 5.357460943198e-05 ||r(i)||/||b|| 7.233310971512e-06
 29 KSP unpreconditioned resid norm 4.182989256886e-05 true resid norm 4.182989257160e-05 ||r(i)||/||b|| 5.647612256688e-06
 30 KSP unpreconditioned resid norm 3.087441942016e-05 true resid norm 3.087441942016e-05 ||r(i)||/||b|| 4.168472324833e-06
 31 KSP unpreconditioned resid norm 2.643983394241e-05 true resid norm 2.643983394242e-05 ||r(i)||/||b|| 3.569742140323e-06
 32 KSP unpreconditioned resid norm 2.216484802712e-05 true resid norm 2.216484802713e-05 ||r(i)||/||b|| 2.992560097336e-06
 33 KSP unpreconditioned resid norm 1.907523007213e-05 true resid norm 1.907523007214e-05 ||r(i)||/||b|| 2.575419073098e-06
 34 KSP unpreconditioned resid norm 1.547185278986e-05 true resid norm 1.547185278987e-05 ||r(i)||/||b|| 2.088913455854e-06
 35 KSP unpreconditioned resid norm 1.256379017347e-05 true resid norm 1.256379017349e-05 ||r(i)||/||b|| 1.696284905652e-06
 36 KSP unpreconditioned resid norm 1.072584068780e-05 true resid norm 1.072584068780e-05 ||r(i)||/||b|| 1.448136383042e-06
 37 KSP unpreconditioned resid norm 9.211701529799e-06 true resid norm 9.211701529800e-06 ||r(i)||/||b|| 1.243706719438e-06
 38 KSP unpreconditioned resid norm 8.028399995262e-06 true resid norm 8.028399995246e-06 ||r(i)||/||b|| 1.083944696658e-06
 39 KSP unpreconditioned resid norm 6.857325667061e-06 true resid norm 6.857325667056e-06 ||r(i)||/||b|| 9.258335153282e-07
 40 KSP unpreconditioned resid norm 5.759722349850e-06 true resid norm 5.759722349846e-06 ||r(i)||/||b|| 7.776419335152e-07
 41 KSP unpreconditioned resid norm 4.722558786184e-06 true resid norm 4.722558786179e-06 ||r(i)||/||b|| 6.376105517867e-07
 42 KSP unpreconditioned resid norm 3.797562376720e-06 true resid norm 3.797562376716e-06 ||r(i)||/||b|| 5.127232824604e-07
 43 KSP unpreconditioned resid norm 2.942658206923e-06 true resid norm 2.942658206913e-06 ||r(i)||/||b|| 3.972994319352e-07
 44 KSP unpreconditioned resid norm 2.251149576887e-06 true resid norm 2.251149576873e-06 ||r(i)||/||b|| 3.039362322107e-07
 45 KSP unpreconditioned resid norm 1.698940938700e-06 true resid norm 1.698940938710e-06 ||r(i)||/||b|| 2.293804520876e-07
 46 KSP unpreconditioned resid norm 1.261300739337e-06 true resid norm 1.261300739358e-06 ||r(i)||/||b|| 1.702929908983e-07
 47 KSP unpreconditioned resid norm 9.471923629982e-07 true resid norm 9.471923630326e-07 ||r(i)||/||b|| 1.278840291007e-07
 48 KSP unpreconditioned resid norm 7.128407378936e-07 true resid norm 7.128407379083e-07 ||r(i)||/||b|| 9.624332841847e-08
Linear solve converged due to CONVERGED_RTOL iterations 48
Residual norm 7.12841e-07
  0 KSP unpreconditioned resid norm 2.178065518847e+00 true resid norm 2.178065518847e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 1.460392868474e-01 true resid norm 1.460392868474e-01 ||r(i)||/||b|| 6.704999715746e-02
  2 KSP unpreconditioned resid norm 3.941062007261e-02 true resid norm 3.941062007261e-02 ||r(i)||/||b|| 1.809432256817e-02
  3 KSP unpreconditioned resid norm 1.469001086082e-02 true resid norm 1.469001086082e-02 ||r(i)||/||b|| 6.744522023654e-03
  4 KSP unpreconditioned resid norm 7.045501244561e-03 true resid norm 7.045501244561e-03 ||r(i)||/||b|| 3.234751748098e-03
  5 KSP unpreconditioned resid norm 4.607801857748e-03 true resid norm 4.607801857748e-03 ||r(i)||/||b|| 2.115547864781e-03
  6 KSP unpreconditioned resid norm 2.920588014185e-03 true resid norm 2.920588014185e-03 ||r(i)||/||b|| 1.340909164078e-03
  7 KSP unpreconditioned resid norm 1.837118592260e-03 true resid norm 1.837118592261e-03 ||r(i)||/||b|| 8.434634203445e-04
  8 KSP unpreconditioned resid norm 1.326010801107e-03 true resid norm 1.326010801107e-03 ||r(i)||/||b|| 6.088020721291e-04
  9 KSP unpreconditioned resid norm 9.748366701558e-04 true resid norm 9.748366701566e-04 ||r(i)||/||b|| 4.475699476079e-04
 10 KSP unpreconditioned resid norm 7.331750895867e-04 true resid norm 7.331750895872e-04 ||r(i)||/||b|| 3.366175550015e-04
 11 KSP unpreconditioned resid norm 5.814568566459e-04 true resid norm 5.814568566461e-04 ||r(i)||/||b|| 2.669602230120e-04
 12 KSP unpreconditioned resid norm 5.038353768751e-04 true resid norm 5.038353768752e-04 ||r(i)||/||b|| 2.313224154717e-04
 13 KSP unpreconditioned resid norm 4.261654180571e-04 true resid norm 4.261654180568e-04 ||r(i)||/||b|| 1.956623500851e-04
 14 KSP unpreconditioned resid norm 3.777823804727e-04 true resid norm 3.777823804721e-04 ||r(i)||/||b|| 1.734485841694e-04
 15 KSP unpreconditioned resid norm 3.149422832642e-04 true resid norm 3.149422832633e-04 ||r(i)||/||b|| 1.445972495034e-04
 16 KSP unpreconditioned resid norm 2.738474743364e-04 true resid norm 2.738474743356e-04 ||r(i)||/||b|| 1.257296770763e-04
 17 KSP unpreconditioned resid norm 2.130851183760e-04 true resid norm 2.130851183749e-04 ||r(i)||/||b|| 9.783228122895e-05
 18 KSP unpreconditioned resid norm 1.744002705546e-04 true resid norm 1.744002705535e-04 ||r(i)||/||b|| 8.007117740235e-05
 19 KSP unpreconditioned resid norm 1.268436039537e-04 true resid norm 1.268436039527e-04 ||r(i)||/||b|| 5.823681742132e-05
 20 KSP unpreconditioned resid norm 1.025539525209e-04 true resid norm 1.025539525202e-04 ||r(i)||/||b|| 4.708487951018e-05
 21 KSP unpreconditioned resid norm 8.111346657473e-05 true resid norm 8.111346657392e-05 ||r(i)||/||b|| 3.724105903705e-05
 22 KSP unpreconditioned resid norm 6.811645792110e-05 true resid norm 6.811645792094e-05 ||r(i)||/||b|| 3.127383328533e-05
 23 KSP unpreconditioned resid norm 5.476915383296e-05 true resid norm 5.476915383309e-05 ||r(i)||/||b|| 2.514577883869e-05
 24 KSP unpreconditioned resid norm 4.361783613715e-05 true resid norm 4.361783613789e-05 ||r(i)||/||b|| 2.002595227759e-05
 25 KSP unpreconditioned resid norm 3.473686153395e-05 true resid norm 3.473686153498e-05 ||r(i)||/||b|| 1.594849247390e-05
 26 KSP unpreconditioned resid norm 2.662103935785e-05 true resid norm 2.662103936019e-05 ||r(i)||/||b|| 1.222233175717e-05
 27 KSP unpreconditioned resid norm 2.200010814357e-05 true resid norm 2.200010814643e-05 ||r(i)||/||b|| 1.010075590292e-05
 28 KSP unpreconditioned resid norm 1.774330318901e-05 true resid norm 1.774330319304e-05 ||r(i)||/||b|| 8.146358793851e-06
 29 KSP unpreconditioned resid norm 1.494333750491e-05 true resid norm 1.494333750969e-05 ||r(i)||/||b|| 6.860830117544e-06
 30 KSP unpreconditioned resid norm 1.206656267301e-05 true resid norm 1.206656267301e-05 ||r(i)||/||b|| 5.540036591461e-06
 31 KSP unpreconditioned resid norm 1.120278995565e-05 true resid norm 1.120278995564e-05 ||r(i)||/||b|| 5.143458660314e-06
 32 KSP unpreconditioned resid norm 9.261235878008e-06 true resid norm 9.261235878003e-06 ||r(i)||/||b|| 4.252046505427e-06
 33 KSP unpreconditioned resid norm 8.197470936141e-06 true resid norm 8.197470936131e-06 ||r(i)||/||b|| 3.763647541913e-06
 34 KSP unpreconditioned resid norm 6.820318077282e-06 true resid norm 6.820318077276e-06 ||r(i)||/||b|| 3.131364974221e-06
 35 KSP unpreconditioned resid norm 5.688691374400e-06 true resid norm 5.688691374394e-06 ||r(i)||/||b|| 2.611809114634e-06
 36 KSP unpreconditioned resid norm 4.595604182694e-06 true resid norm 4.595604182687e-06 ||r(i)||/||b|| 2.109947631475e-06
 37 KSP unpreconditioned resid norm 3.771797432721e-06 true resid norm 3.771797432722e-06 ||r(i)||/||b|| 1.731718995634e-06
 38 KSP unpreconditioned resid norm 3.109066412989e-06 true resid norm 3.109066412982e-06 ||r(i)||/||b|| 1.427443934115e-06
 39 KSP unpreconditioned resid norm 2.669628603745e-06 true resid norm 2.669628603739e-06 ||r(i)||/||b|| 1.225687923820e-06
 40 KSP unpreconditioned resid norm 2.210365942259e-06 true resid norm 2.210365942256e-06 ||r(i)||/||b|| 1.014829867664e-06
 41 KSP unpreconditioned resid norm 1.821949773643e-06 true resid norm 1.821949773631e-06 ||r(i)||/||b|| 8.364990666563e-07
 42 KSP unpreconditioned resid norm 1.446964504975e-06 true resid norm 1.446964504973e-06 ||r(i)||/||b|| 6.643347008862e-07
 43 KSP unpreconditioned resid norm 1.161968636199e-06 true resid norm 1.161968636218e-06 ||r(i)||/||b|| 5.334865393916e-07
 44 KSP unpreconditioned resid norm 9.487319749258e-07 true resid norm 9.487319749359e-07 ||r(i)||/||b|| 4.355846813269e-07
 45 KSP unpreconditioned resid norm 7.697968173503e-07 true resid norm 7.697968173499e-07 ||r(i)||/||b|| 3.534314329339e-07
 46 KSP unpreconditioned resid norm 6.509475897671e-07 true resid norm 6.509475897554e-07 ||r(i)||/||b|| 2.988650176603e-07
 47 KSP unpreconditioned resid norm 5.418206977645e-07 true resid norm 5.418206977467e-07 ||r(i)||/||b|| 2.487623503785e-07
 48 KSP unpreconditioned resid norm 4.629579528470e-07 true resid norm 4.629579528207e-07 ||r(i)||/||b|| 2.125546494422e-07
 49 KSP unpreconditioned resid norm 3.742046372363e-07 true resid norm 3.742046372009e-07 ||r(i)||/||b|| 1.718059599048e-07
 50 KSP unpreconditioned resid norm 2.906109875748e-07 true resid norm 2.906109875442e-07 ||r(i)||/||b|| 1.334261917420e-07
 51 KSP unpreconditioned resid norm 2.167356702683e-07 true resid norm 2.167356702358e-07 ||r(i)||/||b|| 9.950833359255e-08
Linear solve converged due to CONVERGED_RTOL iterations 51
Residual norm 2.16736e-07
Rank#2, time step = 1, continuity = 2.025209e-03 @ (4, 51, 35)
Rank#44, time step = 1, continuity = 8.147067e-03 @ (5, 5, 4)
Rank#24, time step = 1, continuity = 3.314627e-04 @ (41, 4, 4)
Rank#10, time step = 1, continuity = 2.015249e-03 @ (4, 5, 35)
Rank#1, time step = 1, continuity = 9.967610e-05 @ (4, 4, 4)
Rank#46, time step = 1, continuity = 2.260864e-03 @ (4, 50, 34)
Rank#27, time step = 1, continuity = 4.478382e+00 @ (4, 11, 17)
Rank#11, time step = 1, continuity = 3.502620e-02 @ (4, 4, 35)
Rank#31, time step = 1, continuity = 2.189822e-03 @ (4, 50, 5)
Rank#0, time step = 1, continuity = 3.535561e-08 @ (19, 51, 7)
Rank#47, time step = 1, continuity = 2.189827e-03 @ (4, 50, 34)
Rank#8, time step = 1, continuity = 3.448571e-05 @ (41, 4, 35)
Rank#30, time step = 1, continuity = 2.226857e-03 @ (4, 50, 5)
Rank#4, time step = 1, continuity = 4.905157e-03 @ (4, 4, 4)
Rank#28, time step = 1, continuity = 1.385920e-02 @ (4, 4, 20)
Rank#5, time step = 1, continuity = 2.806331e-03 @ (4, 4, 4)
Rank#25, time step = 1, continuity = 4.553406e-03 @ (41, 4, 4)
Rank#29, time step = 1, continuity = 2.459065e-03 @ (4, 50, 5)
Rank#3, time step = 1, continuity = 3.336243e-02 @ (4, 51, 35)
Rank#6, time step = 1, continuity = 2.297121e-03 @ (4, 4, 4)
Rank#26, time step = 1, continuity = 9.589653e-01 @ (39, 4, 17)
Rank#20, time step = 1, continuity = 1.330094e-02 @ (4, 51, 20)
Rank#21, time step = 1, continuity = 2.511545e-03 @ (4, 4, 5)
Rank#16, time step = 1, continuity = 2.985854e-04 @ (41, 51, 4)
Rank#37, time step = 1, continuity = 2.769053e-03 @ (4, 4, 34)
Rank#40, time step = 1, continuity = 2.449979e-04 @ (41, 5, 4)
Rank#12, time step = 1, continuity = 4.912665e-03 @ (4, 50, 4)
Rank#22, time step = 1, continuity = 2.246064e-03 @ (4, 4, 5)
Rank#17, time step = 1, continuity = 4.362478e-03 @ (41, 51, 4)
Rank#36, time step = 1, continuity = 8.123727e-03 @ (5, 51, 4)
Rank#41, time step = 1, continuity = 4.216866e-03 @ (41, 5, 4)
Rank#14, time step = 1, continuity = 2.279742e-03 @ (4, 50, 4)
Rank#23, time step = 1, continuity = 2.197173e-03 @ (4, 4, 5)
Rank#18, time step = 1, continuity = 8.029293e-02 @ (39, 51, 4)
Rank#38, time step = 1, continuity = 2.278785e-03 @ (4, 4, 34)
Rank#42, time step = 1, continuity = 9.597068e-02 @ (40, 5, 4)
Rank#15, time step = 1, continuity = 2.197458e-03 @ (4, 50, 4)
Rank#19, time step = 1, continuity = 4.478201e+00 @ (4, 45, 17)
Rank#43, time step = 1, continuity = 8.285460e-02 @ (19, 5, 4)
Rank#39, time step = 1, continuity = 2.197159e-03 @ (4, 4, 34)
Rank#45, time step = 1, continuity = 2.732214e-03 @ (4, 50, 34)
Rank#32, time step = 1, continuity = 2.455089e-04 @ (41, 51, 4)
Rank#33, time step = 1, continuity = 4.212290e-03 @ (41, 51, 4)
Rank#34, time step = 1, continuity = 9.554038e-02 @ (40, 51, 4)
Rank#9, time step = 1, continuity = 1.731917e-04 @ (41, 4, 35)
Rank#13, time step = 1, continuity = 2.771882e-03 @ (4, 50, 4)
Rank#7, time step = 1, continuity = 2.204604e-03 @ (4, 4, 4)
Rank#35, time step = 1, continuity = 8.228460e-02 @ (19, 51, 4)
Current time step = 2, Total time step number = 5
  0 KSP unpreconditioned resid norm 1.145993263262e+01 true resid norm 1.145993263262e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 8.467018295731e-01 true resid norm 8.467018295732e-01 ||r(i)||/||b|| 7.388366552551e-02
  2 KSP unpreconditioned resid norm 2.353082733202e-01 true resid norm 2.353082733202e-01 ||r(i)||/||b|| 2.053312884671e-02
  3 KSP unpreconditioned resid norm 8.280650623931e-02 true resid norm 8.280650623932e-02 ||r(i)||/||b|| 7.225741101098e-03
  4 KSP unpreconditioned resid norm 4.146387000857e-02 true resid norm 4.146387000857e-02 ||r(i)||/||b|| 3.618160013485e-03
  5 KSP unpreconditioned resid norm 2.760201858697e-02 true resid norm 2.760201858697e-02 ||r(i)||/||b|| 2.408567264035e-03
  6 KSP unpreconditioned resid norm 1.750509619293e-02 true resid norm 1.750509619293e-02 ||r(i)||/||b|| 1.527504284197e-03
  7 KSP unpreconditioned resid norm 1.101437000383e-02 true resid norm 1.101437000383e-02 ||r(i)||/||b|| 9.611199609047e-04
  8 KSP unpreconditioned resid norm 8.020603798473e-03 true resid norm 8.020603798472e-03 ||r(i)||/||b|| 6.998822816501e-04
  9 KSP unpreconditioned resid norm 5.769911324715e-03 true resid norm 5.769911324718e-03 ||r(i)||/||b|| 5.034856233182e-04
 10 KSP unpreconditioned resid norm 4.217969701212e-03 true resid norm 4.217969701212e-03 ||r(i)||/||b|| 3.680623469991e-04
 11 KSP unpreconditioned resid norm 3.290098525645e-03 true resid norm 3.290098525644e-03 ||r(i)||/||b|| 2.870957998723e-04
 12 KSP unpreconditioned resid norm 2.609406224541e-03 true resid norm 2.609406224541e-03 ||r(i)||/||b|| 2.276982167517e-04
 13 KSP unpreconditioned resid norm 2.004708786049e-03 true resid norm 2.004708786048e-03 ||r(i)||/||b|| 1.749319869772e-04
 14 KSP unpreconditioned resid norm 1.621432183334e-03 true resid norm 1.621432183333e-03 ||r(i)||/||b|| 1.414870606410e-04
 15 KSP unpreconditioned resid norm 1.273824611796e-03 true resid norm 1.273824611795e-03 ||r(i)||/||b|| 1.111546335071e-04
 16 KSP unpreconditioned resid norm 1.022867010282e-03 true resid norm 1.022867010282e-03 ||r(i)||/||b|| 8.925593570862e-05
 17 KSP unpreconditioned resid norm 8.088159574836e-04 true resid norm 8.088159574832e-04 ||r(i)||/||b|| 7.057772357066e-05
 18 KSP unpreconditioned resid norm 6.782535622143e-04 true resid norm 6.782535622147e-04 ||r(i)||/||b|| 5.918477742916e-05
 19 KSP unpreconditioned resid norm 5.390023303178e-04 true resid norm 5.390023303189e-04 ||r(i)||/||b|| 4.703363864328e-05
 20 KSP unpreconditioned resid norm 4.544503585906e-04 true resid norm 4.544503585916e-04 ||r(i)||/||b|| 3.965558726743e-05
 21 KSP unpreconditioned resid norm 3.748239986292e-04 true resid norm 3.748239986313e-04 ||r(i)||/||b|| 3.270734747292e-05
 22 KSP unpreconditioned resid norm 3.106950604455e-04 true resid norm 3.106950604470e-04 ||r(i)||/||b|| 2.711142119306e-05
 23 KSP unpreconditioned resid norm 2.519104118885e-04 true resid norm 2.519104118907e-04 ||r(i)||/||b|| 2.198184055408e-05
 24 KSP unpreconditioned resid norm 1.993796457577e-04 true resid norm 1.993796457610e-04 ||r(i)||/||b|| 1.739797712192e-05
 25 KSP unpreconditioned resid norm 1.536074482824e-04 true resid norm 1.536074482846e-04 ||r(i)||/||b|| 1.340387009321e-05
 26 KSP unpreconditioned resid norm 1.160166482479e-04 true resid norm 1.160166482505e-04 ||r(i)||/||b|| 1.012367628762e-05
 27 KSP unpreconditioned resid norm 9.118828433660e-05 true resid norm 9.118828433948e-05 ||r(i)||/||b|| 7.957139650188e-06
 28 KSP unpreconditioned resid norm 6.968237176481e-05 true resid norm 6.968237176823e-05 ||r(i)||/||b|| 6.080521936918e-06
 29 KSP unpreconditioned resid norm 5.489756729503e-05 true resid norm 5.489756729856e-05 ||r(i)||/||b|| 4.790391798841e-06
 30 KSP unpreconditioned resid norm 4.088864972904e-05 true resid norm 4.088864972904e-05 ||r(i)||/||b|| 3.567965976751e-06
 31 KSP unpreconditioned resid norm 3.550536673258e-05 true resid norm 3.550536673258e-05 ||r(i)||/||b|| 3.098217753177e-06
 32 KSP unpreconditioned resid norm 2.932517724995e-05 true resid norm 2.932517724995e-05 ||r(i)||/||b|| 2.558931033023e-06
 33 KSP unpreconditioned resid norm 2.538035496051e-05 true resid norm 2.538035496053e-05 ||r(i)||/||b|| 2.214703678824e-06
 34 KSP unpreconditioned resid norm 2.077966563835e-05 true resid norm 2.077966563835e-05 ||r(i)||/||b|| 1.813245008021e-06
 35 KSP unpreconditioned resid norm 1.677227950577e-05 true resid norm 1.677227950575e-05 ||r(i)||/||b|| 1.463558298590e-06
 36 KSP unpreconditioned resid norm 1.426971881665e-05 true resid norm 1.426971881664e-05 ||r(i)||/||b|| 1.245183481797e-06
 37 KSP unpreconditioned resid norm 1.232421452779e-05 true resid norm 1.232421452778e-05 ||r(i)||/||b|| 1.075417711681e-06
 38 KSP unpreconditioned resid norm 1.072305282161e-05 true resid norm 1.072305282161e-05 ||r(i)||/||b|| 9.356994639823e-07
 39 KSP unpreconditioned resid norm 9.187459115632e-06 true resid norm 9.187459115628e-06 ||r(i)||/||b|| 8.017027159025e-07
 40 KSP unpreconditioned resid norm 7.725611104268e-06 true resid norm 7.725611104266e-06 ||r(i)||/||b|| 6.741410575380e-07
 41 KSP unpreconditioned resid norm 6.336099247960e-06 true resid norm 6.336099247978e-06 ||r(i)||/||b|| 5.528914916955e-07
 42 KSP unpreconditioned resid norm 5.072527467147e-06 true resid norm 5.072527467184e-06 ||r(i)||/||b|| 4.426315258387e-07
 43 KSP unpreconditioned resid norm 3.980186570456e-06 true resid norm 3.980186570487e-06 ||r(i)||/||b|| 3.473132607393e-07
 44 KSP unpreconditioned resid norm 3.031763132156e-06 true resid norm 3.031763132231e-06 ||r(i)||/||b|| 2.645533119106e-07
 45 KSP unpreconditioned resid norm 2.268918039035e-06 true resid norm 2.268918039109e-06 ||r(i)||/||b|| 1.979870311498e-07
 46 KSP unpreconditioned resid norm 1.714692473145e-06 true resid norm 1.714692473173e-06 ||r(i)||/||b|| 1.496250046263e-07
 47 KSP unpreconditioned resid norm 1.278527011803e-06 true resid norm 1.278527011797e-06 ||r(i)||/||b|| 1.115649675076e-07
 48 KSP unpreconditioned resid norm 9.599919523504e-07 true resid norm 9.599919523332e-07 ||r(i)||/||b|| 8.376942370506e-08
Residual norm 9.59992e-07
  0 KSP unpreconditioned resid norm 1.903872986821e+00 true resid norm 1.903872986821e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 1.250166965029e-01 true resid norm 1.250166965029e-01 ||r(i)||/||b|| 6.566441005689e-02
  2 KSP unpreconditioned resid norm 3.413148600032e-02 true resid norm 3.413148600032e-02 ||r(i)||/||b|| 1.792739654199e-02
  3 KSP unpreconditioned resid norm 1.224574003913e-02 true resid norm 1.224574003913e-02 ||r(i)||/||b|| 6.432015225750e-03
  4 KSP unpreconditioned resid norm 5.300073743184e-03 true resid norm 5.300073743185e-03 ||r(i)||/||b|| 2.783837881976e-03
  5 KSP unpreconditioned resid norm 3.365317369016e-03 true resid norm 3.365317369016e-03 ||r(i)||/||b|| 1.767616533409e-03
  6 KSP unpreconditioned resid norm 2.233194123812e-03 true resid norm 2.233194123811e-03 ||r(i)||/||b|| 1.172974320908e-03
  7 KSP unpreconditioned resid norm 1.414030484365e-03 true resid norm 1.414030484365e-03 ||r(i)||/||b|| 7.427126148400e-04
  8 KSP unpreconditioned resid norm 1.008018647560e-03 true resid norm 1.008018647560e-03 ||r(i)||/||b|| 5.294568779209e-04
  9 KSP unpreconditioned resid norm 7.859431037379e-04 true resid norm 7.859431037391e-04 ||r(i)||/||b|| 4.128127817241e-04
 10 KSP unpreconditioned resid norm 6.142350651412e-04 true resid norm 6.142350651422e-04 ||r(i)||/||b|| 3.226239719739e-04
 11 KSP unpreconditioned resid norm 5.010222708685e-04 true resid norm 5.010222708691e-04 ||r(i)||/||b|| 2.631595039886e-04
 12 KSP unpreconditioned resid norm 4.370374667634e-04 true resid norm 4.370374667636e-04 ||r(i)||/||b|| 2.295517977243e-04
 13 KSP unpreconditioned resid norm 3.751450978703e-04 true resid norm 3.751450978698e-04 ||r(i)||/||b|| 1.970431328490e-04
 14 KSP unpreconditioned resid norm 3.234752378984e-04 true resid norm 3.234752378973e-04 ||r(i)||/||b|| 1.699037909232e-04
 15 KSP unpreconditioned resid norm 2.685396778927e-04 true resid norm 2.685396778914e-04 ||r(i)||/||b|| 1.410491559837e-04
 16 KSP unpreconditioned resid norm 2.309017226947e-04 true resid norm 2.309017226933e-04 ||r(i)||/||b|| 1.212800035988e-04
 17 KSP unpreconditioned resid norm 1.762487331106e-04 true resid norm 1.762487331090e-04 ||r(i)||/||b|| 9.257378739494e-05
 18 KSP unpreconditioned resid norm 1.448381331042e-04 true resid norm 1.448381331027e-04 ||r(i)||/||b|| 7.607552294995e-05
 19 KSP unpreconditioned resid norm 1.077151882122e-04 true resid norm 1.077151882107e-04 ||r(i)||/||b|| 5.657687721623e-05
 20 KSP unpreconditioned resid norm 8.753358844749e-05 true resid norm 8.753358844627e-05 ||r(i)||/||b|| 4.597659037771e-05
 21 KSP unpreconditioned resid norm 6.789005163891e-05 true resid norm 6.789005163755e-05 ||r(i)||/||b|| 3.565891848221e-05
 22 KSP unpreconditioned resid norm 5.730497317295e-05 true resid norm 5.730497317199e-05 ||r(i)||/||b|| 3.009915764794e-05
 23 KSP unpreconditioned resid norm 4.488629127859e-05 true resid norm 4.488629127750e-05 ||r(i)||/||b|| 2.357630555620e-05
 24 KSP unpreconditioned resid norm 3.549059931238e-05 true resid norm 3.549059931175e-05 ||r(i)||/||b|| 1.864126417960e-05
 25 KSP unpreconditioned resid norm 2.825201934536e-05 true resid norm 2.825201934469e-05 ||r(i)||/||b|| 1.483923535879e-05
 26 KSP unpreconditioned resid norm 2.204358958226e-05 true resid norm 2.204358958227e-05 ||r(i)||/||b|| 1.157828790831e-05
 27 KSP unpreconditioned resid norm 1.826364573014e-05 true resid norm 1.826364573052e-05 ||r(i)||/||b|| 9.592890837228e-06
 28 KSP unpreconditioned resid norm 1.488023103673e-05 true resid norm 1.488023103794e-05 ||r(i)||/||b|| 7.815768772885e-06
 29 KSP unpreconditioned resid norm 1.283432364115e-05 true resid norm 1.283432364331e-05 ||r(i)||/||b|| 6.741165892973e-06
 30 KSP unpreconditioned resid norm 1.014605282698e-05 true resid norm 1.014605282698e-05 ||r(i)||/||b|| 5.329164758998e-06
 31 KSP unpreconditioned resid norm 9.407914973543e-06 true resid norm 9.407914973543e-06 ||r(i)||/||b|| 4.941461451822e-06
 32 KSP unpreconditioned resid norm 7.757298584563e-06 true resid norm 7.757298584557e-06 ||r(i)||/||b|| 4.074483244551e-06
 33 KSP unpreconditioned resid norm 6.931504610008e-06 true resid norm 6.931504610005e-06 ||r(i)||/||b|| 3.640738987309e-06
 34 KSP unpreconditioned resid norm 5.698043511339e-06 true resid norm 5.698043511334e-06 ||r(i)||/||b|| 2.992869561560e-06
 35 KSP unpreconditioned resid norm 4.862023768014e-06 true resid norm 4.862023768017e-06 ||r(i)||/||b|| 2.553754269152e-06
 36 KSP unpreconditioned resid norm 3.935139896939e-06 true resid norm 3.935139896942e-06 ||r(i)||/||b|| 2.066913036837e-06
 37 KSP unpreconditioned resid norm 3.257659841958e-06 true resid norm 3.257659841967e-06 ||r(i)||/||b|| 1.711069942437e-06
 38 KSP unpreconditioned resid norm 2.658817764230e-06 true resid norm 2.658817764249e-06 ||r(i)||/||b|| 1.396531062026e-06
 39 KSP unpreconditioned resid norm 2.259760363675e-06 true resid norm 2.259760363695e-06 ||r(i)||/||b|| 1.186928108827e-06
 40 KSP unpreconditioned resid norm 1.850320661460e-06 true resid norm 1.850320661493e-06 ||r(i)||/||b|| 9.718719023281e-07
 41 KSP unpreconditioned resid norm 1.507757223827e-06 true resid norm 1.507757223866e-06 ||r(i)||/||b|| 7.919421276016e-07
 42 KSP unpreconditioned resid norm 1.222830298328e-06 true resid norm 1.222830298355e-06 ||r(i)||/||b|| 6.422856497358e-07
 43 KSP unpreconditioned resid norm 9.791313605986e-07 true resid norm 9.791313606237e-07 ||r(i)||/||b|| 5.142839713580e-07
 44 KSP unpreconditioned resid norm 8.030348922423e-07 true resid norm 8.030348922612e-07 ||r(i)||/||b|| 4.217901602785e-07
 45 KSP unpreconditioned resid norm 6.450601933616e-07 true resid norm 6.450601933832e-07 ||r(i)||/||b|| 3.388147202299e-07
 46 KSP unpreconditioned resid norm 5.406035117950e-07 true resid norm 5.406035118192e-07 ||r(i)||/||b|| 2.839493577362e-07
 47 KSP unpreconditioned resid norm 4.409627148245e-07 true resid norm 4.409627148583e-07 ||r(i)||/||b|| 2.316135151403e-07
 48 KSP unpreconditioned resid norm 3.776631107440e-07 true resid norm 3.776631107863e-07 ||r(i)||/||b|| 1.983657068515e-07
 49 KSP unpreconditioned resid norm 3.060662042891e-07 true resid norm 3.060662043298e-07 ||r(i)||/||b|| 1.607597809562e-07
 50 KSP unpreconditioned resid norm 2.450411530613e-07 true resid norm 2.450411530946e-07 ||r(i)||/||b|| 1.287066704506e-07
 51 KSP unpreconditioned resid norm 1.892344498531e-07 true resid norm 1.892344498921e-07 ||r(i)||/||b|| 9.939447179615e-08
Residual norm 1.89234e-07
Rank#24, time step = 2, continuity = 3.572595e-04 @ (41, 4, 4)
Rank#44, time step = 2, continuity = 1.147952e-02 @ (5, 5, 4)
Rank#27, time step = 2, continuity = 3.980041e+00 @ (4, 11, 17)
Rank#45, time step = 2, continuity = 2.594768e-03 @ (4, 50, 34)
Rank#46, time step = 2, continuity = 2.060500e-03 @ (4, 50, 34)
Rank#1, time step = 2, continuity = 2.221491e-04 @ (4, 4, 4)
Rank#0, time step = 2, continuity = 2.750387e-08 @ (19, 51, 7)
Rank#4, time step = 2, continuity = 6.838965e-03 @ (4, 51, 35)
Rank#5, time step = 2, continuity = 2.685059e-03 @ (4, 4, 4)
Rank#2, time step = 2, continuity = 3.305379e-03 @ (4, 51, 35)
Rank#36, time step = 2, continuity = 1.145714e-02 @ (5, 51, 4)
Rank#31, time step = 2, continuity = 2.043125e-03 @ (4, 50, 5)
Rank#37, time step = 2, continuity = 2.641305e-03 @ (4, 4, 34)
Rank#30, time step = 2, continuity = 2.021057e-03 @ (4, 50, 5)
Rank#28, time step = 2, continuity = 2.169531e-02 @ (4, 4, 20)
Rank#29, time step = 2, continuity = 2.251697e-03 @ (4, 50, 5)
Rank#13, time step = 2, continuity = 2.641033e-03 @ (4, 50, 4)
Rank#14, time step = 2, continuity = 2.080491e-03 @ (4, 50, 4)
Rank#8, time step = 2, continuity = 3.839277e-05 @ (41, 4, 35)
Rank#20, time step = 2, continuity = 2.088852e-02 @ (4, 51, 20)
Rank#9, time step = 2, continuity = 2.025106e-04 @ (4, 50, 4)
Rank#22, time step = 2, continuity = 2.042619e-03 @ (4, 4, 5)
Rank#10, time step = 2, continuity = 3.293410e-03 @ (4, 5, 35)
Rank#21, time step = 2, continuity = 2.318005e-03 @ (4, 4, 5)
Rank#25, time step = 2, continuity = 5.028256e-03 @ (41, 4, 4)
Rank#26, time step = 2, continuity = 8.660592e-01 @ (39, 4, 17)
Rank#11, time step = 2, continuity = 4.892623e-02 @ (4, 4, 35)
Rank#38, time step = 2, continuity = 2.080645e-03 @ (4, 4, 34)
Rank#40, time step = 2, continuity = 2.570407e-04 @ (41, 5, 4)
Rank#41, time step = 2, continuity = 4.631534e-03 @ (41, 5, 4)
Rank#16, time step = 2, continuity = 3.189125e-04 @ (41, 51, 4)
Rank#42, time step = 2, continuity = 1.119371e-01 @ (40, 5, 4)
Rank#17, time step = 2, continuity = 4.813800e-03 @ (41, 51, 4)
Rank#43, time step = 2, continuity = 1.055263e-01 @ (19, 5, 4)
Rank#18, time step = 2, continuity = 9.377534e-02 @ (39, 51, 4)
Rank#15, time step = 2, continuity = 2.050923e-03 @ (4, 50, 4)
Rank#19, time step = 2, continuity = 4.025784e+00 @ (4, 51, 13)
Rank#32, time step = 2, continuity = 2.570683e-04 @ (41, 51, 4)
Rank#33, time step = 2, continuity = 4.597828e-03 @ (41, 51, 4)
Rank#23, time step = 2, continuity = 2.050687e-03 @ (4, 4, 5)
Rank#34, time step = 2, continuity = 1.111301e-01 @ (40, 51, 4)
Rank#35, time step = 2, continuity = 1.047201e-01 @ (19, 51, 4)
Rank#47, time step = 2, continuity = 2.043574e-03 @ (4, 50, 34)
Rank#3, time step = 2, continuity = 4.698379e-02 @ (4, 51, 35)
Rank#12, time step = 2, continuity = 7.182269e-03 @ (4, 4, 35)
Rank#7, time step = 2, continuity = 2.058267e-03 @ (4, 4, 4)
Rank#6, time step = 2, continuity = 2.100210e-03 @ (4, 4, 4)
Rank#39, time step = 2, continuity = 2.051061e-03 @ (4, 5, 34)
Current time step = 3, Total time step number = 5
  0 KSP unpreconditioned resid norm 1.498434584652e+01 true resid norm 1.498434584652e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 1.092790363921e+00 true resid norm 1.092790363921e+00 ||r(i)||/||b|| 7.292880017017e-02
  2 KSP unpreconditioned resid norm 3.035607510875e-01 true resid norm 3.035607510875e-01 ||r(i)||/||b|| 2.025852541024e-02
  3 KSP unpreconditioned resid norm 1.046104233532e-01 true resid norm 1.046104233532e-01 ||r(i)||/||b|| 6.981313994265e-03
  4 KSP unpreconditioned resid norm 4.900330197785e-02 true resid norm 4.900330197786e-02 ||r(i)||/||b|| 3.270299716771e-03
  5 KSP unpreconditioned resid norm 3.243734826670e-02 true resid norm 3.243734826671e-02 ||r(i)||/||b|| 2.164749038694e-03
  6 KSP unpreconditioned resid norm 2.125601515562e-02 true resid norm 2.125601515562e-02 ||r(i)||/||b|| 1.418548088341e-03
  7 KSP unpreconditioned resid norm 1.320366086225e-02 true resid norm 1.320366086225e-02 ||r(i)||/||b|| 8.811636488838e-04
  8 KSP unpreconditioned resid norm 9.434930974812e-03 true resid norm 9.434930974811e-03 ||r(i)||/||b|| 6.296525101231e-04
  9 KSP unpreconditioned resid norm 6.928273956785e-03 true resid norm 6.928273956791e-03 ||r(i)||/||b|| 4.623674618670e-04
 10 KSP unpreconditioned resid norm 5.054559978185e-03 true resid norm 5.054559978187e-03 ||r(i)||/||b|| 3.373226986323e-04
 11 KSP unpreconditioned resid norm 3.879257749830e-03 true resid norm 3.879257749830e-03 ||r(i)||/||b|| 2.588873608208e-04
 12 KSP unpreconditioned resid norm 3.115677995555e-03 true resid norm 3.115677995557e-03 ||r(i)||/||b|| 2.079288630595e-04
 13 KSP unpreconditioned resid norm 2.397098909417e-03 true resid norm 2.397098909416e-03 ||r(i)||/||b|| 1.599735439885e-04
 14 KSP unpreconditioned resid norm 1.919635663198e-03 true resid norm 1.919635663196e-03 ||r(i)||/||b|| 1.281094071679e-04
 15 KSP unpreconditioned resid norm 1.516959045641e-03 true resid norm 1.516959045638e-03 ||r(i)||/||b|| 1.012362542333e-04
 16 KSP unpreconditioned resid norm 1.227746545064e-03 true resid norm 1.227746545063e-03 ||r(i)||/||b|| 8.193527816555e-05
 17 KSP unpreconditioned resid norm 9.567761331953e-04 true resid norm 9.567761331946e-04 ||r(i)||/||b|| 6.385171184614e-05
 18 KSP unpreconditioned resid norm 8.061097903490e-04 true resid norm 8.061097903493e-04 ||r(i)||/||b|| 5.379679557628e-05
 19 KSP unpreconditioned resid norm 6.448576549729e-04 true resid norm 6.448576549744e-04 ||r(i)||/||b|| 4.303542253894e-05
 20 KSP unpreconditioned resid norm 5.367404070636e-04 true resid norm 5.367404070649e-04 ||r(i)||/||b|| 3.582007600216e-05
 21 KSP unpreconditioned resid norm 4.465369943436e-04 true resid norm 4.465369943470e-04 ||r(i)||/||b|| 2.980023278433e-05
 22 KSP unpreconditioned resid norm 3.708072163845e-04 true resid norm 3.708072163881e-04 ||r(i)||/||b|| 2.474630659131e-05
 23 KSP unpreconditioned resid norm 2.994136346519e-04 true resid norm 2.994136346554e-04 ||r(i)||/||b|| 1.998176214846e-05
 24 KSP unpreconditioned resid norm 2.368415263321e-04 true resid norm 2.368415263359e-04 ||r(i)||/||b|| 1.580593031967e-05
 25 KSP unpreconditioned resid norm 1.843154328279e-04 true resid norm 1.843154328311e-04 ||r(i)||/||b|| 1.230053248363e-05
 26 KSP unpreconditioned resid norm 1.374799193076e-04 true resid norm 1.374799193111e-04 ||r(i)||/||b|| 9.174902976697e-06
 27 KSP unpreconditioned resid norm 1.078590988123e-04 true resid norm 1.078590988147e-04 ||r(i)||/||b|| 7.198118617891e-06
 28 KSP unpreconditioned resid norm 8.366418218981e-05 true resid norm 8.366418219349e-05 ||r(i)||/||b|| 5.583439080388e-06
 29 KSP unpreconditioned resid norm 6.486198779907e-05 true resid norm 6.486198780324e-05 ||r(i)||/||b|| 4.328649943589e-06
 30 KSP unpreconditioned resid norm 4.869596253714e-05 true resid norm 4.869596253714e-05 ||r(i)||/||b|| 3.249789015545e-06
 31 KSP unpreconditioned resid norm 4.197253762996e-05 true resid norm 4.197253762997e-05 ||r(i)||/||b|| 2.801092424047e-06
 32 KSP unpreconditioned resid norm 3.477255859637e-05 true resid norm 3.477255859636e-05 ||r(i)||/||b|| 2.320592367030e-06
 33 KSP unpreconditioned resid norm 2.984747219315e-05 true resid norm 2.984747219315e-05 ||r(i)||/||b|| 1.991910257470e-06
 34 KSP unpreconditioned resid norm 2.473689623528e-05 true resid norm 2.473689623530e-05 ||r(i)||/||b|| 1.650849258865e-06
 35 KSP unpreconditioned resid norm 1.955260027410e-05 true resid norm 1.955260027416e-05 ||r(i)||/||b|| 1.304868459020e-06
 36 KSP unpreconditioned resid norm 1.694685253795e-05 true resid norm 1.694685253801e-05 ||r(i)||/||b|| 1.130970461547e-06
 37 KSP unpreconditioned resid norm 1.449937027782e-05 true resid norm 1.449937027791e-05 ||r(i)||/||b|| 9.676345184785e-07
 38 KSP unpreconditioned resid norm 1.264545410891e-05 true resid norm 1.264545410903e-05 ||r(i)||/||b|| 8.439109880776e-07
 39 KSP unpreconditioned resid norm 1.079008846191e-05 true resid norm 1.079008846223e-05 ||r(i)||/||b|| 7.200907248641e-07
 40 KSP unpreconditioned resid norm 9.100895988825e-06 true resid norm 9.100895989285e-06 ||r(i)||/||b|| 6.073602466538e-07
 41 KSP unpreconditioned resid norm 7.434748605604e-06 true resid norm 7.434748606064e-06 ||r(i)||/||b|| 4.961677127729e-07
 42 KSP unpreconditioned resid norm 5.974987079856e-06 true resid norm 5.974987080279e-06 ||r(i)||/||b|| 3.987486101482e-07
 43 KSP unpreconditioned resid norm 4.731598282761e-06 true resid norm 4.731598283153e-06 ||r(i)||/||b|| 3.157694257473e-07
 44 KSP unpreconditioned resid norm 3.527588850234e-06 true resid norm 3.527588850504e-06 ||r(i)||/||b|| 2.354182749542e-07
 45 KSP unpreconditioned resid norm 2.688764015030e-06 true resid norm 2.688764015219e-06 ||r(i)||/||b|| 1.794381978873e-07
 46 KSP unpreconditioned resid norm 2.023673546681e-06 true resid norm 2.023673546778e-06 ||r(i)||/||b|| 1.350525119686e-07
 47 KSP unpreconditioned resid norm 1.510010378674e-06 true resid norm 1.510010378681e-06 ||r(i)||/||b|| 1.007725258178e-07
 48 KSP unpreconditioned resid norm 1.140779932135e-06 true resid norm 1.140779932032e-06 ||r(i)||/||b|| 7.613144702591e-08
Residual norm 1.14078e-06
  0 KSP unpreconditioned resid norm 1.652982043410e+00 true resid norm 1.652982043410e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 1.040644076118e-01 true resid norm 1.040644076118e-01 ||r(i)||/||b|| 6.295555842646e-02
  2 KSP unpreconditioned resid norm 2.849057515307e-02 true resid norm 2.849057515307e-02 ||r(i)||/||b|| 1.723586488229e-02
  3 KSP unpreconditioned resid norm 1.053181684125e-02 true resid norm 1.053181684125e-02 ||r(i)||/||b|| 6.371404264939e-03
  4 KSP unpreconditioned resid norm 4.749233649129e-03 true resid norm 4.749233649130e-03 ||r(i)||/||b|| 2.873130817158e-03
  5 KSP unpreconditioned resid norm 3.048765576587e-03 true resid norm 3.048765576587e-03 ||r(i)||/||b|| 1.844403324732e-03
  6 KSP unpreconditioned resid norm 1.972895444966e-03 true resid norm 1.972895444966e-03 ||r(i)||/||b|| 1.193537130565e-03
  7 KSP unpreconditioned resid norm 1.216104509688e-03 true resid norm 1.216104509688e-03 ||r(i)||/||b|| 7.357034001285e-04
  8 KSP unpreconditioned resid norm 8.397302896056e-04 true resid norm 8.397302896054e-04 ||r(i)||/||b|| 5.080093234850e-04
  9 KSP unpreconditioned resid norm 6.264979217511e-04 true resid norm 6.264979217521e-04 ||r(i)||/||b|| 3.790107244358e-04
 10 KSP unpreconditioned resid norm 4.502188878110e-04 true resid norm 4.502188878118e-04 ||r(i)||/||b|| 2.723676821577e-04
 11 KSP unpreconditioned resid norm 3.486290906189e-04 true resid norm 3.486290906193e-04 ||r(i)||/||b|| 2.109091819898e-04
 12 KSP unpreconditioned resid norm 2.892294177841e-04 true resid norm 2.892294177842e-04 ||r(i)||/||b|| 1.749743253034e-04
 13 KSP unpreconditioned resid norm 2.455836801619e-04 true resid norm 2.455836801616e-04 ||r(i)||/||b|| 1.485700834687e-04
 14 KSP unpreconditioned resid norm 2.080058928662e-04 true resid norm 2.080058928656e-04 ||r(i)||/||b|| 1.258367528522e-04
 15 KSP unpreconditioned resid norm 1.769405745688e-04 true resid norm 1.769405745682e-04 ||r(i)||/||b|| 1.070432526921e-04
 16 KSP unpreconditioned resid norm 1.532177881785e-04 true resid norm 1.532177881780e-04 ||r(i)||/||b|| 9.269174386308e-05
 17 KSP unpreconditioned resid norm 1.213202871017e-04 true resid norm 1.213202871011e-04 ||r(i)||/||b|| 7.339480037595e-05
 18 KSP unpreconditioned resid norm 1.008586917109e-04 true resid norm 1.008586917102e-04 ||r(i)||/||b|| 6.101620529536e-05
 19 KSP unpreconditioned resid norm 7.536678882281e-05 true resid norm 7.536678882237e-05 ||r(i)||/||b|| 4.559443892500e-05
 20 KSP unpreconditioned resid norm 6.165856591295e-05 true resid norm 6.165856591247e-05 ||r(i)||/||b|| 3.730141301795e-05
 21 KSP unpreconditioned resid norm 4.781675773685e-05 true resid norm 4.781675773624e-05 ||r(i)||/||b|| 2.892757239976e-05
 22 KSP unpreconditioned resid norm 4.111930662611e-05 true resid norm 4.111930662552e-05 ||r(i)||/||b|| 2.487583382376e-05
 23 KSP unpreconditioned resid norm 3.231084932122e-05 true resid norm 3.231084932060e-05 ||r(i)||/||b|| 1.954700563712e-05
 24 KSP unpreconditioned resid norm 2.629119845771e-05 true resid norm 2.629119845736e-05 ||r(i)||/||b|| 1.590531401244e-05
 25 KSP unpreconditioned resid norm 2.062134326649e-05 true resid norm 2.062134326590e-05 ||r(i)||/||b|| 1.247523731314e-05
 26 KSP unpreconditioned resid norm 1.598609489324e-05 true resid norm 1.598609489274e-05 ||r(i)||/||b|| 9.671063854853e-06
 27 KSP unpreconditioned resid norm 1.293327139531e-05 true resid norm 1.293327139479e-05 ||r(i)||/||b|| 7.824205620597e-06
 28 KSP unpreconditioned resid norm 1.035949175128e-05 true resid norm 1.035949175088e-05 ||r(i)||/||b|| 6.267153229026e-06
 29 KSP unpreconditioned resid norm 8.880493935672e-06 true resid norm 8.880493935523e-06 ||r(i)||/||b|| 5.372407988900e-06
 30 KSP unpreconditioned resid norm 7.137871934412e-06 true resid norm 7.137871934412e-06 ||r(i)||/||b|| 4.318178750259e-06
 31 KSP unpreconditioned resid norm 6.707215155334e-06 true resid norm 6.707215155334e-06 ||r(i)||/||b|| 4.057645503213e-06
 32 KSP unpreconditioned resid norm 5.556103817925e-06 true resid norm 5.556103817933e-06 ||r(i)||/||b|| 3.361260843748e-06
 33 KSP unpreconditioned resid norm 4.988355482067e-06 true resid norm 4.988355482078e-06 ||r(i)||/||b|| 3.017791694693e-06
 34 KSP unpreconditioned resid norm 4.087915820136e-06 true resid norm 4.087915820152e-06 ||r(i)||/||b|| 2.473055189226e-06
 35 KSP unpreconditioned resid norm 3.481285629031e-06 true resid norm 3.481285629045e-06 ||r(i)||/||b|| 2.106063791149e-06
 36 KSP unpreconditioned resid norm 2.775692176766e-06 true resid norm 2.775692176776e-06 ||r(i)||/||b|| 1.679202861182e-06
 37 KSP unpreconditioned resid norm 2.326242471264e-06 true resid norm 2.326242471274e-06 ||r(i)||/||b|| 1.407300509130e-06
 38 KSP unpreconditioned resid norm 1.903169493624e-06 true resid norm 1.903169493629e-06 ||r(i)||/||b|| 1.151355213577e-06
 39 KSP unpreconditioned resid norm 1.647136962470e-06 true resid norm 1.647136962479e-06 ||r(i)||/||b|| 9.964639174670e-07
 40 KSP unpreconditioned resid norm 1.341776814255e-06 true resid norm 1.341776814265e-06 ||r(i)||/||b|| 8.117310285457e-07
 41 KSP unpreconditioned resid norm 1.113514152334e-06 true resid norm 1.113514152345e-06 ||r(i)||/||b|| 6.736395938384e-07
 42 KSP unpreconditioned resid norm 8.915555405500e-07 true resid norm 8.915555405616e-07 ||r(i)||/||b|| 5.393619030020e-07
 43 KSP unpreconditioned resid norm 7.237736566449e-07 true resid norm 7.237736566594e-07 ||r(i)||/||b|| 4.378593582096e-07
 44 KSP unpreconditioned resid norm 5.921887748494e-07 true resid norm 5.921887748552e-07 ||r(i)||/||b|| 3.582548142106e-07
 45 KSP unpreconditioned resid norm 4.832497255683e-07 true resid norm 4.832497255690e-07 ||r(i)||/||b|| 2.923502572189e-07
 46 KSP unpreconditioned resid norm 4.072281865093e-07 true resid norm 4.072281865119e-07 ||r(i)||/||b|| 2.463597158453e-07
 47 KSP unpreconditioned resid norm 3.355562061436e-07 true resid norm 3.355562061460e-07 ||r(i)||/||b|| 2.030005150291e-07
 48 KSP unpreconditioned resid norm 2.849049830237e-07 true resid norm 2.849049830229e-07 ||r(i)||/||b|| 1.723581839009e-07
 49 KSP unpreconditioned resid norm 2.266132667399e-07 true resid norm 2.266132667368e-07 ||r(i)||/||b|| 1.370936046403e-07
 50 KSP unpreconditioned resid norm 1.739841395163e-07 true resid norm 1.739841395054e-07 ||r(i)||/||b|| 1.052547063043e-07
 51 KSP unpreconditioned resid norm 1.268356186763e-07 true resid norm 1.268356186611e-07 ||r(i)||/||b|| 7.673139533900e-08
Residual norm 1.26836e-07
Rank#44, time step = 3, continuity = 1.368123e-02 @ (5, 5, 4)
Rank#24, time step = 3, continuity = 3.885754e-04 @ (41, 4, 4)
Rank#10, time step = 3, continuity = 4.105729e-03 @ (4, 5, 35)
Rank#3, time step = 3, continuity = 5.609826e-02 @ (4, 51, 35)
Rank#45, time step = 3, continuity = 1.929346e-03 @ (4, 50, 34)
Rank#27, time step = 3, continuity = 3.546324e+00 @ (4, 11, 17)
Rank#11, time step = 3, continuity = 5.897940e-02 @ (4, 4, 35)
Rank#2, time step = 3, continuity = 4.119999e-03 @ (4, 51, 35)
Rank#0, time step = 3, continuity = 1.960288e-08 @ (19, 51, 7)
Rank#46, time step = 3, continuity = 1.202898e-03 @ (4, 50, 34)
Rank#8, time step = 3, continuity = 4.222265e-05 @ (41, 4, 35)
Rank#4, time step = 3, continuity = 9.702817e-03 @ (4, 51, 35)
Rank#5, time step = 3, continuity = 2.042632e-03 @ (4, 4, 4)
Rank#6, time step = 3, continuity = 1.251370e-03 @ (4, 4, 4)
Rank#30, time step = 3, continuity = 1.158913e-03 @ (4, 50, 5)
Rank#14, time step = 3, continuity = 1.228256e-03 @ (4, 50, 4)
Rank#7, time step = 3, continuity = 1.121091e-03 @ (4, 4, 4)
Rank#15, time step = 3, continuity = 1.112731e-03 @ (4, 50, 4)
Rank#16, time step = 3, continuity = 3.469996e-04 @ (41, 51, 4)
Rank#17, time step = 3, continuity = 5.357466e-03 @ (41, 51, 4)
Rank#18, time step = 3, continuity = 1.080270e-01 @ (39, 51, 4)
Rank#25, time step = 3, continuity = 5.597218e-03 @ (41, 4, 4)
Rank#13, time step = 3, continuity = 1.989096e-03 @ (4, 50, 4)
Rank#12, time step = 3, continuity = 1.013889e-02 @ (4, 4, 35)
Rank#26, time step = 3, continuity = 7.539334e-01 @ (39, 4, 17)
Rank#23, time step = 3, continuity = 1.112361e-03 @ (4, 4, 5)
Rank#20, time step = 3, continuity = 2.731360e-02 @ (4, 51, 20)
Rank#22, time step = 3, continuity = 1.184401e-03 @ (4, 4, 5)
Rank#21, time step = 3, continuity = 1.597810e-03 @ (4, 4, 5)
Rank#39, time step = 3, continuity = 1.112194e-03 @ (4, 5, 34)
Rank#36, time step = 3, continuity = 1.367959e-02 @ (5, 51, 4)
Rank#37, time step = 3, continuity = 1.986552e-03 @ (4, 4, 34)
Rank#40, time step = 3, continuity = 2.850005e-04 @ (41, 5, 4)
Rank#28, time step = 3, continuity = 2.828638e-02 @ (4, 4, 20)
Rank#38, time step = 3, continuity = 1.226979e-03 @ (4, 4, 34)
Rank#41, time step = 3, continuity = 5.161523e-03 @ (41, 5, 4)
Rank#29, time step = 3, continuity = 1.517670e-03 @ (4, 50, 5)
Rank#42, time step = 3, continuity = 1.294414e-01 @ (40, 5, 4)
Rank#43, time step = 3, continuity = 1.224322e-01 @ (19, 5, 4)
Rank#32, time step = 3, continuity = 2.852451e-04 @ (41, 51, 4)
Rank#31, time step = 3, continuity = 1.103723e-03 @ (4, 50, 5)
Rank#33, time step = 3, continuity = 5.164929e-03 @ (41, 51, 4)
Rank#34, time step = 3, continuity = 1.287048e-01 @ (40, 51, 4)
Rank#9, time step = 3, continuity = 2.683230e-04 @ (4, 50, 4)
Rank#1, time step = 3, continuity = 2.941918e-04 @ (4, 4, 4)
Rank#19, time step = 3, continuity = 3.689953e+00 @ (4, 51, 13)
Rank#47, time step = 3, continuity = 1.103518e-03 @ (4, 50, 34)
Rank#35, time step = 3, continuity = 1.214269e-01 @ (19, 51, 4)
Current time step = 4, Total time step number = 5
  0 KSP unpreconditioned resid norm 1.800295456670e+01 true resid norm 1.800295456670e+01 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 1.295938894634e+00 true resid norm 1.295938894634e+00 ||r(i)||/||b|| 7.198478948734e-02
  2 KSP unpreconditioned resid norm 3.597174991333e-01 true resid norm 3.597174991333e-01 ||r(i)||/||b|| 1.998102576999e-02
  3 KSP unpreconditioned resid norm 1.228849356110e-01 true resid norm 1.228849356110e-01 ||r(i)||/||b|| 6.825820459396e-03
  4 KSP unpreconditioned resid norm 5.526977676103e-02 true resid norm 5.526977676104e-02 ||r(i)||/||b|| 3.070039229186e-03
  5 KSP unpreconditioned resid norm 3.618819388233e-02 true resid norm 3.618819388233e-02 ||r(i)||/||b|| 2.010125268508e-03
  6 KSP unpreconditioned resid norm 2.416631959864e-02 true resid norm 2.416631959864e-02 ||r(i)||/||b|| 1.342352973736e-03
  7 KSP unpreconditioned resid norm 1.499930293446e-02 true resid norm 1.499930293447e-02 ||r(i)||/||b|| 8.331578507791e-04
  8 KSP unpreconditioned resid norm 1.055050367432e-02 true resid norm 1.055050367432e-02 ||r(i)||/||b|| 5.860428984156e-04
  9 KSP unpreconditioned resid norm 7.822204060520e-03 true resid norm 7.822204060528e-03 ||r(i)||/||b|| 4.344955730208e-04
 10 KSP unpreconditioned resid norm 5.732827542959e-03 true resid norm 5.732827542962e-03 ||r(i)||/||b|| 3.184381497893e-04
 11 KSP unpreconditioned resid norm 4.349201692653e-03 true resid norm 4.349201692655e-03 ||r(i)||/||b|| 2.415826622536e-04
 12 KSP unpreconditioned resid norm 3.507456574416e-03 true resid norm 3.507456574419e-03 ||r(i)||/||b|| 1.948267192156e-04
 13 KSP unpreconditioned resid norm 2.714359769664e-03 true resid norm 2.714359769663e-03 ||r(i)||/||b|| 1.507730167071e-04
 14 KSP unpreconditioned resid norm 2.159613131461e-03 true resid norm 2.159613131459e-03 ||r(i)||/||b|| 1.199588169518e-04
 15 KSP unpreconditioned resid norm 1.704473557682e-03 true resid norm 1.704473557679e-03 ||r(i)||/||b|| 9.467743482680e-05
 16 KSP unpreconditioned resid norm 1.390545859097e-03 true resid norm 1.390545859096e-03 ||r(i)||/||b|| 7.723986937498e-05
 17 KSP unpreconditioned resid norm 1.077180358743e-03 true resid norm 1.077180358741e-03 ||r(i)||/||b|| 5.983353203220e-05
 18 KSP unpreconditioned resid norm 9.048346152026e-04 true resid norm 9.048346152024e-04 ||r(i)||/||b|| 5.026033987087e-05
 19 KSP unpreconditioned resid norm 7.300819022225e-04 true resid norm 7.300819022251e-04 ||r(i)||/||b|| 4.055344913081e-05
 20 KSP unpreconditioned resid norm 6.034455779373e-04 true resid norm 6.034455779385e-04 ||r(i)||/||b|| 3.351925239286e-05
 21 KSP unpreconditioned resid norm 5.027864502361e-04 true resid norm 5.027864502383e-04 ||r(i)||/||b|| 2.792799639500e-05
 22 KSP unpreconditioned resid norm 4.185448641713e-04 true resid norm 4.185448641737e-04 ||r(i)||/||b|| 2.324867635604e-05
 23 KSP unpreconditioned resid norm 3.383127450993e-04 true resid norm 3.383127451025e-04 ||r(i)||/||b|| 1.879206792691e-05
 24 KSP unpreconditioned resid norm 2.658271933588e-04 true resid norm 2.658271933632e-04 ||r(i)||/||b|| 1.476575371994e-05
 25 KSP unpreconditioned resid norm 2.086016977258e-04 true resid norm 2.086016977289e-04 ||r(i)||/||b|| 1.158708127358e-05
 26 KSP unpreconditioned resid norm 1.553878432255e-04 true resid norm 1.553878432301e-04 ||r(i)||/||b|| 8.631241202902e-06
 27 KSP unpreconditioned resid norm 1.207652470263e-04 true resid norm 1.207652470298e-04 ||r(i)||/||b|| 6.708079308999e-06
 28 KSP unpreconditioned resid norm 9.478447325293e-05 true resid norm 9.478447325797e-05 ||r(i)||/||b|| 5.264939868996e-06
 29 KSP unpreconditioned resid norm 7.309077489139e-05 true resid norm 7.309077489702e-05 ||r(i)||/||b|| 4.059932197585e-06
 30 KSP unpreconditioned resid norm 5.488099653620e-05 true resid norm 5.488099653620e-05 ||r(i)||/||b|| 3.048443872524e-06
 31 KSP unpreconditioned resid norm 4.691702649096e-05 true resid norm 4.691702649093e-05 ||r(i)||/||b|| 2.606073704019e-06
 32 KSP unpreconditioned resid norm 3.921717594840e-05 true resid norm 3.921717594834e-05 ||r(i)||/||b|| 2.178374433098e-06
 33 KSP unpreconditioned resid norm 3.340909038588e-05 true resid norm 3.340909038575e-05 ||r(i)||/||b|| 1.855755968387e-06
 34 KSP unpreconditioned resid norm 2.772109424893e-05 true resid norm 2.772109424866e-05 ||r(i)||/||b|| 1.539808043505e-06
 35 KSP unpreconditioned resid norm 2.185592027217e-05 true resid norm 2.185592027141e-05 ||r(i)||/||b|| 1.214018520706e-06
 36 KSP unpreconditioned resid norm 1.903747666486e-05 true resid norm 1.903747666396e-05 ||r(i)||/||b|| 1.057464017555e-06
 37 KSP unpreconditioned resid norm 1.624600448157e-05 true resid norm 1.624600448058e-05 ||r(i)||/||b|| 9.024076809383e-07
 38 KSP unpreconditioned resid norm 1.420940242615e-05 true resid norm 1.420940242508e-05 ||r(i)||/||b|| 7.892816910929e-07
 39 KSP unpreconditioned resid norm 1.203584566250e-05 true resid norm 1.203584566145e-05 ||r(i)||/||b|| 6.685483550411e-07
 40 KSP unpreconditioned resid norm 1.020862316387e-05 true resid norm 1.020862316287e-05 ||r(i)||/||b|| 5.670526537766e-07
 41 KSP unpreconditioned resid norm 8.241595972505e-06 true resid norm 8.241595971594e-06 ||r(i)||/||b|| 4.577912998146e-07
 42 KSP unpreconditioned resid norm 6.689625267539e-06 true resid norm 6.689625266635e-06 ||r(i)||/||b|| 3.715848552441e-07
 43 KSP unpreconditioned resid norm 5.248454162379e-06 true resid norm 5.248454161620e-06 ||r(i)||/||b|| 2.915329337845e-07
 44 KSP unpreconditioned resid norm 3.931049414091e-06 true resid norm 3.931049413544e-06 ||r(i)||/||b|| 2.183557925994e-07
 45 KSP unpreconditioned resid norm 3.002868065889e-06 true resid norm 3.002868065505e-06 ||r(i)||/||b|| 1.667986248801e-07
 46 KSP unpreconditioned resid norm 2.243200121528e-06 true resid norm 2.243200121288e-06 ||r(i)||/||b|| 1.246017765016e-07
 47 KSP unpreconditioned resid norm 1.693164287854e-06 true resid norm 1.693164287781e-06 ||r(i)||/||b|| 9.404924516737e-08
Linear solve converged due to CONVERGED_RTOL iterations 47
Residual norm 1.69316e-06
  0 KSP unpreconditioned resid norm 1.412673063450e+00 true resid norm 1.412673063450e+00 ||r(i)||/||b|| 1.000000000000e+00
  1 KSP unpreconditioned resid norm 8.531572199357e-02 true resid norm 8.531572199358e-02 ||r(i)||/||b|| 6.039311161296e-02
  2 KSP unpreconditioned resid norm 2.354905984408e-02 true resid norm 2.354905984408e-02 ||r(i)||/||b|| 1.666985833691e-02
  3 KSP unpreconditioned resid norm 8.866561466319e-03 true resid norm 8.866561466321e-03 ||r(i)||/||b|| 6.276442650265e-03
  4 KSP unpreconditioned resid norm 4.007731044735e-03 true resid norm 4.007731044736e-03 ||r(i)||/||b|| 2.836984117859e-03
  5 KSP unpreconditioned resid norm 2.562270094262e-03 true resid norm 2.562270094262e-03 ||r(i)||/||b|| 1.813774298211e-03
  6 KSP unpreconditioned resid norm 1.648374750802e-03 true resid norm 1.648374750802e-03 ||r(i)||/||b|| 1.166848008538e-03
  7 KSP unpreconditioned resid norm 1.012675849200e-03 true resid norm 1.012675849200e-03 ||r(i)||/||b|| 7.168508237332e-04
  8 KSP unpreconditioned resid norm 6.975172897121e-04 true resid norm 6.975172897118e-04 ||r(i)||/||b|| 4.937570537433e-04
  9 KSP unpreconditioned resid norm 5.194036995358e-04 true resid norm 5.194036995367e-04 ||r(i)||/||b|| 3.676743848064e-04
 10 KSP unpreconditioned resid norm 3.696092053889e-04 true resid norm 3.696092053896e-04 ||r(i)||/||b|| 2.616381772629e-04
 11 KSP unpreconditioned resid norm 2.850523803892e-04 true resid norm 2.850523803895e-04 ||r(i)||/||b|| 2.017822720377e-04
 12 KSP unpreconditioned resid norm 2.350800134299e-04 true resid norm 2.350800134300e-04 ||r(i)||/||b|| 1.664079393259e-04
 13 KSP unpreconditioned resid norm 2.005287837193e-04 true resid norm 2.005287837191e-04 ||r(i)||/||b|| 1.419498884117e-04
 14 KSP unpreconditioned resid norm 1.693423716447e-04 true resid norm 1.693423716441e-04 ||r(i)||/||b|| 1.198737174407e-04
 15 KSP unpreconditioned resid norm 1.450875061234e-04 true resid norm 1.450875061229e-04 ||r(i)||/||b|| 1.027042348840e-04
 16 KSP unpreconditioned resid norm 1.255170696894e-04 true resid norm 1.255170696889e-04 ||r(i)||/||b|| 8.885075601452e-05
 17 KSP unpreconditioned resid norm 1.001150732534e-04 true resid norm 1.001150732528e-04 ||r(i)||/||b|| 7.086924486848e-05
 18 KSP unpreconditioned resid norm 8.324107526331e-05 true resid norm 8.324107526263e-05 ||r(i)||/||b|| 5.892451510282e-05
 19 KSP unpreconditioned resid norm 6.233954903979e-05 true resid norm 6.233954903940e-05 ||r(i)||/||b|| 4.412878722776e-05
 20 KSP unpreconditioned resid norm 5.068242281259e-05 true resid norm 5.068242281210e-05 ||r(i)||/||b|| 3.587696553675e-05
 21 KSP unpreconditioned resid norm 3.925070811210e-05 true resid norm 3.925070811142e-05 ||r(i)||/||b|| 2.778470767720e-05
 22 KSP unpreconditioned resid norm 3.353801271807e-05 true resid norm 3.353801271731e-05 ||r(i)||/||b|| 2.374081702626e-05
 23 KSP unpreconditioned resid norm 2.647759351203e-05 true resid norm 2.647759351127e-05 ||r(i)||/||b|| 1.874290251319e-05
 24 KSP unpreconditioned resid norm 2.135260655706e-05 true resid norm 2.135260655663e-05 ||r(i)||/||b|| 1.511503766093e-05
 25 KSP unpreconditioned resid norm 1.687070927407e-05 true resid norm 1.687070927336e-05 ||r(i)||/||b|| 1.194240175582e-05
 26 KSP unpreconditioned resid norm 1.293694698390e-05 true resid norm 1.293694698317e-05 ||r(i)||/||b|| 9.157778482429e-06
 27 KSP unpreconditioned resid norm 1.049854679096e-05 true resid norm 1.049854679022e-05 ||r(i)||/||b|| 7.431688946185e-06
 28 KSP unpreconditioned resid norm 8.323105069998e-06 true resid norm 8.323105069154e-06 ||r(i)||/||b|| 5.891741893078e-06
 29 KSP unpreconditioned resid norm 7.149131008665e-06 true resid norm 7.149131007929e-06 ||r(i)||/||b|| 5.060711634486e-06
 30 KSP unpreconditioned resid norm 5.765627614985e-06 true resid norm 5.765627614985e-06 ||r(i)||/||b|| 4.081360198730e-06
 31 KSP unpreconditioned resid norm 5.420427196404e-06 true resid norm 5.420427196403e-06 ||r(i)||/||b|| 3.837000461497e-06
 32 KSP unpreconditioned resid norm 4.532576209396e-06 true resid norm 4.532576209394e-06 ||r(i)||/||b|| 3.208510395408e-06
 33 KSP unpreconditioned resid norm 4.064657789569e-06 true resid norm 4.064657789567e-06 ||r(i)||/||b|| 2.877281300770e-06
 34 KSP unpreconditioned resid norm 3.349298785897e-06 true resid norm 3.349298785894e-06 ||r(i)||/||b|| 2.370894492540e-06
 35 KSP unpreconditioned resid norm 2.848140811778e-06 true resid norm 2.848140811775e-06 ||r(i)||/||b|| 2.016135852990e-06
 36 KSP unpreconditioned resid norm 2.272096193713e-06 true resid norm 2.272096193716e-06 ||r(i)||/||b|| 1.608366615391e-06
 37 KSP unpreconditioned resid norm 1.902087742756e-06 true resid norm 1.902087742762e-06 ||r(i)||/||b|| 1.346445821028e-06
 38 KSP unpreconditioned resid norm 1.556881030367e-06 true resid norm 1.556881030374e-06 ||r(i)||/||b|| 1.102081628548e-06
 39 KSP unpreconditioned resid norm 1.348642308105e-06 true resid norm 1.348642308109e-06 ||r(i)||/||b|| 9.546740452567e-07
 40 KSP unpreconditioned resid norm 1.100324584644e-06 true resid norm 1.100324584650e-06 ||r(i)||/||b|| 7.788954239433e-07
 41 KSP unpreconditioned resid norm 9.053973900964e-07 true resid norm 9.053973900970e-07 ||r(i)||/||b|| 6.409107765427e-07
 42 KSP unpreconditioned resid norm 7.230581243700e-07 true resid norm 7.230581243733e-07 ||r(i)||/||b|| 5.118368453966e-07
 43 KSP unpreconditioned resid norm 5.825287157867e-07 true resid norm 5.825287157901e-07 ||r(i)||/||b|| 4.123591868930e-07
 44 KSP unpreconditioned resid norm 4.762644417313e-07 true resid norm 4.762644417360e-07 ||r(i)||/||b|| 3.371370588555e-07
 45 KSP unpreconditioned resid norm 3.865941721477e-07 true resid norm 3.865941721540e-07 ||r(i)||/||b|| 2.736614593682e-07
 46 KSP unpreconditioned resid norm 3.263216396424e-07 true resid norm 3.263216396447e-07 ||r(i)||/||b|| 2.309958674003e-07
 47 KSP unpreconditioned resid norm 2.681743797359e-07 true resid norm 2.681743797427e-07 ||r(i)||/||b|| 1.898347088800e-07
 48 KSP unpreconditioned resid norm 2.281833238064e-07 true resid norm 2.281833238130e-07 ||r(i)||/||b|| 1.615259253657e-07
 49 KSP unpreconditioned resid norm 1.815350740360e-07 true resid norm 1.815350740409e-07 ||r(i)||/||b|| 1.285046616501e-07
 50 KSP unpreconditioned resid norm 1.392510493034e-07 true resid norm 1.392510493056e-07 ||r(i)||/||b|| 9.857273626037e-08
Linear solve converged due to CONVERGED_RTOL iterations 50
Residual norm 1.39251e-07
Rank#47, time step = 4, continuity = 9.072241e-04 @ (4, 50, 34)
Rank#32, time step = 4, continuity = 2.993468e-04 @ (41, 51, 4)
Rank#34, time step = 4, continuity = 1.409515e-01 @ (40, 51, 4)
Rank#0, time step = 4, continuity = 2.806779e-08 @ (41, 51, 35)
Rank#9, time step = 4, continuity = 3.242195e-04 @ (4, 50, 4)
Rank#1, time step = 4, continuity = 3.559030e-04 @ (4, 4, 4)
Rank#10, time step = 4, continuity = 4.821606e-03 @ (4, 5, 35)
Rank#27, time step = 4, continuity = 3.181760e+00 @ (4, 8, 14)
Rank#36, time step = 4, continuity = 1.548400e-02 @ (5, 51, 4)
Rank#37, time step = 4, continuity = 1.847557e-03 @ (4, 4, 34)
Rank#8, time step = 4, continuity = 4.587898e-05 @ (41, 4, 35)
Rank#44, time step = 4, continuity = 1.552645e-02 @ (5, 5, 4)
Rank#16, time step = 4, continuity = 3.709613e-04 @ (41, 51, 4)
Rank#4, time step = 4, continuity = 1.173989e-02 @ (4, 51, 35)
Rank#45, time step = 4, continuity = 1.782619e-03 @ (4, 50, 34)
Rank#18, time step = 4, continuity = 1.182176e-01 @ (39, 51, 4)
Rank#5, time step = 4, continuity = 1.908359e-03 @ (4, 4, 4)
Rank#46, time step = 4, continuity = 9.872820e-04 @ (4, 50, 34)
Rank#6, time step = 4, continuity = 1.039245e-03 @ (4, 4, 4)
Rank#12, time step = 4, continuity = 1.240915e-02 @ (4, 4, 35)
Rank#25, time step = 4, continuity = 6.008582e-03 @ (41, 4, 4)
Rank#13, time step = 4, continuity = 1.847262e-03 @ (4, 50, 4)
Rank#14, time step = 4, continuity = 1.013285e-03 @ (4, 50, 4)
Rank#24, time step = 4, continuity = 4.176380e-04 @ (41, 4, 4)
Rank#40, time step = 4, continuity = 2.993544e-04 @ (41, 5, 4)
Rank#42, time step = 4, continuity = 1.417756e-01 @ (40, 5, 4)
Rank#28, time step = 4, continuity = 3.335993e-02 @ (4, 4, 20)
Rank#43, time step = 4, continuity = 1.360899e-01 @ (19, 5, 4)
Rank#29, time step = 4, continuity = 1.310806e-03 @ (4, 50, 5)
Rank#33, time step = 4, continuity = 5.532869e-03 @ (41, 51, 4)
Rank#23, time step = 4, continuity = 9.159324e-04 @ (4, 4, 5)
Rank#2, time step = 4, continuity = 4.837666e-03 @ (4, 51, 35)
Rank#20, time step = 4, continuity = 3.225439e-02 @ (4, 51, 20)
Rank#21, time step = 4, continuity = 1.402715e-03 @ (4, 4, 5)
Rank#22, time step = 4, continuity = 9.657753e-04 @ (4, 4, 5)
Rank#26, time step = 4, continuity = 6.323174e-01 @ (39, 4, 17)
Rank#19, time step = 4, continuity = 3.372144e+00 @ (4, 51, 13)
Rank#30, time step = 4, continuity = 9.366603e-04 @ (4, 50, 5)
Rank#41, time step = 4, continuity = 5.527059e-03 @ (41, 5, 4)
Rank#38, time step = 4, continuity = 1.013971e-03 @ (4, 4, 34)
Rank#11, time step = 4, continuity = 6.808021e-02 @ (4, 4, 35)
Rank#31, time step = 4, continuity = 9.066095e-04 @ (4, 50, 5)
Rank#17, time step = 4, continuity = 5.747098e-03 @ (41, 51, 4)
Rank#39, time step = 4, continuity = 9.165216e-04 @ (4, 5, 34)
Rank#3, time step = 4, continuity = 6.498223e-02 @ (4, 51, 35)
Rank#7, time step = 4, continuity = 9.252253e-04 @ (4, 4, 4)
Rank#15, time step = 4, continuity = 9.161437e-04 @ (4, 50, 4)
Rank#35, time step = 4, continuity = 1.349255e-01 @ (19, 51, 4)
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./ex45 on a arch-linux2-c-debug named compute-8-8.local with 48 processors, by zlwei Fri Oct  5 14:00:22 2012
Using Petsc Development HG revision: 98bf11863c3be31b7c2af504314a500bc64d88c9  HG Date: Wed Aug 29 13:51:08 2012 -0500
                         Max       Max/Min        Avg      Total
Time (sec):           1.246e+02      1.00015   1.246e+02
Objects:              5.499e+03      1.00000   5.499e+03
Flops:                8.761e+09      1.03903   8.570e+09  4.114e+11
Flops/sec:            7.034e+07      1.03901   6.881e+07  3.303e+09
MPI Messages:         1.089e+05      2.25599   7.804e+04  3.746e+06
MPI Message Lengths:  4.049e+08      1.75931   4.110e+03  1.540e+10
MPI Reductions:       2.272e+04      1.00000
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 4.0932e+01  32.9%  4.6734e+08   0.1%  1.037e+04   0.3%  1.167e+03       28.4%  3.200e+01   0.1%
 1:      DMMG Setup: 3.5440e+00   2.8%  0.0000e+00   0.0%  1.528e+03   0.0%  6.567e-01        0.0%  3.500e+01   0.2%
 2: Pressure RHS Setup: 1.0369e+01   8.3%  1.4382e+10   3.5%  3.013e+05   8.0%  2.590e+02        6.3%  3.635e+03  16.0%
 3:  Pressure Solve: 2.8890e+01  23.2%  1.8356e+11  44.6%  1.513e+06  40.4%  1.171e+03       28.5%  7.453e+03  32.8%
 4: Corrector RHS Setup: 9.9616e+00   8.0%  1.4382e+10   3.5%  3.013e+05   8.0%  2.590e+02        6.3%  3.635e+03  16.0%
 5: Corrector Solve: 3.0856e+01  24.8%  1.9859e+11  48.3%  1.619e+06  43.2%  1.253e+03       30.5%  7.929e+03  34.9%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %f - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %f %M %L %R  %T %f %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecNorm               10 1.0 5.0277e-02 2.3 1.17e+06 1.0 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  0   0 12  0  0 31  1100
VecSet                 1 1.0 2.1939e-03 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               10 1.0 2.4841e-03 1.6 1.17e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 12  0  0  0 22260
VecScatterBegin       11 1.0 5.4202e-03 3.0 0.00e+00 0.0 2.5e+03 1.2e+04 0.0e+00  0  0  0  0  0   0  0 24  1  0     0
VecScatterEnd         11 1.0 2.4676e-0213.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult               10 1.0 4.8111e-02 1.7 7.56e+06 1.0 2.0e+03 1.2e+04 0.0e+00  0  0  0  0  0   0 76 19  1  0  7415
--- Event Stage 1: DMMG Setup
--- Event Stage 2: Pressure RHS Setup
KSPGMRESOrthog       150 1.0 4.9527e-01 1.7 7.04e+07 1.0 0.0e+00 0.0e+00 1.5e+02  0  1  0  0  1   4 23  0  0  4  6736
KSPSetUp              40 1.0 2.1560e-01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.8e+02  0  0  0  0  1   2  0  0  0  5     0
VecMDot              150 1.0 4.3920e-01 1.9 3.52e+07 1.0 0.0e+00 0.0e+00 1.5e+02  0  0  0  0  1   3 12  0  0  4  3798
VecNorm              165 1.0 3.3326e-01 2.4 7.04e+06 1.0 0.0e+00 0.0e+00 1.6e+02  0  0  0  0  1   2  2  0  0  5  1001
VecScale             165 1.0 1.0014e-02 2.8 3.52e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 16657
VecCopy               15 1.0 1.6418e-03 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               235 1.0 7.2906e-03 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               15 1.0 1.8489e-03 2.1 6.40e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 16402
VecMAXPY             165 1.0 9.6994e-02 2.0 4.16e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1 14  0  0  0 20323
VecAssemblyBegin     215 1.0 6.1984e-01 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 6.3e+02  0  0  0  0  3   5  0  0  0 17     0
VecAssemblyEnd       215 1.0 4.8971e-04 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult     165 1.0 3.1083e-02 1.8 3.52e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0  5366
VecScatterBegin      375 1.0 6.6681e-02 3.3 0.00e+00 0.0 1.7e+05 3.4e+03 0.0e+00  0  0  5  4  0   0  0 56 60  0     0
VecScatterEnd        375 1.0 5.2347e-01 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   4  0  0  0  0     0
VecSetRandom          15 1.0 1.0735e-02 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         165 1.0 3.4388e-01 2.3 1.06e+07 1.0 0.0e+00 0.0e+00 1.6e+02  0  0  0  0  1   2  3  0  0  5  1455
MatMult              150 1.0 3.7738e-01 2.0 4.51e+07 1.0 5.7e+04 2.8e+03 0.0e+00  0  1  2  1  0   3 15 19 16  0  5631
MatConvert            15 1.0 6.1136e-02 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  0     0
MatScale              15 1.0 1.3903e-01 4.2 4.83e+06 1.0 5.7e+03 2.8e+03 0.0e+00  0  0  0  0  0   1  2  2  2  0  1638
MatAssemblyBegin     195 1.0 1.5021e+00 1.4 0.00e+00 0.0 1.3e+04 6.0e+02 2.2e+02  1  0  0  0  1  13  0  4  1  6     0
MatAssemblyEnd       195 1.0 1.0008e+00 1.3 0.00e+00 0.0 5.2e+04 6.3e+02 6.0e+02  1  0  1  0  3   8  0 17  3 17     0
MatGetRow         639730 1.0 1.6904e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
MatCoarsen            15 1.0 6.1620e-01 1.0 0.00e+00 0.0 5.3e+04 3.7e+03 4.3e+02  0  0  1  1  2   6  0 18 20 12     0
MatPtAP               15 1.0 7.3923e-01 1.1 1.40e+07 1.1 4.8e+04 1.0e+03 4.0e+02  1  0  1  0  2   7  5 16  5 11   886
MatPtAPSymbolic       15 1.0 5.5060e-01 1.1 0.00e+00 0.0 4.4e+04 9.0e+02 3.8e+02  0  0  1  0  2   5  0 15  4 10     0
MatPtAPNumeric        15 1.0 2.1724e-01 1.3 1.40e+07 1.1 4.3e+03 2.2e+03 3.0e+01  0  0  0  0  0   2  5  1  1  1  3014
MatTrnMatMult         15 1.0 3.4586e+00 1.0 1.51e+08 1.1 3.9e+04 7.8e+03 4.4e+02  3  2  1  2  2  33 49 13 31 12  2035
MatGetLocalMat        45 1.0 1.1697e-01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+01  0  0  0  0  0   1  0  0  0  2     0
MatGetBrAoCol         15 1.0 1.0516e-01 2.3 0.00e+00 0.0 1.7e+04 1.8e+03 3.0e+01  0  0  0  0  0   1  0  6  3  1     0
MatGetSymTrans        30 1.0 5.6214e-03 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCSetUp                5 1.0 8.6096e+00 1.0 3.07e+08 1.0 2.9e+05 3.3e+03 3.2e+03  7  3  8  6 14  83100 97 98 89  1670
PCGAMGgraph_AGG        3 1.0 3.7921e-01 1.1 9.66e+05 1.0 3.4e+03 1.4e+03 5.7e+01  0  0  0  0  0   3  0  1  0  2   120
PCGAMGcoarse_AGG       3 1.0 1.0288e+00 1.0 3.03e+07 1.1 2.6e+04 5.0e+03 2.3e+02  1  0  1  1  1  10 10  9 13  6  1368
PCGAMGProl_AGG         3 1.0 1.2415e-01 1.1 0.00e+00 0.0 7.4e+03 2.0e+03 8.4e+01  0  0  0  0  0   1  0  2  2  2     0
PCGAMGPOpt_AGG         3 1.0 1.4067e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCGAMGgraph_AGG        3 1.0 2.9839e-01 1.1 9.66e+05 1.0 3.4e+03 1.4e+03 5.7e+01  0  0  0  0  0   3  0  1  0  2   153
PCGAMGcoarse_AGG       3 1.0 8.6779e-01 1.0 3.03e+07 1.1 2.6e+04 5.0e+03 2.3e+02  1  0  1  1  1   8 10  9 13  6  1622
PCGAMGProl_AGG         3 1.0 1.2736e-01 1.1 0.00e+00 0.0 7.4e+03 2.0e+03 8.4e+01  0  0  0  0  0   1  0  2  2  2     0
PCGAMGPOpt_AGG         3 1.0 3.3379e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCGAMGgraph_AGG        3 1.0 2.7482e-01 1.1 9.66e+05 1.0 3.4e+03 1.4e+03 5.7e+01  0  0  0  0  0   2  0  1  0  2   166
PCGAMGcoarse_AGG       3 1.0 8.9944e-01 1.0 3.03e+07 1.1 2.6e+04 5.0e+03 2.3e+02  1  0  1  1  1   9 10  9 13  6  1565
PCGAMGProl_AGG         3 1.0 1.2325e-01 1.1 0.00e+00 0.0 7.4e+03 2.0e+03 8.4e+01  0  0  0  0  0   1  0  2  2  2     0
PCGAMGPOpt_AGG         3 1.0 1.5020e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCGAMGgraph_AGG        3 1.0 2.8151e-01 1.1 9.66e+05 1.0 3.4e+03 1.4e+03 5.7e+01  0  0  0  0  0   3  0  1  0  2   162
PCGAMGcoarse_AGG       3 1.0 8.8194e-01 1.0 3.03e+07 1.1 2.6e+04 5.0e+03 2.3e+02  1  0  1  1  1   8 10  9 13  6  1596
PCGAMGProl_AGG         3 1.0 1.3077e-01 1.1 0.00e+00 0.0 7.4e+03 2.0e+03 8.4e+01  0  0  0  0  0   1  0  2  2  2     0
PCGAMGgraph_AGG        3 1.0 2.7213e-01 1.1 9.66e+05 1.0 3.4e+03 1.4e+03 5.7e+01  0  0  0  0  0   2  0  1  0  2   167
PCGAMGcoarse_AGG       3 1.0 8.9080e-01 1.0 3.03e+07 1.1 2.6e+04 5.0e+03 2.3e+02  1  0  1  1  1   9 10  9 13  6  1580
PCGAMGProl_AGG         3 1.0 1.3203e-01 1.1 0.00e+00 0.0 7.4e+03 2.0e+03 8.4e+01  0  0  0  0  0   1  0  2  2  2     0
PCGAMGPOpt_AGG         3 1.0 5.9605e-06 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
--- Event Stage 3: Pressure Solve
KSPGMRESOrthog      1928 1.0 7.4579e+00 1.6 8.71e+08 1.0 0.0e+00 0.0e+00 1.9e+03  5 10  0  0  8  20 22  0  0 26  5531
KSPSetUp              20 1.0 2.8610e-05 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               5 1.0 2.8903e+01 1.0 3.92e+09 1.0 1.5e+06 2.9e+03 7.5e+03 23 45 40 28 33 100100100100100  6351
VecMDot             1928 1.0 6.7700e+00 1.7 4.36e+08 1.0 0.0e+00 0.0e+00 1.9e+03  4  5  0  0  8  17 11  0  0 26  3046
VecNorm             3876 1.0 9.7277e+00 1.8 1.82e+08 1.0 0.0e+00 0.0e+00 3.9e+03  6  2  0  0 17  24  5  0  0 52   887
VecScale            3625 1.0 2.0565e-01 2.6 7.66e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  2  0  0  0 17592
VecCopy             1938 1.0 2.5364e-01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecSet              7958 1.0 4.1689e-01 1.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecAXPY             2656 1.0 2.5585e-01 1.5 1.21e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  3  0  0  0 22458
VecAYPX              969 1.0 1.5139e-01 1.5 2.98e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0  9321
VecWAXPY               5 1.0 2.1451e-03 1.6 2.92e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  6445
VecMAXPY            3861 1.0 2.1212e+00 1.6 8.82e+08 1.0 0.0e+00 0.0e+00 0.0e+00  1 10  0  0  0   6 23  0  0  0 19683
VecAssemblyBegin       5 1.0 7.7687e-02 2.2 0.00e+00 0.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         5 1.0 1.7405e-05 3.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin     5071 1.0 6.4226e-01 2.6 0.00e+00 0.0 1.5e+06 2.9e+03 0.0e+00  0  0 40 28  0   1  0100100  0     0
VecScatterEnd       5071 1.0 4.6577e+00 2.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0  10  0  0  0  0     0
VecNormalize        3374 1.0 7.3255e+00 1.7 1.86e+08 1.0 0.0e+00 0.0e+00 3.4e+03  4  2  0  0 15  18  5  0  0 45  1197
MatMult             3625 1.0 9.2039e+00 1.6 1.24e+09 1.0 1.2e+06 3.5e+03 0.0e+00  6 14 32 27  0  27 32 79 96  0  6359
MatMultAdd           723 1.0 1.2736e+00 3.1 3.08e+07 1.0 1.6e+05 5.0e+02 0.0e+00  1  0  4  1  0   2  1 10  2  0  1148
MatMultTranspose     723 1.0 9.4210e-01 1.9 3.08e+07 1.0 1.6e+05 5.0e+02 0.0e+00  1  0  4  1  0   2  1 10  2  0  1552
MatSolve            3374 1.2 3.9078e+00 1.6 8.80e+08 1.1 0.0e+00 0.0e+00 0.0e+00  3 10  0  0  0  11 22  0  0  0 10213
MatLUFactorSym         5 1.0 6.0294e-0367.6 0.00e+00 0.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum        20 1.0 9.0770e-02 1.4 1.98e+07 2.5 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4485
MatILUFactorSym       15 1.0 5.6968e-02 2.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ           20 1.3 4.4918e-0458.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering        20 1.3 6.2945e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+01  0  0  0  0  0   0  0  0  0  0     0
PCSetUp               20 1.0 1.5481e-01 1.6 1.98e+07 2.5 0.0e+00 0.0e+00 7.0e+01  0  0  0  0  0   0  0  0  0  1  2630
PCSetUpOnBlocks     1687 1.0 1.5688e-01 1.5 1.98e+07 2.5 0.0e+00 0.0e+00 7.0e+01  0  0  0  0  0   0  0  0  0  1  2595
PCApply              241 1.0 1.9936e+01 1.0 2.30e+09 1.1 1.4e+06 2.3e+03 5.1e+03 16 26 38 21 23  68 58 94 73 69  5361
--- Event Stage 4: Corrector RHS Setup
KSPGMRESOrthog       150 1.0 4.4386e-01 1.5 7.04e+07 1.0 0.0e+00 0.0e+00 1.5e+02  0  1  0  0  1   4 23  0  0  4  7516
KSPSetUp              40 1.0 1.8739e-01 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 1.8e+02  0  0  0  0  1   2  0  0  0  5     0
VecMDot              150 1.0 3.9025e-01 1.7 3.52e+07 1.0 0.0e+00 0.0e+00 1.5e+02  0  0  0  0  1   3 12  0  0  4  4274
VecNorm              165 1.0 3.0658e-01 2.2 7.04e+06 1.0 0.0e+00 0.0e+00 1.6e+02  0  0  0  0  1   2  2  0  0  5  1088
VecScale             165 1.0 1.0942e-02 3.1 3.52e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 15243
VecCopy               15 1.0 3.6764e-03 5.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               235 1.0 7.4570e-03 1.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               15 1.0 1.7416e-03 1.9 6.40e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 17413
VecMAXPY             165 1.0 1.0165e-01 2.1 4.16e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1 14  0  0  0 19393
VecAssemblyBegin     215 1.0 5.6306e-01 1.3 0.00e+00 0.0 0.0e+00 0.0e+00 6.3e+02  0  0  0  0  3   5  0  0  0 17     0
VecAssemblyEnd       215 1.0 1.0600e-03 4.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecPointwiseMult     165 1.0 3.2980e-02 2.0 3.52e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0  5057
VecScatterBegin      375 1.0 6.3563e-02 3.1 0.00e+00 0.0 1.7e+05 3.4e+03 0.0e+00  0  0  5  4  0   0  0 56 60  0     0
VecScatterEnd        375 1.0 5.1996e-01 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   4  0  0  0  0     0
VecSetRandom          15 1.0 9.5236e-03 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         165 1.0 3.1596e-01 2.2 1.06e+07 1.0 0.0e+00 0.0e+00 1.6e+02  0  0  0  0  1   2  3  0  0  5  1584
MatMult              150 1.0 3.3380e-01 1.8 4.51e+07 1.0 5.7e+04 2.8e+03 0.0e+00  0  1  2  1  0   3 15 19 16  0  6366
MatConvert            15 1.0 5.5341e-02 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  0     0
MatScale              15 1.0 9.3830e-02 3.1 4.83e+06 1.0 5.7e+03 2.8e+03 0.0e+00  0  0  0  0  0   1  2  2  2  0  2426
MatAssemblyBegin     195 1.0 1.3034e+00 1.5 0.00e+00 0.0 1.3e+04 6.0e+02 2.2e+02  1  0  0  0  1  11  0  4  1  6     0
MatAssemblyEnd       195 1.0 9.7578e-01 1.2 0.00e+00 0.0 5.2e+04 6.3e+02 6.0e+02  1  0  1  0  3   9  0 17  3 17     0
MatGetRow         639730 1.0 1.8638e-01 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   2  0  0  0  0     0
MatCoarsen            15 1.0 6.0700e-01 1.1 0.00e+00 0.0 5.3e+04 3.7e+03 4.3e+02  0  0  1  1  2   6  0 18 20 12     0
MatPtAP               15 1.0 7.4058e-01 1.1 1.40e+07 1.1 4.8e+04 1.0e+03 4.0e+02  1  0  1  0  2   7  5 16  5 11   884
MatPtAPSymbolic       15 1.0 5.6122e-01 1.1 0.00e+00 0.0 4.4e+04 9.0e+02 3.8e+02  0  0  1  0  2   5  0 15  4 10     0
MatPtAPNumeric        15 1.0 2.1232e-01 1.3 1.40e+07 1.1 4.3e+03 2.2e+03 3.0e+01  0  0  0  0  0   2  5  1  1  1  3084
MatTrnMatMult         15 1.0 3.2677e+00 1.0 1.51e+08 1.1 3.9e+04 7.8e+03 4.4e+02  3  2  1  2  2  33 49 13 31 12  2154
MatGetLocalMat        45 1.0 1.1687e-01 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 6.0e+01  0  0  0  0  0   1  0  0  0  2     0
MatGetBrAoCol         15 1.0 1.0224e-01 2.1 0.00e+00 0.0 1.7e+04 1.8e+03 3.0e+01  0  0  0  0  0   1  0  6  3  1     0
MatGetSymTrans        30 1.0 5.1825e-03 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCSetUp                5 1.0 8.2378e+00 1.0 3.07e+08 1.0 2.9e+05 3.3e+03 3.2e+03  7  3  8  6 14  83100 97 98 89  1746
PCGAMGgraph_AGG        3 1.0 2.6251e-01 1.1 9.66e+05 1.0 3.4e+03 1.4e+03 5.7e+01  0  0  0  0  0   2  0  1  0  2   173
PCGAMGcoarse_AGG       3 1.0 8.3389e-01 1.0 3.03e+07 1.1 2.6e+04 5.0e+03 2.3e+02  1  0  1  1  1   8 10  9 13  6  1688
PCGAMGProl_AGG         3 1.0 1.2837e-01 1.1 0.00e+00 0.0 7.4e+03 2.0e+03 8.4e+01  0  0  0  0  0   1  0  2  2  2     0
PCGAMGgraph_AGG        3 1.0 2.7516e-01 1.1 9.66e+05 1.0 3.4e+03 1.4e+03 5.7e+01  0  0  0  0  0   3  0  1  0  2   165
PCGAMGcoarse_AGG       3 1.0 8.5538e-01 1.0 3.03e+07 1.1 2.6e+04 5.0e+03 2.3e+02  1  0  1  1  1   9 10  9 13  6  1646
PCGAMGProl_AGG         3 1.0 1.3015e-01 1.1 0.00e+00 0.0 7.4e+03 2.0e+03 8.4e+01  0  0  0  0  0   1  0  2  2  2     0
PCGAMGPOpt_AGG         3 1.0 1.3113e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCGAMGgraph_AGG        3 1.0 2.8946e-01 1.1 9.66e+05 1.0 3.4e+03 1.4e+03 5.7e+01  0  0  0  0  0   3  0  1  0  2   157
PCGAMGcoarse_AGG       3 1.0 8.7704e-01 1.0 3.03e+07 1.1 2.6e+04 5.0e+03 2.3e+02  1  0  1  1  1   9 10  9 13  6  1605
PCGAMGProl_AGG         3 1.0 1.3723e-01 1.1 0.00e+00 0.0 7.4e+03 2.0e+03 8.4e+01  0  0  0  0  0   1  0  2  2  2     0
PCGAMGPOpt_AGG         3 1.0 1.1921e-05 0.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCGAMGgraph_AGG        3 1.0 2.7662e-01 1.1 9.66e+05 1.0 3.4e+03 1.4e+03 5.7e+01  0  0  0  0  0   3  0  1  0  2   165
PCGAMGcoarse_AGG       3 1.0 9.1107e-01 1.0 3.03e+07 1.1 2.6e+04 5.0e+03 2.3e+02  1  0  1  1  1   9 10  9 13  6  1545
PCGAMGProl_AGG         3 1.0 1.2597e-01 1.1 0.00e+00 0.0 7.4e+03 2.0e+03 8.4e+01  0  0  0  0  0   1  0  2  2  2     0
PCGAMGgraph_AGG        3 1.0 2.7047e-01 1.1 9.66e+05 1.0 3.4e+03 1.4e+03 5.7e+01  0  0  0  0  0   3  0  1  0  2   168
PCGAMGcoarse_AGG       3 1.0 8.7131e-01 1.0 3.03e+07 1.1 2.6e+04 5.0e+03 2.3e+02  1  0  1  1  1   9 10  9 13  6  1615
PCGAMGProl_AGG         3 1.0 1.3009e-01 1.1 0.00e+00 0.0 7.4e+03 2.0e+03 8.4e+01  0  0  0  0  0   1  0  2  2  2     0
--- Event Stage 5: Corrector Solve
KSPGMRESOrthog      2064 1.0 7.7906e+00 1.5 9.62e+08 1.0 0.0e+00 0.0e+00 2.1e+03  5 11  0  0  9  20 23  0  0 26  5847
KSPSetUp              20 1.0 3.0756e-05 2.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               5 1.0 3.0870e+01 1.0 4.24e+09 1.0 1.6e+06 2.9e+03 7.9e+03 25 48 43 30 35 100100100100100  6433
VecMDot             2064 1.0 7.0200e+00 1.6 4.81e+08 1.0 0.0e+00 0.0e+00 2.1e+03  4  6  0  0  9  17 11  0  0 26  3245
VecNorm             4148 1.0 1.0233e+01 1.8 1.95e+08 1.0 0.0e+00 0.0e+00 4.1e+03  6  2  0  0 18  24  5  0  0 52   901
VecScale            3880 1.0 2.1841e-01 2.6 8.19e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  2  0  0  0 17724
VecCopy             2074 1.0 2.7166e-01 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecSet              8519 1.0 4.5739e-01 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1  0  0  0  0     0
VecAXPY             2843 1.0 2.7114e-01 1.4 1.30e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1  3  0  0  0 22680
VecAYPX             1037 1.0 1.6162e-01 1.5 3.19e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0  9340
VecWAXPY               5 1.0 2.2409e-03 1.7 2.92e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  6169
VecMAXPY            4133 1.0 2.3573e+00 1.6 9.75e+08 1.0 0.0e+00 0.0e+00 0.0e+00  2 11  0  0  0   6 23  0  0  0 19578
VecAssemblyBegin       5 1.0 3.8697e-02 2.7 0.00e+00 0.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         5 1.0 1.5497e-05 2.6 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin     5428 1.0 6.7515e-01 2.6 0.00e+00 0.0 1.6e+06 2.9e+03 0.0e+00  0  0 43 30  0   1  0100100  0     0
VecScatterEnd       5428 1.0 4.9356e+00 2.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  2  0  0  0  0  10  0  0  0  0     0
VecNormalize        3612 1.0 7.7312e+00 1.7 1.99e+08 1.0 0.0e+00 0.0e+00 3.6e+03  5  2  0  0 16  18  5  0  0 46  1215
MatMult             3880 1.0 9.8883e+00 1.5 1.33e+09 1.0 1.3e+06 3.5e+03 0.0e+00  7 15 34 29  0  27 32 79 96  0  6334
MatMultAdd           774 1.0 1.3812e+00 3.1 3.30e+07 1.0 1.7e+05 5.0e+02 0.0e+00  1  0  4  1  0   3  1 10  2  0  1133
MatMultTranspose     774 1.0 1.0163e+00 1.9 3.30e+07 1.0 1.7e+05 5.0e+02 0.0e+00  1  0  4  1  0   2  1 10  2  0  1540
MatSolve            3612 1.2 4.1856e+00 1.6 9.42e+08 1.1 0.0e+00 0.0e+00 0.0e+00  3 10  0  0  0  11 22  0  0  0 10208
MatLUFactorSym         5 1.0 5.9757e-0368.5 0.00e+00 0.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  0     0
MatLUFactorNum        20 1.0 9.2276e-02 1.4 1.98e+07 2.5 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4412
MatILUFactorSym       15 1.0 4.9916e-02 2.0 0.00e+00 0.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ           20 1.3 4.3893e-0476.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering        20 1.3 2.0333e-02 6.4 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+01  0  0  0  0  0   0  0  0  0  0     0
PCSetUp               20 1.0 1.3867e-01 1.4 1.98e+07 2.5 0.0e+00 0.0e+00 7.0e+01  0  0  0  0  0   0  0  0  0  1  2936
PCSetUpOnBlocks     1806 1.0 1.4069e-01 1.4 1.98e+07 2.5 0.0e+00 0.0e+00 7.0e+01  0  0  0  0  0   0  0  0  0  1  2894
PCApply              258 1.0 2.1168e+01 1.0 2.46e+09 1.1 1.5e+06 2.3e+03 5.5e+03 17 28 40 22 24  68 58 94 73 69  5404
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
           Container     0             10         5480     0
       Krylov Solver     0             91       970112     0
              Vector    11           1172    387333592     0
      Vector Scatter     0            114       118104     0
              Matrix     0            310    190831360     0
    Distributed Mesh     0             22     16761112     0
     Bipartite Graph     0             44        30096     0
           Index Set     0            140      2717000     0
   IS L to G Mapping     0             33     11117700     0
      Preconditioner     0             90        89240     0
       Krylov Solver     1              0            0     0
              Vector     5              4         5856     0
      Vector Scatter     4              0            0     0
    Distributed Mesh     2              0            0     0
     Bipartite Graph     4              0            0     0
           Index Set    10             10       511452     0
   IS L to G Mapping     3              0            0     0
           Container     5              0            0     0
       Krylov Solver    60             15       451800     0
              Vector   900            610     65595960     0
      Vector Scatter   115             60        62160     0
              Matrix   355            220    226589740     0
      Matrix Coarsen    15             15         9180     0
    Distributed Mesh    10              0            0     0
     Bipartite Graph    20              0            0     0
           Index Set   280            270      3224240     0
   IS L to G Mapping    15              0            0     0
      Preconditioner    60             15        12360     0
              Viewer     1              0            0     0
         PetscRandom    15             15         9120     0
              Vector   782            492    230472480     0
              Matrix    20              0            0     0
           Index Set    60              0            0     0
           Container     5              0            0     0
              Vector   816            526    246399440     0
              Matrix    20              0            0     0
           Index Set    60              0            0     0
Average time to get PetscTime(): 1.90735e-07
Average time for MPI_Barrier(): 0.000296211
Average time for zero size MPI_Send(): 0.000285755
#PETSc Option Table entries:
-ksp_converged_reason
-ksp_monitor_true_residual
-ksp_rtol 1.0e-7
-ksp_type fgmres
-log_summary
-mg_levels_ksp_max_it 1
-mg_levels_ksp_type gmres
-mg_levels_pc_type bjacobi
-pc_type gamg
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure run at: Tue Sep 18 16:22:39 2012
Configure options: --with-debugging=0 --with-cc=gcc --with-fc=gfortran --download-f-blas-lapack --download-mpich
Libraries compiled on Tue Sep 18 16:22:39 2012 on firefox.bioinfo.ittc.ku.edu
Machine characteristics: Linux-2.6.18-92.1.13.el5-x86_64-with-redhat-5.2-Final
Using PETSc directory: /bio/work1/zlwei/PETSc/petsc-dev
Using PETSc arch: arch-linux2-c-debug
Using C compiler: /bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/bin/mpicc  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/bin/mpif90   -Wall -Wno-unused-variable -O  ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/include -I/bio/work1/zlwei/PETSc/petsc-dev/include -I/bio/work1/zlwei/PETSc/petsc-dev/include -I/bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/include
Using C linker: /bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/bin/mpicc
Using Fortran linker: /bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/bin/mpif90
Using libraries: -Wl,-rpath,/bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/lib -L/bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/lib -lpetsc -lX11 -lpthread -Wl,-rpath,/bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/lib -L/bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/lib -lflapack -lfblas -lm -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2 -lmpichf90 -lgfortran -lm -lm -ldl -lmpich -lopa -lmpl -lrt -lgcc_s -ldl
