[petsc-dev] Test output broken for test sets
Jed Brown
jed at jedbrown.org
Wed Sep 26 09:58:02 CDT 2018
Scott, do you know how to fix this?
Jakub Kruzik <jakub.kruzik at vsb.cz> writes:
> Related issues:
> https://lists.mcs.anl.gov/pipermail/petsc-dev/2018-August/023448.html
> Jakub
> On 9/24/18 3:26 PM, Matthew Knepley wrote:
>> At least on my machine, this does not work correctly
>> testset:
>> nsize: {{1 2 4}}
>> args: -use_generator -faces {{2,2,2 1,3,5 3,4,7}}
>> args: -interpolate -distribute -interpolate_after_distribute {{0 1}}
>> args: -dm_plex_check_pointsf
>> test:
>> #TODO some combinations generate wrong SF
>> suffix: 6_tet
>> requires: ctetgen
>> args: -cell_simplex 1 -dm_plex_generator ctetgen
>> test:
>> suffix: 6_hex
>> args: -cell_simplex 0
>> If I give REPLACE=1, it makes a single output file 6_hex.out and
>> 6_tet.out for all the test, with the output of the last test in it.
>> Thanks,
>> Matt
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
