[petsc-users] Question about ts_ssp
Sean Farley
sean at mcs.anl.gov
Mon Jul 18 20:42:22 CDT 2011
> Methods can be chosen with -ts_ssp_type {rks2,rks3,rk104}
> rks2: Second order methods with any number s>1 of stages. c_eff = (s-1)/s
> rks3: Third order methods with s=n^2 stages, n>1. c_eff = (s-n)/s
> rk104: A 10-stage fourth order method. c_eff = 0.6
This means that there there are only three options for -ts_ssp_type. Namely,
-ts_ssp_type rks2
-ts_ssp_type rks3
-ts_ssp_type rk104
> However, when I write
> -ts_ssp_type rk53
Therefore, this is not even close to being valid. What are you trying to do?
Get 5 work stages? You can see other ssp options with the -h option
(probably helps to pipe the output to 'grep'),
./program -ts_type ssp -h | grep ssp
-ts_type <beuler>: TS method (one of) euler beuler cn pseudo gl ssp theta
alpha
-ts_ssp_type <rk104>: Type of SSP method (one of) rks2 rks3 rk104
(TSSSPSetType)
-ts_ssp_nstages <5>: Number of stages (TSSSPSetNumStages)
So, you would probably want the following options,
./program -ts_type ssp -ts_ssp_type rks3 -ts_ssp_nstages 5
but keep in mind that 5 is the default for -ts_ssp_nstages.
Hope that helps.
Sean
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20110718/e8ecdecd/attachment.htm>
