[petsc-users] Question about ts_ssp
Mon Jul 18 22:21:01 CDT 2011
Note that you cannot do 5 stages with rks3 because 5 is not square (such a
method would be in a different class). Use 4 or 9 stages with rks3.
On Jul 18, 2011 6:42 PM, "Sean Farley" <sean at mcs.anl.gov> wrote:
>> Methods can be chosen with -ts_ssp_type {rks2,rks3,rk104}
>> rks2: Second order methods with any number s>1 of stages. c_eff = (s-1)/s
>> rks3: Third order methods with s=n^2 stages, n>1. c_eff = (s-n)/s
>> rk104: A 10-stage fourth order method. c_eff = 0.6
> This means that there there are only three options for -ts_ssp_type.
Namely,
> -ts_ssp_type rks2
> -ts_ssp_type rks3
> -ts_ssp_type rk104
>> However, when I write
>> -ts_ssp_type rk53
> Therefore, this is not even close to being valid. What are you trying to
do?
> Get 5 work stages? You can see other ssp options with the -h option
> (probably helps to pipe the output to 'grep'),
> ./program -ts_type ssp -h | grep ssp
> -ts_type <beuler>: TS method (one of) euler beuler cn pseudo gl ssp theta
> alpha
> -ts_ssp_type <rk104>: Type of SSP method (one of) rks2 rks3 rk104
> (TSSSPSetType)
> -ts_ssp_nstages <5>: Number of stages (TSSSPSetNumStages)
> So, you would probably want the following options,
> ./program -ts_type ssp -ts_ssp_type rks3 -ts_ssp_nstages 5
> but keep in mind that 5 is the default for -ts_ssp_nstages.
> Hope that helps.
> Sean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110718/e8d30f89/attachment-0001.htm>
