[petsc-dev] using typedef for each different memory space the variable lives in
Barry Smith bsmith at petsc.dev
Sun Dec 13 22:09:25 CST 2020
  Yes, the PetscKokkosScalar is just a PetscScalar in the Kokkos memory space (same with CUDA).
  Using variable names that give hints of where the variable lives is good but I think also indicating with a specific type is also useful to understand the code easily without needing to hunt around what lives where. Unfortunately the  compiler cannot do type checking but for me it is still useful trying to understand the code.
   Barry
> On Dec 13, 2020, at 9:23 PM, Mark Adams <mfadams at lbl.gov> wrote:
> On Sun, Dec 13, 2020 at 4:34 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>> On Dec 13, 2020, at 8:39 AM, Mark Adams <mfadams at lbl.gov <mailto:mfadams at lbl.gov>> wrote:
>> So how do I declare
>> struct myMat {
>>  PetscScalar *a;
>>  PetscInt        *i, *j, nrows;
>> so that I can use, or give me an alternative idiom,
>> struct myMat h_mat, *d_mat;
>> cudaMemcpy(          d_mat,   &h_mat,  sizeof(myMat),  cudaMemcpyHostToDevice))
>    This will copy the pointers (not the entries in the arrays) which means in both d_mat and h_mat a and i,j refer to Kokkos (or CUDA etc) memory so
> Yes. Note, h_mat is, in my usage, a temporary container. It is a mix of host and device memory and is just there to stuff device pointers and raw (meta) data, to be copied whole onto the device.
>> struct myMat {
>>  PetscKokkosScalar *a;
>>  PetscKokkosInt        *i, *j;
>    PetscInt                    nrows;
>    the nrows is annoying because in d_mat it refers to device memory while in h_mat it refers to host memory so we cannot label it clearly.
> Kokkos wraps all this ugliness, but in raw Cuda I do it this manual way. It's low level and you have to keep track in your head (names help) what is going on. But this mixed h_mat is just around in a local scope. A better name for it might be h_temp_mat.
> I think your PetscKokkosScalar is a Scalar in the default execution's memory space.
>    Sorry, by code reader I meant someone reading or maintaining the code.
>    To me the above struct is clearer, I know immediately that *a and *i, *j point to Kokkos space. While labeled as PetscScalar *a I have to figure out somehow by examining other code where it points (this is a waste of time I think).
> I think Junchao is doing something like this in aijkokkosimpl.hpp, as I said. He and I use variable names to make it clear where they are (eg, d_mat for a Mat on the device). Junchoa had to use Kokkos data type to talk to Kokkos, but we both use naming conventions.
> Here is a whole method that does this idiom. I have a Mat with a "data" pointer (this is a bad name but this was a void* at first) to its device "self".  I'm not sure how your suggestion would impact this.
> PETSC_EXTERN PetscErrorCode LandauCUDACreateMatMaps(P4estVertexMaps *maps, pointInterpolationP4est (*points)[LANDAU_MAX_Q_FACE], PetscInt Nf, PetscInt Nq)
>   P4estVertexMaps h_maps;
>   PetscFunctionBegin;
>   h_maps.num_elements =maps->num_elements;
>   h_maps.num_face = maps->num_face;
>   h_maps.num_reduced = maps->num_reduced;
>   h_maps.deviceType = maps->deviceType;
>   h_maps.Nf = Nf;
>   h_maps.Nq = Nq;
>   CUDA_SAFE_CALL(cudaMalloc((void **)&h_maps.c_maps,               maps->num_reduced  * sizeof *points));
>   CUDA_SAFE_CALL(cudaMemcpy(          h_maps.c_maps, maps->c_maps, maps->num_reduced  * sizeof *points, cudaMemcpyHostToDevice));
>   CUDA_SAFE_CALL(cudaMalloc((void **)&h_maps.gIdx,                 maps->num_elements * sizeof *maps->gIdx));
>   CUDA_SAFE_CALL(cudaMemcpy(          h_maps.gIdx, maps->gIdx,     maps->num_elements * sizeof *maps->gIdx, cudaMemcpyHostToDevice));
>   CUDA_SAFE_CALL(cudaMalloc((void **)&maps->data, sizeof(P4estVertexMaps)));
>   CUDA_SAFE_CALL(cudaMemcpy(          maps->data,   &h_maps, sizeof(P4estVertexMaps), cudaMemcpyHostToDevice));
>   PetscFunctionReturn(0);
> Mark
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20201213/96ec1aa4/attachment.html>
