[petsc-dev] Building PETSc on LLNL Lassen
Jacob Faibussowitsch
jacob.fai at gmail.com
Sun Dec 13 13:25:07 CST 2020
Hello All,
Does anyone have any experience building petsc with cuda support on Lassen? I’ve been having trouble building with ibm xl compilers + spectrum-mpi + nvcc. NVCC seems to not like -std=c++14 argument, complaining that its configured host compiler doesn’t support it, but compiling the following “test.cc <http://test.cc/>":
#include <stdlib.h>
int main(int argc, char **argv)
int i = 1;
i += argc;
return(i);
With mpicc -std=c++14 test.cc <http://test.cc/> produces zero errors.
Modules loaded:
module load xl/2020.11.12-cuda-11.1.1
module load spectrum-mpi
module load cuda/11.1.1
module load python/3.8.2
module load cmake
module load valgrind
module load lapack
My configure commands:
./configure --with-cc=mpicc --with-cxx=mpiCC --with-fc=mpifort --with-cuda --with-debugging=1 PETSC_ARCH=arch-linux-c-debug
The error:
TESTING: findMPIInc from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:636) *******************************************************************************
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
Bad compiler flag: -I/usr/tce/packages/spectrum-mpi/ibm/spectrum-mpi-rolling-release/include
The actual configure.log error:
Executing: nvcc -c -o /var/tmp/petsc-2v0k4k61/config.setCompilers/conftest.o -I/var/tmp/petsc-2v0k4\
k61/config.setCompilers -I/var/tmp/petsc-2v0k4k61/config.types -g -std=c++14 -I/usr/tce/packages/s\
pectrum-mpi/ibm/spectrum-mpi-rolling-release/include -Wno-deprecated-gpu-targets /var/tmp/petsc-2v\
0k4k61/config.setCompilers/conftest.cu
Possible ERROR while running compiler:
stderr:
nvcc warning : The -std=c++14 flag is not supported with the configured host compiler. Flag will be\
ignored.
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
return 0;
Rejecting compiler flag -I/usr/tce/packages/spectrum-mpi/ibm/spectrum-mpi-rolling-release/include due to
nvcc warning : The -std=c++14 flag is not supported with the configured host compiler. Flag will be ignored.
Best regards,
(Jacob Fai - booss - oh - vitch)
Cell: (312) 694-3391
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201213/0911b5f1/attachment-0002.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201213/0911b5f1/attachment-0001.obj>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201213/0911b5f1/attachment-0003.html>
