[petsc-dev] Building PETSc on LLNL Lassen
Jed Brown
jed at jedbrown.org
Sun Dec 13 15:36:30 CST 2020
I use Clang because XL compilers are buggy and not faster. This worked as of a few months ago:
#!/usr/tce/packages/python/python-3.7.2/bin/python3
if __name__ == '__main__':
import sys
import os
sys.path.insert(0, os.path.abspath('config'))
import configure
configure_options = [
'--with-blaslapack-lib=/usr/tcetmp/packages/essl/essl-6.2.1/lib64/liblapackforessl.so /usr/tcetmp/packages/essl/essl-6.2.1/lib64/libessl.so',
'--with-cuda=1',
'--with-debugging=0',
'--with-fc=0',
'--with-mpi-dir=/usr/tce/packages/spectrum-mpi/spectrum-mpi-rolling-release-clang-ibm-2019.10.03',
'COPTFLAGS=-O3 -mcpu=native -ffp-contract=fast',
'CUDAFLAGS=--gpu-architecture=sm_70 -ccbin clang++',
'CXXOPTFLAGS=-O3 -mcpu=native -ffp-contract=fast',
'PETSC_ARCH=lassen-clang-essl-opt',
configure.petsc_configure(configure_options)
Jacob Faibussowitsch <jacob.fai at gmail.com> writes:
> Hello All,
> Does anyone have any experience building petsc with cuda support on Lassen? I’ve been having trouble building with ibm xl compilers + spectrum-mpi + nvcc. NVCC seems to not like -std=c++14 argument, complaining that its configured host compiler doesn’t support it, but compiling the following “test.cc <http://test.cc/>":
> #include <stdlib.h>
> int main(int argc, char **argv)
> int i = 1;
> i += argc;
> return(i);
> With mpicc -std=c++14 test.cc <http://test.cc/> produces zero errors.
> Modules loaded:
> module load xl/2020.11.12-cuda-11.1.1
> module load spectrum-mpi
> module load cuda/11.1.1
> module load python/3.8.2
> module load cmake
> module load valgrind
> module load lapack
> My configure commands:
> ./configure --with-cc=mpicc --with-cxx=mpiCC --with-fc=mpifort --with-cuda --with-debugging=1 PETSC_ARCH=arch-linux-c-debug
> The error:
> TESTING: findMPIInc from config.packages.MPI(config/BuildSystem/config/packages/MPI.py:636) *******************************************************************************
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details):
> Bad compiler flag: -I/usr/tce/packages/spectrum-mpi/ibm/spectrum-mpi-rolling-release/include
> The actual configure.log error:
> Executing: nvcc -c -o /var/tmp/petsc-2v0k4k61/config.setCompilers/conftest.o -I/var/tmp/petsc-2v0k4\
> k61/config.setCompilers -I/var/tmp/petsc-2v0k4k61/config.types -g -std=c++14 -I/usr/tce/packages/s\
> pectrum-mpi/ibm/spectrum-mpi-rolling-release/include -Wno-deprecated-gpu-targets /var/tmp/petsc-2v\
> 0k4k61/config.setCompilers/conftest.cu
> Possible ERROR while running compiler:
> stderr:
> nvcc warning : The -std=c++14 flag is not supported with the configured host compiler. Flag will be\
> ignored.
> Source:
> #include "confdefs.h"
> #include "conffix.h"
> int main() {
> return 0;
> Rejecting compiler flag -I/usr/tce/packages/spectrum-mpi/ibm/spectrum-mpi-rolling-release/include due to
> nvcc warning : The -std=c++14 flag is not supported with the configured host compiler. Flag will be ignored.
> Best regards,
> (Jacob Fai - booss - oh - vitch)
> Cell: (312) 694-3391
