[petsc-users] A similar question of "Enquiry regarding log summary results"
Zhenglun (Alan) Wei zhenglun.wei at gmail.com
Fri Oct 5 11:51:15 CDT 2012
Dear folks,
     I hope you're having a nice day.
     I've been reading the thread of "Enquiry regarding log summary
results" and tried the similar things with -log_summary with my code.
However, my output seems totally different from Dr. TAY Wee-beng's. I
attached it here. My code adopts the
/src/ksp/ksp/example/tutorial/ex45.c from Dr. Yang to solve the Poisson
equation (twice). The "Event Stage 3" and "Event Stage 5" are just for
"KSPSolve", for example:
     ierr = PetscLogStagePush(stages[2]);  CHKERRQ(ierr); // Start
Pressure Poisson Equation Solve
     ierr = KSPSolve(ksp,PETSC_NULL,PETSC_NULL);CHKERRQ(ierr);
     ierr = PetscLogStagePop();  CHKERRQ(ierr); // Finish Pressure
      Therefore, solving the equation takes most of my times. In the
procedure of solving the equation, VecMDot, MatMult, MatMultAdd,
MatMultTranspose takes lots of time.
Event                Count      Time (sec)
Flops                             --- Global ---  --- Stage --- Total
                    Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg
len Reduct  %T %f %M %L %R  %T %f %M %L %R Mflop/s
--- Event Stage 3: Pressure Solve
KSPGMRESOrthog      8643 1.0 2.0476e+0313.1 5.84e+09 1.0 0.0e+00 0.0e+00
8.6e+03 17 13  0  0 17  39 29  0  0 36   270
KSPSetUp               5 1.0 1.0729e-05 3.5 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               5 1.0 4.0481e+03 1.0 2.05e+10 1.0 4.0e+07 1.2e+03
2.4e+04 44 46 47 44 46 100100100100100   477
VecMDot             8643 1.0 2.0424e+0313.5 2.92e+09 1.0 0.0e+00 0.0e+00
8.6e+03 17  7  0  0 17  39 14  0  0 36   135
VecNorm            14503 1.0 8.7184e+02 6.4 8.47e+08 1.0 0.0e+00 0.0e+00
1.5e+04  7  2  0  0 28  15  4  0  0 61    92
VecScale           14503 1.0 3.7836e+00 4.7 4.23e+08 1.0 0.0e+00 0.0e+00
0.0e+00  0  1  0  0  0   0  2  0  0  0 10598
VecCopy             5767 1.0 2.0257e+00 3.8 0.00e+00 0.0 0.0e+00 0.0e+00
VecSet             34670 1.0 5.5035e+00 4.7 0.00e+00 0.0 0.0e+00 0.0e+00
VecAXPY             8741 1.0 2.9888e+00 4.5 5.10e+08 1.0 0.0e+00 0.0e+00
0.0e+00  0  1  0  0  0   0  3  0  0  0 16172
VecAYPX             2881 1.0 1.7167e+00 7.2 8.41e+07 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0  4640
VecWAXPY              93 1.0 5.3297e-02 4.8 2.71e+06 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0  4824
VecMAXPY           14503 1.0 1.5191e+01 3.1 3.42e+09 1.0 0.0e+00 0.0e+00
0.0e+00  0  8  0  0  0   0 17  0  0  0 21342
VecAssemblyBegin       5 1.0 3.7097e+0012.5 0.00e+00 0.0 0.0e+00 0.0e+00
1.5e+01  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         5 1.0 2.9087e-05 5.8 0.00e+00 0.0 0.0e+00 0.0e+00
VecScatterBegin    26022 1.0 1.1726e+01 4.2 0.00e+00 0.0 4.0e+07 1.2e+03
0.0e+00  0  0 47 44  0   0  0100100  0     0
VecScatterEnd      26022 1.0 3.5268e+03 3.5 0.00e+00 0.0 0.0e+00 0.0e+00
0.0e+00 19  0  0  0  0  43  0  0  0  0     0
VecNormalize       11524 1.0 8.4214e+02 7.2 1.01e+09 1.0 0.0e+00 0.0e+00
1.2e+04  6  2  0  0 22  15  5  0  0 49   114
MatMult            14498 1.0 3.0545e+0382.7 5.50e+09 1.0 6.4e+06 7.6e+03
0.0e+00  9 12  8 44  0  21 27 16 98  0   169
MatMultAdd          2881 1.0 1.8177e+0218.6 1.09e+09 1.1 3.6e+06 1.5e+01
0.0e+00  1  2  4  0  0   2  5  9  0  0   560
MatMultTranspose    2881 1.0 7.1296e+0274.9 1.09e+09 1.1 3.6e+06 1.5e+01
0.0e+00  5  2  4  0  0  11  5  9  0  0   143
MatSolve           14405 1.0 3.9663e+01 3.3 4.56e+09 1.0 0.0e+00 0.0e+00
0.0e+00  0 10  0  0  0   1 22  0  0  0 10890
MatLUFactorNum         5 1.0 3.9389e-02 1.6 3.05e+06 1.0 0.0e+00 0.0e+00
0.0e+00  0  0  0  0  0   0  0  0  0  0  7322
MatILUFactorSym        5 1.0 4.2221e-02 3.2 0.00e+00 0.0 0.0e+00 0.0e+00
5.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            5 1.0 9.7752e-06 5.1 0.00e+00 0.0 0.0e+00 0.0e+00
MatGetOrdering         5 1.0 2.9373e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00
1.0e+01  0  0  0  0  0   0  0  0  0  0     0
PCSetUp                5 1.0 8.3110e-02 2.0 3.05e+06 1.0 0.0e+00 0.0e+00
1.5e+01  0  0  0  0  0   0  0  0  0  0  3470
PCSetUpOnBlocks     5762 1.0 9.9790e-02 2.0 3.05e+06 1.0 0.0e+00 0.0e+00
1.5e+01  0  0  0  0  0   0  0  0  0  0  2890
PCApply             2881 1.0 3.3151e+03 1.0 1.37e+10 1.0 3.8e+07 1.0e+03
1.7e+04 36 31 46 36 33  82 67 97 80 73   390
        BTW, how to really calculate the time that a function costs? For
example, it shows that "VecMDot, 2.0424e+0313.5". Would that be
2.0424*10^313.5 sec?
thanks,
Alan
***             WIDEN YOUR WINDOW TO 120 CHARACTERS.  Use 'enscript -r -fCourier9' to print this document            ***
---------------------------------------------- PETSc Performance Summary: ----------------------------------------------
./ex45 on a arch-linux2-c-debug named compute-7-12.local with 96 processors, by zlwei Thu Oct  4 18:16:59 2012
Using Petsc Development HG revision: 98bf11863c3be31b7c2af504314a500bc64d88c9  HG Date: Wed Aug 29 13:51:08 2012 -0500
                         Max       Max/Min        Avg      Total
Time (sec):           9.287e+03      1.00000   9.287e+03
Objects:              2.271e+03      1.04127   2.192e+03
Flops:                4.641e+10      1.08786   4.392e+10  4.216e+12
Flops/sec:            4.998e+06      1.08786   4.729e+06  4.540e+08
MPI Messages:         1.039e+06      1.42613   8.729e+05  8.380e+07
MPI Message Lengths:  1.534e+09      2.02516   1.321e+03  1.107e+11
MPI Reductions:       5.191e+04      1.00174
Flop counting convention: 1 flop = 1 real number operation of type (multiply/divide/add/subtract)
                            e.g., VecAXPY() for real vectors of length N --> 2N flops
                            and VecAXPY() for complex vectors of length N --> 8N flops
Summary of Stages:   ----- Time ------  ----- Flops -----  --- Messages ---  -- Message Lengths --  -- Reductions --
                        Avg     %Total     Avg     %Total   counts   %Total     Avg         %Total   counts   %Total
 0:      Main Stage: 6.3501e+02   6.8%  4.6734e+08   0.0%  2.344e+04   0.0%  7.888e+01        6.0%  3.200e+01   0.1%
 1:      DMMG Setup: 3.6959e+00   0.0%  0.0000e+00   0.0%  3.768e+03   0.0%  4.090e-02        0.0%  3.500e+01   0.1%
 2: Pressure RHS Setup: 7.5716e+01   0.8%  9.2365e+10   2.2%  3.556e+05   0.4%  7.402e+00        0.6%  1.106e+03   2.1%
 3:  Pressure Solve: 4.0469e+03  43.6%  1.9304e+12  45.8%  3.978e+07  47.5%  5.878e+02       44.5%  2.376e+04  45.8%
 4: Corrector RHS Setup: 1.2268e+02   1.3%  9.2365e+10   2.2%  3.556e+05   0.4%  7.402e+00        0.6%  1.106e+03   2.1%
 5: Corrector Solve: 4.4028e+03  47.4%  2.1006e+12  49.8%  4.328e+07  51.7%  6.396e+02       48.4%  2.580e+04  49.7%
See the 'Profiling' chapter of the users' manual for details on interpreting output.
Phase summary info:
   Count: number of times phase was executed
   Time and Flops: Max - maximum over all processors
                   Ratio - ratio of maximum to minimum over all processors
   Mess: number of messages sent
   Avg. len: average message length
   Reduct: number of global reductions
   Global: entire computation
   Stage: stages of a computation. Set stages with PetscLogStagePush() and PetscLogStagePop().
      %T - percent time in this phase         %f - percent flops in this phase
      %M - percent messages in this phase     %L - percent message lengths in this phase
      %R - percent reductions in this phase
   Total Mflop/s: 10e-6 * (sum of flops over all processors)/(max time over all processors)
Event                Count      Time (sec)     Flops                             --- Global ---  --- Stage ---   Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   Avg len Reduct  %T %f %M %L %R  %T %f %M %L %R Mflop/s
--- Event Stage 0: Main Stage
VecNorm               10 1.0 4.2983e+0037.8 5.84e+05 1.0 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  0   0 12  0  0 31    13
VecSet                 1 1.0 2.5029e-03 3.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               10 1.0 2.1505e-03 3.0 5.84e+05 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0 12  0  0  0 25713
VecScatterBegin       11 1.0 6.8583e-03 6.0 0.00e+00 0.0 5.8e+03 6.9e+03 0.0e+00  0  0  0  0  0   0  0 25  1  0     0
VecScatterEnd         11 1.0 4.6764e+00693.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult               10 1.0 3.7633e+00181.3 3.79e+06 1.0 4.4e+03 7.6e+03 0.0e+00  0  0  0  0  0   0 76 19  1  0    95
--- Event Stage 1: DMMG Setup
--- Event Stage 2: Pressure RHS Setup
KSPGMRESOrthog       835 2.0 2.1537e+00 8.0 1.19e+09 3.5 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1 46  0  0  0 19894
KSPSetUp              25 1.0 5.1173e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+02  0  0  0  0  0   1  0  0  0 12     0
KSPSolve              30 1.0 5.3262e+00 4.9 1.82e+09 2.7 0.0e+00 0.0e+00 1.5e+02  0  2  0  0  0   4 85  0  0 13 14779
VecMDot              835 2.0 1.2693e+00 7.9 5.97e+08 3.5 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1 23  0  0  0 16877
VecNorm              865 1.9 1.7481e-01 9.8 4.25e+07 1.8 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  3  0  0  0 14441
VecScale             865 1.9 2.4498e-02 2.5 2.12e+07 1.8 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 51524
VecCopy               30 1.0 1.1885e-02 3.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               250 1.2 9.3647e-02 5.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               30 1.0 9.2101e-03 4.0 1.58e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 15871
VecMAXPY             865 1.9 1.0598e+00 9.0 6.38e+08 3.3 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0 26  0  0  0 22458
VecAssemblyBegin       5 1.0 6.5455e-01 6.3 0.00e+00 0.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   1  0  0  0  1     0
VecAssemblyEnd         5 1.0 2.6226e-05 3.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         865 1.9 1.8566e-01 6.0 6.37e+07 1.8 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  4  0  0  0 20396
MatMult              835 2.0 1.2689e+00 4.7 2.53e+08 1.9 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1 15  0  0  0 11213
MatSolve             865 1.9 1.5827e+00 3.7 2.63e+08 1.9 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1 16  0  0  0  9541
MatLUFactorSym         5 1.0 1.4618e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  1     0
MatLUFactorNum        10 1.0 8.0587e-02 1.9 2.36e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  2  0  0  0 27888
MatILUFactorSym        5 1.0 4.6887e-02 4.6 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               5 1.0 1.9262e-03 2.8 7.91e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 37944
MatAssemblyBegin      65 1.0 4.2835e+00 8.0 0.00e+00 0.0 6.4e+03 1.6e+04 5.0e+01  0  0  0  0  0   3  0  2 17  5     0
MatAssemblyEnd        65 1.0 1.2531e+01 1.1 0.00e+00 0.0 5.8e+04 1.5e+02 1.2e+02  0  0  0  0  0  16  0 16  1 11     0
MatGetRowIJ           10 1.0 1.2584e-03 1.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice      20 1.0 7.2942e+0027.7 0.00e+00 0.0 1.1e+04 9.1e+03 9.5e+01  0  0  0  0  0   3  0  3 16  9     0
MatGetOrdering        10 1.0 4.9312e-03 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+01  0  0  0  0  0   0  0  0  0  3     0
MatMatMult             5 1.0 2.5914e-02 4.8 7.40e+05 2.4 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  0   0  0  0  0  1  2422
MatPtAP                5 1.0 2.2527e+01 1.0 1.85e+08 3.1 7.3e+04 3.3e+03 1.4e+02  0  0  0  0  0  30 12 21 38 12   510
MatPtAPSymbolic        5 1.0 2.1820e+01 1.0 0.00e+00 0.0 6.7e+04 3.5e+03 1.2e+02  0  0  0  0  0  29  0 19 37 11     0
MatPtAPNumeric         5 1.0 1.0236e+00 1.6 1.85e+08 3.1 6.2e+03 7.4e+02 1.0e+01  0  0  0  0  0   1 12  2  1  1 11233
MatGetRedundant        5 1.0 2.4219e+01 1.2 0.00e+00 0.0 1.4e+05 1.1e+03 2.0e+01  0  0  0  0  0  29  0 38 25  2     0
MatGetLocalMat         5 1.0 1.9222e-02 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  0   0  0  0  0  1     0
MatGetBrAoCol          5 1.0 1.7008e+0119.2 0.00e+00 0.0 6.6e+03 3.5e+04 1.0e+01  0  0  0  0  0  12  0  2 37  1     0
MatGetSymTrans        10 1.0 9.4867e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCSetUp                5 1.0 7.3916e+01 1.0 1.92e+09 2.5 3.3e+05 1.8e+03 7.1e+02  1  2  0  1  1  95100 93 96 64  1250
PCApply              865 1.9 1.5850e+00 3.7 2.63e+08 1.9 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1 16  0  0  0  9527
KSPGMRESOrthog      8643 1.0 2.0476e+0313.1 5.84e+09 1.0 0.0e+00 0.0e+00 8.6e+03 17 13  0  0 17  39 29  0  0 36   270
KSPSetUp               5 1.0 1.0729e-05 3.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               5 1.0 4.0481e+03 1.0 2.05e+10 1.0 4.0e+07 1.2e+03 2.4e+04 44 46 47 44 46 100100100100100   477
VecMDot             8643 1.0 2.0424e+0313.5 2.92e+09 1.0 0.0e+00 0.0e+00 8.6e+03 17  7  0  0 17  39 14  0  0 36   135
VecNorm            14503 1.0 8.7184e+02 6.4 8.47e+08 1.0 0.0e+00 0.0e+00 1.5e+04  7  2  0  0 28  15  4  0  0 61    92
VecScale           14503 1.0 3.7836e+00 4.7 4.23e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  2  0  0  0 10598
VecCopy             5767 1.0 2.0257e+00 3.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet             34670 1.0 5.5035e+00 4.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY             8741 1.0 2.9888e+00 4.5 5.10e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  3  0  0  0 16172
VecAYPX             2881 1.0 1.7167e+00 7.2 8.41e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4640
VecWAXPY              93 1.0 5.3297e-02 4.8 2.71e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4824
VecMAXPY           14503 1.0 1.5191e+01 3.1 3.42e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  8  0  0  0   0 17  0  0  0 21342
VecAssemblyBegin       5 1.0 3.7097e+0012.5 0.00e+00 0.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         5 1.0 2.9087e-05 5.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin    26022 1.0 1.1726e+01 4.2 0.00e+00 0.0 4.0e+07 1.2e+03 0.0e+00  0  0 47 44  0   0  0100100  0     0
VecScatterEnd      26022 1.0 3.5268e+03 3.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 19  0  0  0  0  43  0  0  0  0     0
VecNormalize       11524 1.0 8.4214e+02 7.2 1.01e+09 1.0 0.0e+00 0.0e+00 1.2e+04  6  2  0  0 22  15  5  0  0 49   114
MatMult            14498 1.0 3.0545e+0382.7 5.50e+09 1.0 6.4e+06 7.6e+03 0.0e+00  9 12  8 44  0  21 27 16 98  0   169
MatMultAdd          2881 1.0 1.8177e+0218.6 1.09e+09 1.1 3.6e+06 1.5e+01 0.0e+00  1  2  4  0  0   2  5  9  0  0   560
MatMultTranspose    2881 1.0 7.1296e+0274.9 1.09e+09 1.1 3.6e+06 1.5e+01 0.0e+00  5  2  4  0  0  11  5  9  0  0   143
MatSolve           14405 1.0 3.9663e+01 3.3 4.56e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0 10  0  0  0   1 22  0  0  0 10890
MatLUFactorNum         5 1.0 3.9389e-02 1.6 3.05e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  7322
MatILUFactorSym        5 1.0 4.2221e-02 3.2 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            5 1.0 9.7752e-06 5.1 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         5 1.0 2.9373e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  0   0  0  0  0  0     0
PCSetUp                5 1.0 8.3110e-02 2.0 3.05e+06 1.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  0  3470
PCSetUpOnBlocks     5762 1.0 9.9790e-02 2.0 3.05e+06 1.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  0  2890
PCApply             2881 1.0 3.3151e+03 1.0 1.37e+10 1.0 3.8e+07 1.0e+03 1.7e+04 36 31 46 36 33  82 67 97 80 73   390
--- Event Stage 4: Corrector RHS Setup
KSPGMRESOrthog       835 2.0 2.1493e+00 7.9 1.19e+09 3.5 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   1 46  0  0  0 19935
KSPSetUp              25 1.0 5.1442e-01 1.1 0.00e+00 0.0 0.0e+00 0.0e+00 1.4e+02  0  0  0  0  0   0  0  0  0 12     0
KSPSolve              30 1.0 5.3268e+00 4.7 1.82e+09 2.7 0.0e+00 0.0e+00 1.5e+02  0  2  0  0  0   2 85  0  0 13 14777
VecMDot              835 2.0 1.2651e+00 7.8 5.97e+08 3.5 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0 23  0  0  0 16933
VecNorm              865 1.9 1.4096e-01 7.7 4.25e+07 1.8 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  3  0  0  0 17909
VecScale             865 1.9 2.4702e-02 2.5 2.12e+07 1.8 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  1  0  0  0 51099
VecCopy               30 1.0 1.1083e-02 3.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet               250 1.2 1.6737e-0110.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY               30 1.0 9.1493e-03 3.9 1.58e+06 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 15977
VecMAXPY             865 1.9 1.1516e+00 9.5 6.38e+08 3.3 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0 26  0  0  0 20668
VecAssemblyBegin       5 1.0 6.9304e-01 9.7 0.00e+00 0.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  1     0
VecAssemblyEnd         5 1.0 3.0994e-05 4.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNormalize         865 1.9 1.5194e-01 4.8 6.37e+07 1.8 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  4  0  0  0 24922
MatMult              835 2.0 1.2717e+00 4.5 2.53e+08 1.9 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1 15  0  0  0 11188
MatSolve             865 1.9 1.5930e+00 3.7 2.63e+08 1.9 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1 16  0  0  0  9478
MatLUFactorSym         5 1.0 1.3718e-02 1.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  1     0
MatLUFactorNum        10 1.0 1.5112e-01 3.6 2.36e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  2  0  0  0 14871
MatILUFactorSym        5 1.0 4.7347e-02 4.5 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatScale               5 1.0 2.2573e-03 3.6 7.91e+05 1.1 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0 32378
MatAssemblyBegin      65 1.0 4.3617e+00 8.9 0.00e+00 0.0 6.4e+03 1.6e+04 5.0e+01  0  0  0  0  0   2  0  2 17  5     0
MatAssemblyEnd        65 1.0 9.5838e+00 1.1 0.00e+00 0.0 5.8e+04 1.5e+02 1.2e+02  0  0  0  0  0   7  0 16  1 11     0
MatGetRowIJ           10 1.0 1.9398e-03 2.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetSubMatrice      20 1.0 7.1810e+0026.4 0.00e+00 0.0 1.1e+04 9.1e+03 9.5e+01  0  0  0  0  0   2  0  3 16  9     0
MatGetOrdering        10 1.0 5.8639e-03 1.7 0.00e+00 0.0 0.0e+00 0.0e+00 3.0e+01  0  0  0  0  0   0  0  0  0  3     0
MatMatMult             5 1.0 2.5045e-02 4.9 7.40e+05 2.4 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  0   0  0  0  0  1  2506
MatPtAP                5 1.0 1.9980e+01 1.0 1.85e+08 3.1 7.3e+04 3.3e+03 1.4e+02  0  0  0  0  0  16 12 21 38 12   575
MatPtAPSymbolic        5 1.0 1.9330e+01 1.0 0.00e+00 0.0 6.7e+04 3.5e+03 1.2e+02  0  0  0  0  0  16  0 19 37 11     0
MatPtAPNumeric         5 1.0 1.0708e+00 1.7 1.85e+08 3.1 6.2e+03 7.4e+02 1.0e+01  0  0  0  0  0   1 12  2  1  1 10737
MatGetRedundant        5 1.0 2.3013e+01 1.1 0.00e+00 0.0 1.4e+05 1.1e+03 2.0e+01  0  0  0  0  0  18  0 38 25  2     0
MatGetLocalMat         5 1.0 1.8890e-02 1.2 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  0   0  0  0  0  1     0
MatGetBrAoCol          5 1.0 1.7516e+0129.6 0.00e+00 0.0 6.6e+03 3.5e+04 1.0e+01  0  0  0  0  0   7  0  2 37  1     0
MatGetSymTrans        10 1.0 9.4180e-03 1.9 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCSetUp                5 1.0 6.7590e+01 1.0 1.92e+09 2.5 3.3e+05 1.8e+03 7.1e+02  1  2  0  1  1  54100 93 96 64  1367
PCApply              865 1.9 1.5955e+00 3.7 2.63e+08 1.9 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   1 16  0  0  0  9464
--- Event Stage 5: Corrector Solve
KSPGMRESOrthog      9405 1.0 2.2276e+0312.9 6.35e+09 1.0 0.0e+00 0.0e+00 9.4e+03 19 14  0  0 18  39 29  0  0 36   270
KSPSetUp               5 1.0 1.1921e-05 4.2 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve               5 1.0 4.4038e+03 1.0 2.23e+10 1.0 4.3e+07 1.2e+03 2.6e+04 47 50 52 48 50 100100100100100   477
VecMDot             9405 1.0 2.2221e+0313.3 3.17e+09 1.0 0.0e+00 0.0e+00 9.4e+03 18  7  0  0 18  39 14  0  0 36   135
VecNorm            15782 1.0 9.4888e+02 6.4 9.21e+08 1.0 0.0e+00 0.0e+00 1.6e+04  7  2  0  0 30  15  4  0  0 61    92
VecScale           15782 1.0 4.1324e+00 4.7 4.61e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  2  0  0  0 10559
VecCopy             6275 1.0 2.1976e+00 3.8 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecSet             37727 1.0 5.9847e+00 4.7 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAXPY             9512 1.0 3.2965e+00 4.6 5.55e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0  1  0  0  0   0  3  0  0  0 15955
VecAYPX             3135 1.0 1.8733e+00 7.2 9.15e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4627
VecWAXPY             102 1.0 5.8617e-02 4.8 2.98e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  4811
VecMAXPY           15782 1.0 1.6524e+01 3.1 3.72e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0  8  0  0  0   0 17  0  0  0 21351
VecAssemblyBegin       5 1.0 2.8475e+00 3.9 0.00e+00 0.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd         5 1.0 4.1962e-05 8.4 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin    28317 1.0 1.3162e+01 4.3 0.00e+00 0.0 4.3e+07 1.2e+03 0.0e+00  0  0 52 48  0   0  0100100  0     0
VecScatterEnd      28317 1.0 3.8321e+03 3.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00 21  0  0  0  0  43  0  0  0  0     0
VecNormalize       12540 1.0 9.1638e+02 7.2 1.10e+09 1.0 0.0e+00 0.0e+00 1.3e+04  7  2  0  0 24  15  5  0  0 49   114
MatMult            15777 1.0 3.3229e+0381.6 5.99e+09 1.0 6.9e+06 7.6e+03 0.0e+00 10 13  8 48  0  21 27 16 98  0   169
MatMultAdd          3135 1.0 1.9759e+0218.9 1.19e+09 1.1 3.9e+06 1.5e+01 0.0e+00  1  3  5  0  0   2  5  9  0  0   560
MatMultTranspose    3135 1.0 7.7572e+0277.0 1.19e+09 1.1 3.9e+06 1.5e+01 0.0e+00  5  3  5  0  0  11  5  9  0  0   143
MatSolve           15675 1.0 4.3195e+01 3.2 4.96e+09 1.0 0.0e+00 0.0e+00 0.0e+00  0 11  0  0  0   1 22  0  0  0 10881
MatLUFactorNum         5 1.0 3.9492e-02 1.7 3.05e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0  7303
MatILUFactorSym        5 1.0 4.3832e-02 3.3 0.00e+00 0.0 0.0e+00 0.0e+00 5.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            5 1.0 1.0014e-0510.5 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetOrdering         5 1.0 1.3327e-02 9.4 0.00e+00 0.0 0.0e+00 0.0e+00 1.0e+01  0  0  0  0  0   0  0  0  0  0     0
PCSetUp                5 1.0 8.3063e-02 1.9 3.05e+06 1.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  0  3472
PCSetUpOnBlocks     6270 1.0 1.0566e-01 2.0 3.05e+06 1.0 0.0e+00 0.0e+00 1.5e+01  0  0  0  0  0   0  0  0  0  0  2730
PCApply             3135 1.0 3.6073e+03 1.0 1.49e+10 1.0 4.2e+07 1.0e+03 1.9e+04 39 33 50 39 36  82 67 97 80 73   390
Memory usage is given in bytes:
Object Type          Creations   Destructions     Memory  Descendants' Mem.
Reports information only for process 0.
           Container     0             20        10960     0
       Krylov Solver     0             61       589472     0
              Vector    11           1252    255019784     0
      Vector Scatter     0             94        97384     0
              Matrix     0            160  185546300120     0
    Distributed Mesh     0             22      8606680     0
     Bipartite Graph     0             44        30096     0
           Index Set     0             90      2213200     0
   IS L to G Mapping     0             33      5681412     0
      Preconditioner     0             60        56800     0
              Viewer     1              0            0     0
       Krylov Solver     1              0            0     0
              Vector     5              4         5856     0
      Vector Scatter     4              0            0     0
    Distributed Mesh     2              0            0     0
     Bipartite Graph     4              0            0     0
           Index Set    10             10       264444     0
   IS L to G Mapping     3              0            0     0
           Container    10              0            0     0
       Krylov Solver    30              0            0     0
              Vector   385             55      2416680     0
      Vector Scatter    45              0            0     0
              Matrix   105             30     29966460     0
    Distributed Mesh    10              0            0     0
     Bipartite Graph    20              0            0     0
           Index Set   155            125      2631340     0
   IS L to G Mapping    15              0            0     0
      Preconditioner    30              0            0     0
              Vector   290              0            0     0
              Matrix     5              0            0     0
           Index Set    15              0            0     0
           Container    10              0            0     0
              Vector   290              0            0     0
              Matrix     5              0            0     0
           Index Set    15              0            0     0
Average time to get PetscTime(): 2.14577e-07
Average time for MPI_Barrier(): 0.000852394
Average time for zero size MPI_Send(): 0.00120548
#PETSc Option Table entries:
-ksp_rtol 1.0e-7
-ksp_type fgmres
-log_summary
-mg_levels_ksp_max_it 1
-mg_levels_ksp_type gmres
-mg_levels_pc_type bjacobi
-pc_type exotic
#End of PETSc Option Table entries
Compiled without FORTRAN kernels
Compiled with full precision matrices (default)
sizeof(short) 2 sizeof(int) 4 sizeof(long) 8 sizeof(void*) 8 sizeof(PetscScalar) 8 sizeof(PetscInt) 4
Configure run at: Tue Sep 18 16:22:39 2012
Configure options: --with-debugging=0 --with-cc=gcc --with-fc=gfortran --download-f-blas-lapack --download-mpich
Libraries compiled on Tue Sep 18 16:22:39 2012 on firefox.bioinfo.ittc.ku.edu
Machine characteristics: Linux-2.6.18-92.1.13.el5-x86_64-with-redhat-5.2-Final
Using PETSc directory: /bio/work1/zlwei/PETSc/petsc-dev
Using PETSc arch: arch-linux2-c-debug
Using C compiler: /bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/bin/mpicc  -Wall -Wwrite-strings -Wno-strict-aliasing -Wno-unknown-pragmas -O  ${COPTFLAGS} ${CFLAGS}
Using Fortran compiler: /bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/bin/mpif90   -Wall -Wno-unused-variable -O  ${FOPTFLAGS} ${FFLAGS}
Using include paths: -I/bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/include -I/bio/work1/zlwei/PETSc/petsc-dev/include -I/bio/work1/zlwei/PETSc/petsc-dev/include -I/bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/include
Using C linker: /bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/bin/mpicc
Using Fortran linker: /bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/bin/mpif90
Using libraries: -Wl,-rpath,/bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/lib -L/bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/lib -lpetsc -lX11 -lpthread -Wl,-rpath,/bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/lib -L/bio/work1/zlwei/PETSc/petsc-dev/arch-linux2-c-debug/lib -lflapack -lfblas -lm -L/usr/lib/gcc/x86_64-redhat-linux/4.1.2 -lmpichf90 -lgfortran -lm -lm -ldl -lmpich -lopa -lmpl -lrt -lgcc_s -ldl
