[petsc-dev] Test output broken for test sets
Jakub Kruzik jakub.kruzik at vsb.cz
Wed Sep 26 09:53:05 CDT 2018
Related issues:
https://lists.mcs.anl.gov/pipermail/petsc-dev/2018-August/023448.html
Jakub
On 9/24/18 3:26 PM, Matthew Knepley wrote:
> At least on my machine, this does not work correctly
>   testset:
>     nsize: {{1 2 4}}
>     args: -use_generator -faces {{2,2,2  1,3,5  3,4,7}}
>     args: -interpolate -distribute -interpolate_after_distribute {{0 1}}
>     args: -dm_plex_check_pointsf
>     test:
>       #TODO some combinations generate wrong SF
>       suffix: 6_tet
>       requires: ctetgen
>       args: -cell_simplex 1 -dm_plex_generator ctetgen
>     test:
>       suffix: 6_hex
>       args: -cell_simplex 0
> If I give REPLACE=1, it makes a single output file 6_hex.out and
> 6_tet.out for all the test, with the output of the last test in it.
>   Thanks,
>      Matt
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20180926/be5aea48/attachment.html>
